Slowpokee wrote:Pin 1 registered at 4.2~4.3 volts
That's higher than it should be, and could mean that the RasPi's 3.3V regulator is damaged.
Slowpokee wrote:My Kippah is missing the USB chip and connector. However, I don't know if this would interfere with the display data as that is a separate item all together.
The display and AR1100 USB touchscreen controller are independent circuits, yes. The one should have no effect on the other.
Slowpokee wrote:To me the common denominator is the Kippach card!
The Kippah firmware would be another common factor. The whole project is a fairly technical hack, and isn't guaranteed to work with versions of Raspbian other than the 2019/04/11 version of Raspbian. Are you sure you're using that OS image?
https://learn.adafruit.com/portable-kip ... stallation
