I recently bought one of these (Adafruit MAX98357 I2S Class-D Mono Amp) to try to make a smart speaker device. After some initial success I got it to work and it sound great but it was a little loud. For unknown reasons it stopped working, and I've been at a loss in determine the why.
However, I have 2 more on the way and would like to figure out beforehand how to control the volume that they output. The instructions at (https://learn.adafruit.com/adafruit-max ... s?view=all) have no further suggestions into how it operates. If I go to alsamixer it does not recognize the device, although it did use to play music at the time.
Any pointers? Once I get the copies I'll be able to determine if the first one is busted, so I'm more interested in learning how to lower the volume?
Controlling Volume on I2S Class-D Mono Amp
- bbx10node
Re: Controlling Volume on I2S Class-D Mono Amp
I used the same DAC+amplifier board on an ESP8266 project. There is no software volume control. However, the GAIN pin does control the volume as described in the tutorial.
- Buckler
He recently bought this nice little board to upgrade a vintage radio from 1956 with a RPI.
@JTIBAU
Software volume control is no problem, I am using Raspbian Jessie and mpd/mpc:
and add/replace these lines:
and set the mxier to software:
ALSA settings:
create config-file:
add these lines:
reboot the Pi and with mpc you can control the volume!
Problem!
When my pi is playing music (radiostream or mp3 file) it sounds loud and crispy but when I stop/start or skip to the next song there is some noise and two loud plops!!!
I am using the lastest Raspbian Jessie Lite and mpd/mpc to play the music. I have tried several setups with a B+ and a Zero an even with an ArchLinux-image (Archphile) but the same results, playing music is okay but dont try to control the music :-)
Any tips/advice to get rid of this?
Kind regards
Harry
@JTIBAU
nano /etc/mpd.conf
audio_output {
enables "yes"
type "alsa"
name "HiFiBerry"
device "hw:0,0"
auto_resample "no"
auto_channels "no"
auto_format "no"
mixer_type "software"
create config-file:
nano /etc/asound.conf
pcm.!default {
type hw card 0
ctl.!default {
type hw card 0
Problem!
Kind regards
Harry
- bbx10node
Thanks, I will try to see if I can get volume control to work.
