AdafruitClassLibrary - DotStar
by seitz on Tue Sep 19, 2017 4:43 am
Hi, I'm trying to control a DotStar Strip with the AdafruitClassLibrary in Visual Studio 2017.
I've wrote a very simple program to learn how the class library works:
Two buttons, one button to turn led 2 on and one button to turn led 2 off.
It works but i have to click twice on the buttons to se a change. why?
Here the code:
namespace Seitz.Assembly.IoT.Controller
    public sealed partial class MainPage : Page
        public DotStar Strip { get; set; }
        private const int PixelNumber = 30;
        public MainPage()
            this.InitializeComponent();
            Strip = new DotStar(PixelNumber, DotStar.DOTSTAR_GBR);
        private async void MainPage_OnLoaded(object sender, RoutedEventArgs e)
            await Strip.BeginAsync();
            Strip.Clear();
            Strip.Show();
        private void On_Click(object sender, RoutedEventArgs e)
            Strip.SetPixelColor(2, 255, 0, 0);
            Strip.Show();
        private void Off_Click(object sender, RoutedEventArgs e)
            Strip.SetPixelColor(2, 0, 0, 0);
            Strip.Show();
seitz
Re: AdafruitClassLibrary - DotStar
by adafruit_support_rick on Tue Sep 19, 2017 8:53 am
Wow - I don't know. Maybe it's a problem with the on-click functions?
Have you tried stepping into the click calls? Are they getting called twice?
Alternately, you can add a couple of debug statements to the click calls to see if they're getting called twice:
[code] private void On_Click(object sender, RoutedEventArgs e)
System.Diagnostics.Debug.WriteLine(string.Format("On_Click called"));
Strip.Show();
}/code]
The Dotstar strip on my Pi is offline for a couple of days - I lent my level shifter chip to friend. I'll have another in a day or two.
Meanwhile, can you zip up your solution and post it here? I'll give it a try and see what I can figure out.
by seitz on Tue Sep 19, 2017 9:34 am
Thank you for the quick reply.
Here it is the zipped solution.
The click calls are not getting called twice... I have to click twice on the buttons...
I figured out that in order to work, I need to call the _pixelStrip.Show(); twice on the On_Click Event.
This behavior shows up when i put _pixelStrip.Clear(); in the MainPage_Loaded Event. If I comment out _pixelStrip.Clear(); from the MainPage_Loaded Event (and comment out the second _pixelStrip.Show();) then i have to click just once one the button... but i can only address the first pixel.
Very strange...
I hope I could express myself clearly ;-)
Do you have a simple example with UWP and DotStar which you can upload? This would me help a lot.
Seitz.Assembly.zip
(536.2 KiB) Downloaded 3 times
seitz
by adafruit_support_rick on Tue Sep 19, 2017 10:54 am
Just published a Dot Star demo solution:
https://github.com/adafruit/DotStarDemo
by adafruit_support_rick on Wed Sep 20, 2017 12:31 pm
Okay - I just ran your app, and it works for me. No need to double-click, no need to call _pixelStrip.Show twice.
I don't know why it's not working for you, but it does not seem to be a problem with the DotStar class
by seitz on Wed Sep 20, 2017 12:38 pm
Did you notice that in my app i call the _pixelStrip.Show() twice in row?
What happens on your System if you comment out one _pixelStrip.Show()?
seitz
by adafruit_support_rick on Wed Sep 20, 2017 3:12 pm
Yes, I know. As I said, I don't have to call show twice.
