Adafruit DC & Stepper Motor HAT with servo
smith9
Post by smith9 »
I´m trying to control a high torque servo (http://alturn-usa.com/products/PDF/ABDS-996HTG+HV.pdf) with the Adafruit DC & Stepper Motor HAT for Raspberry.
The connection to the servo is shown in the picture:
Red: Positive
Black: Ground
Gray: Signal
Blue: 6V power supply
And here is my test code:
#!/usr/bin/python3
from Adafruit_MotorHAT.Adafruit_PWM_Servo_Driver import PWM
import time
import atexit
# create a default PWM
pwm = PWM(0x60, debug=False,i2c=None, i2c_bus=None)
pwm.setPWMFreq(50)
def turnOffAllPWM():
    pwm.setAllPWM(4095,0)
    print("Motors stopped")
atexit.register(turnOffAllPWM)
################################# PWM test!
try:
    #set Voltage
    pwm.setPWM(10, 4095,0)
    pwm.setPWM(9,0,4095)
    pwm.setPWM(8,0,4095)
    #setPWM
    position = 1.5
    if position < 1:
        position = 1.0
    elif position > 2:
        position = 2
    print(position)
    off = int(round((4096 * position / 20 )))
    pwm.setPWM(15,0, off )
    while (True):
        time.sleep(1.0)
except KeyboardInterrupt:
    turnOffAllPWM()
    print("KeyboardInterrupt")
However, the servo isn´t moving when I set different position values. Only short random movement when the signal cable is not connected. Do you have any suggestions what I have done wrong?
adafruit_support_carter
Re: Adafruit DC & Stepper Motor HAT with servo
I guess I'd expect that. Without the signal cable connected, it'll just send in noise.
In your code, I see only one position being commanded. How are you changing that?
smith9
Post by smith9 »
I change the value and restart the program. I wrote this code to test the correct connection of the servo. The servo should move to the new position and stop there.
Is the gray wire going into the PWM 15 header soldered in place?
It is possible that the 3.3v control signal from the HAT is not high enough to drive that servo. I'm not familiar with that particular model, but we have seen several high-torque servos that don't respond to signal levels much less than 5v.
smith9
Post by smith9 »
I also tried higher signal voltage by connecting the signal cable to the output 3 of the Motor Hat and adding these 3 lines to the code.
pwm.setPWM(11, 4095, 0)
pwm.setPWM(12 ,0, 4095)
pwm.setPWM(13, 0, off)
This should generate a 6V PWM signal. In the beginning, I added a voltage divider to get a 5V signal. But with or without voltage divider, the servo did not move.
If it´s not a problem with the HAT or the connection, I guess the servo is damaged.
The PWM signal voltage level is determined by the VDD of the PCA9685 chip. Since this is being driven by the Pi - which operates at 3.3v - it is running at 3.3v also.
https://cdn-learn.adafruit.com/assets/a ... 1422045515
smith9
Post by smith9 »
With output 3, I mean the BO2 output of the TB6612FNG chip. The dead time of the chip is only 230 ns ( https://www.pololu.com/file/0J86/TB6612FNG.pdf) which should be no problem with a frequency of 50 Hz.
I see now. Yea, that should give you a 6v pulse. Do you have access to a oscilloscope to see the actual output?
smith9
Post by smith9 »
No, I don´t have an oscilloscope, that would be much easier. But I used a normal voltmeter and the measured voltage equals approximately 6V * duty cycle. Also, when I connect a LED instead of the servo to the signal cable, I can barely see a rapid flickering.
That is a pretty good indication that you have a good signal. Your servo diagnosis sounds pretty likely then.
