No audio from UDA1334A I2S Stereo DAC
by fetimo on Tue Dec 07, 2021 2:08 pm
Hi Adafruit!
I'm trying to get sound output from this DAC, but there's just no output. I've run the install script and manually verified each step and rebooted a few times. I've tried connecting to an external amp and some cheap headphones to try debugging it.
I'm testing it by running
speaker-test -c2 --test=wav -w /usr/share/sounds/alsa/Front_Center.wav
speaker-test 1.2.4
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 2229 to 8916
Period size range from 1114 to 1115
Using max buffer size 8916
Periods = 4
was set period_size = 1114
was set buffer_size = 8916
 0 - Front Left
 1 - Front Right
Time per period = 2.696776
 0 - Front Left
 1 - Front Right
Time per period = 2.854197
 0 - Front Left
 1 - Front Right
Time per period = 2.854534
 0 - Front Left
 1 - Front Right
Time per period = 2.854280
 0 - Front Left
 1 - Front Right
Time per period = 2.853814
 0 - Front Left
 1 - Front Right
Time per period = 2.855340
 0 - Front Left
 1 - Front Right
Time per period = 2.854094
 0 - Front Left
 1 - Front Right
Time per period = 2.854542
 0 - Front Left
 1 - Front Right
aplay -l lists the following
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 [HifiBerry DAC HiFi pcm5102a-hifi-0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: vc4hdmi [vc4-hdmi], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
  Subdevices: 1/1
I'm running it on a Raspberry Pi Zero W and the latest Raspberry OS Lite:
Distributor ID:   Raspbian
Description:   Raspbian GNU/Linux 11 (bullseye)
Release:   11
Codename:   bullseye
I can also see output in hw_params when audio is playing and alsamixer recognises the device but there's still nothing out of the headphone jack. Any ideas?
fetimo
Re: No audio from UDA1334A I2S Stereo DAC
by adafruit_support_mike on Wed Dec 08, 2021 10:38 pm
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
by fetimo on Sat Dec 11, 2021 3:13 am
@adafruit_support_mike I'm ashamed to say that it was simply because I hadn't soldered the header onto the Zero. When it said it was solderless I took that a bit too literally! Sorry
fetimo
by adafruit_support_mike on Sat Dec 11, 2021 10:34 pm
Glad to hear you got it working. Happy hacking!
