Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days. On MLK Day no orders will be shipped.
Adafruit Voice Bonnet - Input and Output at the same time?
by Bortus on Wed Nov 24, 2021 10:43 am
Hello there!
Is it possible to simultaneously record audio through the board's microphones and output it through the JST 2PH connector?
I plan to use the board for a DIY intercom system.
Bortus
Bortus
Re: Adafruit Voice Bonnet - Input and Output at the same tim
by mikeysklar on Fri Nov 26, 2021 2:33 pm
Bortus,
Good question. I cannot say that it work to record and playback audio simultaneously. The datasheet and guide do not mention this scenario.
https://cdn-learn.adafruit.com/assets/a ... 1603825540
The input and output would all be going over i2s through the same CODEC.
You could try something like these command running at the same time.
arecord --device=hw:1,0 --format S16_LE --rate 44100 -c1 test.wav
aplay -D plughw:1,0 test2.wav
Should playback be an issue you could use the Pi built-in 1/8" jack or HDMI audio output.
mikeysklar
by Bortus on Tue Nov 30, 2021 11:09 am
Thanks for the reply!
So I tried the following command (bonnet needs to be the default device or otherwise specified):
arecord -f cd | aplay
This works. Everything that is being picked up by the microphones is played back throught the speaker.
Bortus
by mikeysklar on Tue Nov 30, 2021 4:18 pm
oh cool, thanks for sharing the syntax to record and pipe the audio through a speaker.
mikeysklar
