I have put a GPIO Extension Header otherwise the HAT interferes with the RPi 4's PoE headers.
I have enabled i2c and ran
sudo i2cdetect -y 1
from adafruit_motorkit import MotorKit
import board
File "/usr/local/lib/python3.9/dist-packages/board.py", line 285, in <module>
raise NotImplementedError(
NotImplementError: Adafruit-PlatformDetect version 3.19.2 was unable to identify the board and/or microcontroller running the Linux Platform. Please make sure you have the latest packages running: 'pip3 install --upgrade adafruit-blinka adafruit-platformdetect'
I have taken a picture and put it on Google Drive for you to read fully if the above is confusing. See the link below
I have ran the code to update it and it has all come back saying it is updated. Has Adafruit dropped support for this HAT? Or will it not work with RPi 4? Or do I need to modify some files?
Please help!
https://rb.gy/wybqzj
