RPi zero 2W bluez and C
cydrollinger
Post by cydrollinger »
So, I have been fishing around for information about connecting bluetooth low energy devices to an rpi zero 2 W. I came across a few sources of information, and an adafruit tutorial has been as good as any, but imcomplete and now outdated.
Resources:
https://learn.adafruit.com/install-blue ... stallation
https://people.csail.mit.edu/albert/blu ... index.html
https://www.bluetooth.com/bluetooth-res ... ovisioner/
So, I have successfully scanned bluetooth devices on the rpi zero 2 W after following the adafruit tutorial and testing an example program simplescan.c from https://people.csail.mit.edu/albert/blu ... /c404.html all from within buster lite.
So, it is possible to control the bluetooth radio and resources on an rpi from C programs, but the ability to do it without installing the latest bluez and relying on the preinstalled bluez on current rpi os has not been successful by me. Modern rpi os will allow me to compile and run helloworld.c it will not compile the simplescan.c program on account the reference to bluetooth/bluetooth.h header can not included.
I have been fishing for information about the official bluestack for linux: bluez and its location within the modern rpi os. I can find refences to bluetooth in /sys/module but the actual bluez folder and more specifically bluetooth.h is a mystery.
QUESTIONS: on modern rpi os is bluez the bluetooth stack or library used to control the bluetooth radio and resource? If so, where is it located, specifically the bluetooth.h file? Would there be any reason I could not create the simplescan.c file within that location compile and run with the same success I have seen thus far? Ultimately, I would like to utilize the recipe from Bluetooth Sig to manage a bluetooth mesh network. Is this reasonable?
mikeysklar
Re: RPi zero 2W bluez and C
Post by mikeysklar »
bluez and bluezutils are the official Linux Bluetooth protocol stack + utilities.
https://command-not-found.com/bluetoothctl
This package contains tools and system daemons for using Bluetooth devices. BlueZ is the official Linux Bluetooth protocol stack. It is an Open Source project distributed under GNU General Public License (GPL).
I use bluetoothctl on my Pi's to scan for other BLE devices and learn about their services. Example below.
pi@pidev:~ $ sudo bluetoothctl
Agent registered
[Logitech X50]# scan on
Discovery started
[CHG] Controller DC:A6:32:D2:9A:90 Discovering: yes
[NEW] Device CC:FD:D2:4F:82:1D Xtactor
[NEW] Device 70:81:53:04:20:4F 70-81-53-04-20-4F
[NEW] Device 4F:13:A6:7A:67:B6 4F-13-A6-7A-67-B6
[NEW] Device A0:38:F8:AD:39:D0 oura_A038F8AD39D0
[Logitech X50]# connect CC:FD:D2:4F:82:1D
Attempting to connect to CC:FD:D2:4F:82:1D
[CHG] Device CC:FD:D2:4F:82:1D Connected: yes
Connection successful
# scan off
Discovery stopped
[CHG] Controller DC:A6:32:D2:9A:90 Discovering: no
[CHG] Device D1:72:15:C7:30:93 RSSI is nil
[CHG] Device A0:38:F8:AD:39:D0 RSSI is nil
[CHG] Device 40:6C:1E:DB:DB:84 TxPower is nil
[CHG] Device 40:6C:1E:DB:DB:84 RSSI is nil
[CHG] Device 74:C1:D2:DD:04:D6 TxPower is nil
[CHG] Device 74:C1:D2:DD:04:D6 RSSI is nil
[Xtactor]# info
Device CC:FD:D2:4F:82:1D (random)
        Alias: Xtactor
        Appearance: 0x03c0
        Paired: no
        Trusted: no
        Blocked: no
        Connected: yes
        LegacyPairing: no
        UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
        UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
        UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
        UUID: Battery Service           (0000180f-0000-1000-8000-00805f9b34fb)
        UUID: Nordic Semiconductor ASA  (0000fe59-0000-1000-8000-00805f9b34fb)
        UUID: Vendor specific           (8ec9f001-f315-4f60-9fb8-838830daea50)
        UUID: Vendor specific           (8ec9f00a-f315-4f60-9fb8-838830daea50)
        UUID: Vendor specific           (8ec9f00b-f315-4f60-9fb8-838830daea50)
        UUID: Vendor specific           (8ec9f00d-f315-4f60-9fb8-838830daea50)
        RSSI: -61
