Mini USB WiFi Module and Model 1 Pi
by ntynen on Sat May 28, 2022 10:17 pm
I have a Raspberry Pi Model 1 running the latest Raspberry Pi OS (based on Bullseye).
Will the Mini USB WiFi Module work with this hardware?
Thanks,
Nicole
ntynen
Re: Mini USB WiFi Module and Model 1 Pi
by mikeysklar on Tue May 31, 2022 11:35 am
Which model of Raspberry Pi do you have? When you say model 1 does that mean the first release model from 2012? Here is a chart which might help me to confirm the device you have.
Screen Shot 2022-05-31 at 8.23.47 AM.png (140.32 KiB) Viewed 51 times
The USB port might not have enough power for the WiFi to work well. I've had to use powered USB hubs when working with some of the WiFi RTL chipsets to get them to operate at full power. Otherwise I suspect it will work fine with the OS being and earliest hardware releases of Raspberry Pi.
mikeysklar
by ntynen on Tue May 31, 2022 2:12 pm
Looks like it's the 2012 model
/proc/cpuinfo
cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2835
Revision : 000e
Serial : 00000000b48ad82e
Model : Raspberry Pi Model B Rev 2
ntynen
by mikeysklar on Wed Jun 01, 2022 5:01 pm
Thank you for confirming your model "Raspberry Pi Model B Rev 2".
That is an oldie, but a goodie.
The maximum current all USB peripherals can draw from the USB port is 600mA. By changing a value in the /boot/config.txt file, this current limit can be increased to 1.2A for all four ports.
max_usb_current=1
I mention the current draw and max USB power since this module can draw up to 120mA of current.
mikeysklar
