ADS1115 16 bit ADC
AsifSaeed
ADS1115 16 bit ADC
Post by AsifSaeed »
Hello Guys,
I am supplying the voltage 3.3 to the ADC from raspberry pi.
Gain = 1 mean (4.09V)
My question is
is it possible for me to measure the signal greater than 3.3V upto 4.09V on any channel????
I have read, its not possible to measure the signal greater than the supplied voltage to the ADC, which is in my case 3.3V
Re: ADS1115 16 bit ADC
No. It is not possible to measure signals greater than VDD. And any voltage higher the VDD + 0.3V is likely to cause permanent damage to the device.
(See section 7. Absolute Maximum Ratings)
https://www.ti.com/lit/ds/symlink/ads11 ... e.com%252F
sj_remington
Post by sj_remington »
You can use a voltage divider to reduce an input voltage to the allowable range.
AsifSaeed
Post by AsifSaeed »
If i apply 5V to the ADC, then i can measure the signal on any channel upto 5V. right????
Yes. However now the i2c signals will be pulled up to 5v also, so you will need an i2c level-shifter to protect the signal pins on your Pi. https://www.adafruit.com/product/757
The voltage divider solution suggested by sj_remington is a bit simpler.
AsifSaeed
Post by AsifSaeed »
adafruit_support_bill wrote:Yes. However now the i2c signals will be pulled up to 5v also, so you will need an i2c level-shifter to protect the signal pins on your Pi. https://www.adafruit.com/product/757
great . Thank you for suport
Return to “Adafruit Raspberry Pi® accessories”
