Internet of Things Printer for Raspberry Pi
by MattPackwood on Fri Nov 19, 2021 10:49 am
I am trying to rebuild a unit, I am running "stretch"
The error I get trying to run:
python printertest.py
File "printertest.py", line 3, in <module>
from Adafruit_Thermal import *
File "/home/pi/Python-Thermal-Printer/Adafruit_Thermal.py", line 725
def print(self, *args, **kwargs):
SyntaxError: invalid syntax
Matt
MattPackwood
Re: Internet of Things Printer for Raspberry Pi
by adafruit_support_carter on Fri Nov 19, 2021 4:15 pm
Do you know what version "python" is on your setup? Can find out with:
python --version
by MattPackwood on Fri Nov 19, 2021 4:26 pm
Python 2.7.13
MattPackwood
by adafruit_support_carter on Fri Nov 19, 2021 4:32 pm
That's probably the issue. The library is now Python 3.
https://github.com/adafruit/Python-Ther ... /README.md
by MattPackwood on Sun Nov 21, 2021 9:22 pm
That got me a lot closer, I put an issue in the repository as well:
I am getting the following when I run
main.py
  File "main.py", line 101, in <module>
    printer.printImage(Image.open('gfx/hello.png'), True)
  File "/home/pi/Python-Thermal-Printer/Adafruit_Thermal.py", line 552, in printImage
    image = Image.open(image_file)
  File "/usr/lib/python3/dist-packages/PIL/Image.py", line 2643, in open
    prefix = fp.read(16)
AttributeError: 'PngImageFile' object has no attribute 'read'
Matt
MattPackwood
by DeluxCode on Mon Nov 22, 2021 9:52 pm
We are getting the exact same error from main.py - so looking forward to some help.
We noticed that in the new cloned version of main.py referenced above, all the internal calls are still to python and not python3. We tried updating those, but it doesn't get rid of this error.
DeluxCode
by DeluxCode on Wed Nov 24, 2021 9:59 am
Figured out the problem for the printer.printImage line...
Turns out that the function printImage calls an Image.open on the input which expects a string, not the output of Image.open.
So if you change
to
printer.printImage('gfx/hello.png', True)
in main.py, it will work. Note that this mistake also exists for a few other images in main.py, so you need to fix those too.
Now on to the next problems... can't use forecast.py as written because DarkSky is being shut down and we get some error messages from the number puzzle code (can't enter name as the forum says it is a banned word????)
DeluxCode
by MattPackwood on Fri Nov 26, 2021 11:37 am
Now I am "at"....
pi@iotp:~/Python-Thermal-Printer $ sudo python3 main.py
  File "forecast.py", line 17, in <module>
  File "sudoku-gfx.py", line 25, in <module>
  File "twitter.py", line 32, in <module>
  File "main.py", line 166, in <module>
    lastId = result.rstrip('\r\n')
TypeError: a bytes-like object is required, not 'str'
MattPackwood
by adafruit_support_carter on Mon Nov 29, 2021 2:57 pm
What are the constraints of your current application? Are you required to stick with buster and Python 2? Or could you update your setup to latest OS release and Python 3?
by DeluxCode on Tue Nov 30, 2021 9:55 pm
We finally got everything to work. Here is the steps it took...
1) Switched to python3. We updated some of the libraries from python versions to python3 versions in the 'sudo apt-get install' step. Not sure if this was necessary or not. We also edited main.py to use python3 for all the subprocess calls.
2) Edited Adafruit_thermal.py to update the function printImage. For this we commented out the line that said image = Image.open(image_file) and added a line that said image=image_file. The original line generates an error because an open image has already been passed in as the input to the overall function and not jus a text string for the file name (this is true in calls from both main.py and the number puzzle python code - sorry can't type it in directly because the forum is saying the word is banned).
3) Wrote our own forecast.py to get a weather report from the National Weather Service. Obviously, this won't work for outside the US, but DarkSky is being shutdown and we needed an alternative.
Hope this helps!
DeluxCode
by MattPackwood on Tue Dec 14, 2021 7:08 pm
Any chance you have sour code somewhere I can steal (I mean borrow) it from?
MattPackwood
by DeluxCode on Sun Dec 19, 2021 8:35 am
We don't have it posted anywhere yet, but would be happy too. Is there a central place we can load up the code? Seems it would be good for others trying to follow in the instructions in the future too.
DeluxCode
by MattPackwood on Sun Dec 19, 2021 12:41 pm
You could post it to GitHub, either under your own repository or suggest / do a pull request for the code in the Adafruit repository?
MattPackwood
by MattPackwood on Tue Dec 21, 2021 1:12 pm
Or you could send me the files...
My google email address is mattpackwood@google.com
Matt
MattPackwood
by rcb on Thu Dec 30, 2021 1:02 pm
I second the motion. It would be useful for others to update the GitHub so that the software for the printer is up-to-date and works with the printer kit Adafruit currently sells. Adafruit should make it easy for for DeluxCode to post the required update.
rcb
