Pomeronic HyperPixel - 4.0" Hi-Res Display for Raspberry Pi
- Knautica
I can not get this display to work on a pi 3 pi 4 or pi 400. what is the way to make this happen? I followed the steps on get hub and on Pimoroni. what am I missing.
- dastels
Re: Pomeronic HyperPixel - 4.0" Hi-Res Display for Raspberry
I found that it took quite a bit of googling and finicky, low-level configuration work to get it working how I wanted it to. It will work very nicely once all that is done.
I assume you've worked through https://learn.pimoroni.com/article/gett ... perpixel-4 since you mentioned the Pimoroni instructions.
For the 400, how are you connecting it?
- Knautica
to a cyberdeck and just a pi 3 and 4 no results on either
- dastels
You will need to make adjustments to the JST port5s on the CyberDeck for use with the HyperPixel 4.0. See https://learn.adafruit.com/cyberdeck-bo ... -3104511-6.
Is anything else connected to the Pi 3 & 4?
- Knautica
no no thing connected to the 32 or 4!
- dastels
As I recall the Pimoroni instructions got it up and running. It took me longer as I needed it to be a landscape console display, not a GUI.
- Knautica
I spent the last four hours on the site that makes the display on a ras 3 and nothing! I’m so pissed
- dastels
Yeah, it took me a few days. It's very fiddly work. Keep at it!
- Knautica
Total junk nothing worked for these.
Adafruit 2.23" Monochrome OLED Bonnet for Raspberry Pi PID: 4567 $22.50 1 $22.50
Pimoroni HyperPixel - 4.0" Hi-Res Display for Raspberry Pi - Non-Touch
- adafruit_support_carter
Those are two different products. Setup for the OLED Bonnet is very different than the setup for the Pimoroni HyperPixel.
We can help troubleshoot the OLED, but best to focus on one thing at a time.
Is there a specific step in Pimoroni's setup instructions for the HyperPixel that did not work as shown?
- Knautica
I got the hyper pixel to work on the pi 4 and 400. Will work on the opex later
- Knautica
- Knautica
This hyper pixel 4 worked once until rebooted now it does nothing on pi 400 pi 4 or pi 3!! Totally disappointed with this product and support.
The only that happened between working and not working was a reboot?
If you start over and follow Pimoroni's guide:
you can not recreate your previous success?
- Knautica
I have followed every guy there is out there they are replacing my display because they say it’s bad also
