Hello, I'm having a problem with the I2S Audio Bonnet, it has a lot of noise on the speakers and clipping, that's either when I use it for playing audio or if I don't use it and just have the speakers connected to it. The interesting part is that If I press the hat onto the raspberry the noise goes lower.
The system is with a raspberry pi zw, I already tried with different raspberries and hats, all have the same problem. Trying with the hat from Hifyberry doesn't give me any problem and the sound quality is excellent so there is no problem on the soldering.
I have tried the setup with raspberry os bullseye and buster, both with the same issues only buster had a lower noise level. I have tried installing manually the drivers and with the Automatic script, both had the same issue. I also tried disabling Aplay, again with no difference. The volume in AlsaMixer is 80% and the interesting part is that even with 0% volume I still get the noise in the speakers.
I don't know what else to try.
Ps sorry for my bad english
