Due to high demand, expect some shipping delays at this time - orders may not ship for up to 2-3 business days.
RuntimeError: Could not determine default I2C bus for platfo
by r0760589 on Fri May 13, 2022 8:40 am
Hi
I am using a raspberry pi 4 running on ubuntu and I am trying to create an analog singnal. I am doing this by using a MCP4725 connected to my raspberry pi. But I keep getting the same error even after trying multiple solutions I found on the web. The project is to send the signal to a frequencydrive to alter the speed of a motor. This to build an autonomous boat for my master thesis.
dac=Adafruit_MCP4725.MCP4725(adress=0x62)
This is the line of code in my python script where the error occurs.
Kind regards
r0760589
Re: RuntimeError: Could not determine default I2C bus for pl
by dastels on Fri May 13, 2022 8:59 am
Do you have I2C enabled on the Pi?
dastels
by r0760589 on Fri May 13, 2022 9:03 am
yes, and when I check it in the config file it also says it's enabled
r0760589
by dastels on Fri May 13, 2022 9:31 am
If this is a cut & paste from your code: dac=Adafruit_MCP4725.MCP4725(adress=0x62)...
address, not adress
dastels
by r0760589 on Fri May 13, 2022 10:24 am
Hi, I indeed wrongly typed it in the topic, in the code it is written as address.
Kind regards
r0760589
by dastels on Fri May 13, 2022 4:33 pm
Try scanning I2C and see what gets reported: https://learn.adafruit.com/scanning-i2c-addresses/raspberry-pi.
dastels
by r0760589 on Fri May 13, 2022 5:55 pm
Dear
It gives me as a result that on my 62 address I have my MCP4725 connected. And if I disconnect my MCP4725 the address 62 disappears. So I am sure that my configuration is set correctly.
r0760589
by dastels on Fri May 13, 2022 7:05 pm
Can you paste the output if you run the code in the REPL.
dastels
by r0760589 on Sat May 14, 2022 5:34 am
We’ve fixed it! Thanks for the help anyway Dave.
Kind regards
r0760589
