I'm not able to get wifi working on my pi zero w. I've tried multiple images. The latest thing I tried was Raspbian Stretch Lite from here : https://www.raspberrypi.org/downloads/raspbian/
For power supply, I'm using https://www.adafruit.com/product/501
The ifconfig -a only lists the loopback address and just does not list wlan0.
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.41+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1023 Tue Aug 8 15:47:12 BST 2017
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x17400000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 98304
[ 0.000000] free_area_init_node: node 0, pgdat c09168d4, node_mem_map d7c8be00
[ 0.000000] Normal zone: 864 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 98304 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97440
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1200 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:08:CF:44 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=c855574e-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 370972K/393216K available (5949K kernel code, 489K rwdata, 1952K rodata, 400K init, 734K bss, 14052K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xd8800000 - 0xff800000 ( 624 MB)
lowmem : 0xc0000000 - 0xd8000000 ( 384 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc05d78dc (5951 kB)
.init : 0xc0842000 - 0xc08a6000 ( 400 kB)
.data : 0xc08a6000 - 0xc0920788 ( 490 kB)
.bss : 0xc0920788 - 0xc09d7f88 ( 734 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000030] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000077] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000174] bcm2835: system timer (irq = 27)
[ 0.000646] Console: colour dummy device 80x30
[ 0.001421] console [tty1] enabled
[ 0.001477] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060351] pid_max: default: 32768 minimum: 301
[ 0.060818] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060888] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.062001] Disabling cpuset control group subsystem
[ 0.062281] CPU: Testing write buffer coherency: ok
[ 0.062387] ftrace: allocating 21719 entries in 64 pages
[ 0.179121] Setting up static identity map for 0x8200 - 0x8238
[ 0.181173] devtmpfs: initialized
[ 0.190314] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.190827] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.190928] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.192255] pinctrl core: initialized pinctrl subsystem
[ 0.193764] NET: Registered protocol family 16
[ 0.196245] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.206087] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.206181] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.206322] Serial: AMBA PL011 UART driver
[ 0.209273] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.210087] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.258794] bcm2835-dma 20007000.dma: DMA legacy API manager at d880d000, dmachans=0x1
[ 0.261661] SCSI subsystem initialized
[ 0.261992] usbcore: registered new interface driver usbfs
[ 0.262166] usbcore: registered new interface driver hub
[ 0.262403] usbcore: registered new device driver usb
[ 0.269184] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-08-08 12:05
[ 0.271124] clocksource: Switched to clocksource timer
[ 0.325098] VFS: Disk quotas dquot_6.6.0
[ 0.325295] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.325655] FS-Cache: Loaded
[ 0.326044] CacheFiles: Loaded
[ 0.345466] NET: Registered protocol family 2
[ 0.346869] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.347028] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.347160] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.347297] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.347364] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.347718] NET: Registered protocol family 1
[ 0.348522] RPC: Registered named UNIX socket transport module.
[ 0.348599] RPC: Registered udp transport module.
[ 0.348637] RPC: Registered tcp transport module.
[ 0.348672] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.349834] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.352464] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.372866] FS-Cache: Netfs 'nfs' registered for caching
[ 0.374670] NFS: Registering the id_resolver key type
[ 0.374780] Key type id_resolver registered
[ 0.374822] Key type id_legacy registered
[ 0.379335] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.379803] io scheduler noop registered
[ 0.379868] io scheduler deadline registered (default)
[ 0.380368] io scheduler cfq registered
[ 0.386463] BCM2708FB: allocated DMA memory 57500000
[ 0.386594] BCM2708FB: allocated DMA channel 0 @ d880d000
[ 0.444331] Console: switching to colour frame buffer device 240x75
[ 0.493256] bcm2835-rng 20104000.rng: hwrng registered
[ 0.493637] vc-cma: Videocore CMA driver
[ 0.493821] vc-cma: vc_cma_base = 0x00000000
[ 0.494018] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.494227] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.494901] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 0.524858] brd: module loaded
[ 0.539409] loop: module loaded
[ 0.539621] Loading iSCSI transport class v2.0-870.
[ 0.540920] usbcore: registered new interface driver smsc95xx
[ 0.541326] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.770105] Core Release: 2.80a
[ 0.770305] Setting default values for core params
[ 0.770546] Finished setting default values for core params
[ 0.971343] Using Buffer DMA mode
[ 0.971532] Periodic Transfer Interrupt Enhancement - disabled
[ 0.971764] Multiprocessor Interrupt Enhancement - disabled
[ 0.971988] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.972261] Dedicated Tx FIFOs mode
[ 0.973190] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xd7514000 dma = 0x57514000 len=9024
[ 0.973609] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.974391] dwc_otg: Microframe scheduler enabled
[ 0.974518] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04519f4
[ 0.974770] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451cd0 length 36
[ 0.975031] WARN::hcd_init_fiq:486: MPHI regs_base at 0xd88a5000
[ 0.975355] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.975629] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.976036] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 0.976318] Init: Port Power? op_state=1
[ 0.976486] Init: Power Port (0)
[ 0.977022] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.977264] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.977535] usb usb1: Product: DWC OTG Controller
[ 0.977735] usb usb1: Manufacturer: Linux 4.9.41+ dwc_otg_hcd
[ 0.977964] usb usb1: SerialNumber: 20980000.usb
[ 0.979504] hub 1-0:1.0: USB hub found
[ 0.979809] hub 1-0:1.0: 1 port detected
[ 0.992203] dwc_otg: FIQ enabled
[ 0.992216] dwc_otg: NAK holdoff enabled
[ 0.992224] dwc_otg: FIQ split-transaction FSM enabled
[ 0.992247] Module dwc_common_port init
[ 0.992865] usbcore: registered new interface driver usb-storage
[ 1.004670] mousedev: PS/2 mouse device common for all mice
[ 1.017757] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[ 1.029715] bcm2835-cpufreq: min=700000 max=1000000
[ 1.041846] sdhci: Secure Digital Host Controller Interface driver
[ 1.053056] sdhci: Copyright(c) Pierre Ossman
[ 1.064651] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
[ 1.078690] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
[ 1.090345] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.102521] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.114041] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.125662] usbcore: registered new interface driver usbhid
[ 1.136905] usbhid: USB HID core driver
[ 1.149672] vchiq: vchiq_init_state: slot_zero = 0xd7580000, is_master = 0
[ 1.164139] Initializing XFRM netlink socket
[ 1.177116] NET: Registered protocol family 17
[ 1.188746] Key type dns_resolver registered
[ 1.202222] registered taskstats version 1
[ 1.213778] Indeed it is in host mode hprt0 = 00041901
[ 1.285741] vc-sm: Videocore shared memory driver
[ 1.297125] [vc_sm_connected_init]: start
[ 1.309749] [vc_sm_connected_init]: end - returning 0
[ 1.331494] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 1.345951] sdhost: log_buf @ d7513000 (57513000)
[ 1.424141] random: fast init done
[ 1.435626] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.449808] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.461376] mmc-bcm2835 20300000.mmc: DMA channel allocated
[ 1.472951] usb 1-1: new low-speed USB device number 2 using dwc_otg
[ 1.505201] Indeed it is in host mode hprt0 = 00041901
[ 1.631427] of_cfs_init
[ 1.646949] of_cfs_init: OK
[ 1.666069] Waiting for root device PARTUUID=c855574e-02...
[ 1.703259] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.721723] mmc0: new high speed SDHC card at address e624
[ 1.734932] mmcblk0: mmc0:e624 SS16G 14.8 GiB
[ 1.761959] usb 1-1: New USB device found, idVendor=046d, idProduct=c31d
[ 1.775984] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.787693] usb 1-1: Product: USB Keyboard
[ 1.799291] usb 1-1: Manufacturer: Logitech
[ 1.827372] mmcblk0: p1 p2
[ 1.848993] input: Logitech USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:046D:C31D.0001/input/input0
[ 1.932831] hid-generic 0003:046D:C31D.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-20980000.usb-1/input0
[ 1.964576] input: Logitech USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.1/0003:046D:C31D.0002/input/input1
[ 2.041774] hid-generic 0003:046D:C31D.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-20980000.usb-1/input1
[ 2.166805] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.179635] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.273965] EXT4-fs (mmcblk0p2): recovery complete
[ 2.292231] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.305051] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.330458] devtmpfs: mounted
[ 2.344728] Freeing unused kernel memory: 400K (c0842000 - c08a6000)
[ 2.357374] This architecture does not have kernel memory protection.
[ 2.890902] systemd[1]: System time before build time, advancing clock.
[ 3.042236] NET: Registered protocol family 10
[ 3.083632] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.137969] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +BANNED +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 3.153291] systemd[1]: Detected architecture arm.
[ 3.219326] systemd[1]: Set hostname to <raspberrypi>.
[ 4.414766] systemd[1]: Listening on Syslog Socket.
[ 4.445903] systemd[1]: Listening on udev Control Socket.
[ 4.507542] systemd[1]: Created slice System Slice.
[ 4.544289] systemd[1]: Mounting RPC Pipe File System...
[ 4.603153] systemd[1]: Reached target Swap.
[ 4.643683] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.683675] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.498237] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 8.702469] systemd-journald[107]: Received request to flush runtime journal from PID 1
[ 11.182673] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 17.071758] uart-pl011 20201000.serial: no DMA platform data
[ 18.647308] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 21.561234] Bluetooth: Core ver 2.22
[ 21.561402] NET: Registered protocol family 31
[ 21.561412] Bluetooth: HCI device and connection manager initialized
[ 21.561440] Bluetooth: HCI socket layer initialized
[ 21.561455] Bluetooth: L2CAP socket layer initialized
[ 21.561501] Bluetooth: SCO socket layer initialized
[ 21.577307] Bluetooth: HCI UART driver ver 2.3
[ 21.577322] Bluetooth: HCI UART protocol H4 registered
[ 21.577326] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 21.577484] Bluetooth: HCI UART protocol Broadcom registered
[ 22.096035] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.096049] Bluetooth: BNEP filters: protocol multicast
[ 22.096081] Bluetooth: BNEP socket layer initialized
[ 66.938217] random: crng init done
-- Logs begin at Thu 2017-09-07 16:25:01 UTC, end at Thu 2017-09-07 16:26:57 UTC. --
Sep 07 16:25:01 raspberrypi kernel: Booting Linux on physical CPU 0x0
Sep 07 16:25:01 raspberrypi kernel: Linux version 4.9.41+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1023 Tue Aug 8 15:47:12 BST 2017
Sep 07 16:25:01 raspberrypi kernel: CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Sep 07 16:25:01 raspberrypi kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Sep 07 16:25:01 raspberrypi kernel: OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Sep 07 16:25:01 raspberrypi kernel: cma: Reserved 8 MiB at 0x17400000
Sep 07 16:25:01 raspberrypi kernel: Memory policy: Data cache writeback
Sep 07 16:25:01 raspberrypi kernel: On node 0 totalpages: 98304
Sep 07 16:25:01 raspberrypi kernel: free_area_init_node: node 0, pgdat c09168d4, node_mem_map d7c8be00
Sep 07 16:25:01 raspberrypi kernel: Normal zone: 864 pages used for memmap
Sep 07 16:25:01 raspberrypi kernel: Normal zone: 0 pages reserved
Sep 07 16:25:01 raspberrypi kernel: Normal zone: 98304 pages, LIFO batch:31
Sep 07 16:25:01 raspberrypi kernel: pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Sep 07 16:25:01 raspberrypi kernel: pcpu-alloc: [0] 0
Sep 07 16:25:01 raspberrypi kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97440
Sep 07 16:25:01 raspberrypi kernel: Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1200 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:08:CF:44 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=c855574e-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Sep 07 16:25:01 raspberrypi kernel: PID hash table entries: 2048 (order: 1, 8192 bytes)
Sep 07 16:25:01 raspberrypi kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Sep 07 16:25:01 raspberrypi kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Sep 07 16:25:01 raspberrypi kernel: Memory: 370972K/393216K available (5949K kernel code, 489K rwdata, 1952K rodata, 400K init, 734K bss, 14052K reserved, 8192K cma-reserved)
Sep 07 16:25:01 raspberrypi kernel: Virtual kernel memory layout:
Sep 07 16:25:01 raspberrypi kernel: SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Sep 07 16:25:01 raspberrypi kernel: NR_IRQS:16 nr_irqs:16 16
Sep 07 16:25:01 raspberrypi kernel: sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Sep 07 16:25:01 raspberrypi kernel: clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Sep 07 16:25:01 raspberrypi kernel: bcm2835: system timer (irq = 27)
Sep 07 16:25:01 raspberrypi kernel: Console: colour dummy device 80x30
Sep 07 16:25:01 raspberrypi kernel: console [tty1] enabled
Sep 07 16:25:01 raspberrypi kernel: Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Sep 07 16:25:01 raspberrypi kernel: pid_max: default: 32768 minimum: 301
Sep 07 16:25:01 raspberrypi kernel: Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Sep 07 16:25:01 raspberrypi kernel: Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Sep 07 16:25:01 raspberrypi kernel: Disabling cpuset control group subsystem
Sep 07 16:25:01 raspberrypi kernel: CPU: Testing write buffer coherency: ok
Sep 07 16:25:01 raspberrypi kernel: ftrace: allocating 21719 entries in 64 pages
Sep 07 16:25:01 raspberrypi kernel: Setting up static identity map for 0x8200 - 0x8238
Sep 07 16:25:01 raspberrypi kernel: devtmpfs: initialized
Sep 07 16:25:01 raspberrypi kernel: VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Sep 07 16:25:01 raspberrypi kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Sep 07 16:25:01 raspberrypi kernel: futex hash table entries: 256 (order: -1, 3072 bytes)
Sep 07 16:25:01 raspberrypi kernel: pinctrl core: initialized pinctrl subsystem
Sep 07 16:25:01 raspberrypi kernel: NET: Registered protocol family 16
Sep 07 16:25:01 raspberrypi kernel: DMA: preallocated 1024 KiB pool for atomic coherent allocations
Sep 07 16:25:01 raspberrypi kernel: hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Sep 07 16:25:01 raspberrypi kernel: hw-breakpoint: maximum watchpoint size is 4 bytes.
Sep 07 16:25:01 raspberrypi kernel: Serial: AMBA PL011 UART driver
Sep 07 16:25:01 raspberrypi kernel: bcm2835-mbox 2000b880.mailbox: mailbox enabled
Sep 07 16:25:01 raspberrypi kernel: uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Sep 07 16:25:01 raspberrypi kernel: bcm2835-dma 20007000.dma: DMA legacy API manager at d880d000, dmachans=0x1
Sep 07 16:25:01 raspberrypi kernel: SCSI subsystem initialized
Sep 07 16:25:01 raspberrypi kernel: usbcore: registered new interface driver usbfs
Sep 07 16:25:01 raspberrypi kernel: usbcore: registered new interface driver hub
Sep 07 16:25:01 raspberrypi kernel: usbcore: registered new device driver usb
Sep 07 16:25:01 raspberrypi kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2017-08-08 12:05
Sep 07 16:25:01 raspberrypi kernel: clocksource: Switched to clocksource timer
Sep 07 16:25:01 raspberrypi kernel: VFS: Disk quotas dquot_6.6.0
Sep 07 16:25:01 raspberrypi kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Sep 07 16:25:01 raspberrypi kernel: FS-Cache: Loaded
Sep 07 16:25:01 raspberrypi kernel: CacheFiles: Loaded
Sep 07 16:25:01 raspberrypi kernel: NET: Registered protocol family 2
Sep 07 16:25:01 raspberrypi kernel: TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Sep 07 16:25:01 raspberrypi kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Sep 07 16:25:01 raspberrypi kernel: TCP: Hash tables configured (established 4096 bind 4096)
Sep 07 16:25:01 raspberrypi kernel: UDP hash table entries: 256 (order: 0, 4096 bytes)
Sep 07 16:25:01 raspberrypi kernel: UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Sep 07 16:25:01 raspberrypi kernel: RPC: Registered named UNIX socket transport module.
Sep 07 16:25:01 raspberrypi kernel: RPC: Registered udp transport module.
Sep 07 16:25:01 raspberrypi kernel: RPC: Registered tcp transport module.
Sep 07 16:25:01 raspberrypi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Sep 07 16:25:01 raspberrypi kernel: hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Sep 07 16:25:01 raspberrypi kernel: workingset: timestamp_bits=14 max_order=17 bucket_order=3
Sep 07 16:25:01 raspberrypi kernel: FS-Cache: Netfs 'nfs' registered for caching
Sep 07 16:25:01 raspberrypi kernel: NFS: Registering the id_resolver key type
Sep 07 16:25:01 raspberrypi kernel: Key type id_resolver registered
Sep 07 16:25:01 raspberrypi kernel: Key type id_legacy registered
Sep 07 16:25:01 raspberrypi kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Sep 07 16:25:01 raspberrypi kernel: io scheduler noop registered
Sep 07 16:25:01 raspberrypi kernel: io scheduler deadline registered (default)
Sep 07 16:25:01 raspberrypi kernel: io scheduler cfq registered
Sep 07 16:25:01 raspberrypi kernel: BCM2708FB: allocated DMA memory 57500000
Sep 07 16:25:01 raspberrypi kernel: BCM2708FB: allocated DMA channel 0 @ d880d000
Sep 07 16:25:01 raspberrypi kernel: Console: switching to colour frame buffer device 240x75
Sep 07 16:25:01 raspberrypi kernel: bcm2835-rng 20104000.rng: hwrng registered
Sep 07 16:25:01 raspberrypi kernel: vc-cma: Videocore CMA driver
Sep 07 16:25:01 raspberrypi kernel: vc-cma: vc_cma_base = 0x00000000
Sep 07 16:25:01 raspberrypi kernel: vc-cma: vc_cma_size = 0x00000000 (0 MiB)
Sep 07 16:25:01 raspberrypi kernel: vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
Sep 07 16:25:01 raspberrypi kernel: vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Sep 07 16:25:01 raspberrypi kernel: brd: module loaded
Sep 07 16:25:01 raspberrypi kernel: loop: module loaded
Sep 07 16:25:01 raspberrypi kernel: Loading iSCSI transport class v2.0-870.
Sep 07 16:25:01 raspberrypi kernel: usbcore: registered new interface driver smsc95xx
Sep 07 16:25:01 raspberrypi kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Sep 07 16:25:01 raspberrypi kernel: Core Release: 2.80a
Sep 07 16:25:01 raspberrypi kernel: Setting default values for core params
Sep 07 16:25:01 raspberrypi kernel: Finished setting default values for core params
Sep 07 16:25:01 raspberrypi kernel: Using Buffer DMA mode
Sep 07 16:25:01 raspberrypi kernel: Periodic Transfer Interrupt Enhancement - disabled
Sep 07 16:25:01 raspberrypi kernel: Multiprocessor Interrupt Enhancement - disabled
Sep 07 16:25:01 raspberrypi kernel: OTG VER PARAM: 0, OTG VER FLAG: 0
Sep 07 16:25:01 raspberrypi kernel: Dedicated Tx FIFOs mode
Sep 07 16:25:01 raspberrypi kernel: WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xd7514000 dma = 0x57514000 len=9024
Sep 07 16:25:01 raspberrypi kernel: FIQ FSM acceleration enabled for :
Sep 07 16:25:01 raspberrypi kernel: dwc_otg: Microframe scheduler enabled
Sep 07 16:25:01 raspberrypi kernel: WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04519f4
Sep 07 16:25:01 raspberrypi kernel: WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451cd0 length 36
Sep 07 16:25:01 raspberrypi kernel: WARN::hcd_init_fiq:486: MPHI regs_base at 0xd88a5000
Sep 07 16:25:01 raspberrypi kernel: dwc_otg 20980000.usb: DWC OTG Controller
Sep 07 16:25:01 raspberrypi kernel: dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Sep 07 16:25:01 raspberrypi kernel: dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Sep 07 16:25:01 raspberrypi kernel: Init: Port Power? op_state=1
Sep 07 16:25:01 raspberrypi kernel: Init: Power Port (0)
Sep 07 16:25:01 raspberrypi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Sep 07 16:25:01 raspberrypi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 07 16:25:01 raspberrypi kernel: usb usb1: Product: DWC OTG Controller
Sep 07 16:25:01 raspberrypi kernel: usb usb1: Manufacturer: Linux 4.9.41+ dwc_otg_hcd
Sep 07 16:25:01 raspberrypi kernel: usb usb1: SerialNumber: 20980000.usb
Sep 07 16:25:01 raspberrypi kernel: hub 1-0:1.0: USB hub found
Sep 07 16:25:01 raspberrypi kernel: hub 1-0:1.0: 1 port detected
Sep 07 16:25:01 raspberrypi kernel: dwc_otg: FIQ enabled
Sep 07 16:25:01 raspberrypi kernel: dwc_otg: NAK holdoff enabled
Sep 07 16:25:01 raspberrypi kernel: dwc_otg: FIQ split-transaction FSM enabled
Sep 07 16:25:01 raspberrypi kernel: Module dwc_common_port init
Sep 07 16:25:01 raspberrypi kernel: usbcore: registered new interface driver usb-storage
Sep 07 16:25:01 raspberrypi kernel: mousedev: PS/2 mouse device common for all mice
Sep 07 16:25:01 raspberrypi kernel: bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Sep 07 16:25:01 raspberrypi kernel: bcm2835-cpufreq: min=700000 max=1000000
Sep 07 16:25:01 raspberrypi kernel: sdhci: Secure Digital Host Controller Interface driver
Sep 07 16:25:01 raspberrypi kernel: sdhci: Copyright(c) Pierre Ossman
Sep 07 16:25:01 raspberrypi kernel: sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
Sep 07 16:25:01 raspberrypi kernel: mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Sep 07 16:25:01 raspberrypi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Sep 07 16:25:01 raspberrypi kernel: ledtrig-cpu: registered to indicate activity on CPUs
Sep 07 16:25:01 raspberrypi kernel: hidraw: raw HID events driver (C) Jiri Kosina
Sep 07 16:25:01 raspberrypi kernel: usbcore: registered new interface driver usbhid
Sep 07 16:25:01 raspberrypi kernel: usbhid: USB HID core driver
Sep 07 16:25:01 raspberrypi kernel: vchiq: vchiq_init_state: slot_zero = 0xd7580000, is_master = 0
Sep 07 16:25:01 raspberrypi kernel: Initializing XFRM netlink socket
Sep 07 16:25:01 raspberrypi kernel: NET: Registered protocol family 17
Sep 07 16:25:01 raspberrypi kernel: Key type dns_resolver registered
Sep 07 16:25:01 raspberrypi kernel: registered taskstats version 1
Sep 07 16:25:01 raspberrypi kernel: Indeed it is in host mode hprt0 = 00041901
Sep 07 16:25:01 raspberrypi kernel: vc-sm: Videocore shared memory driver
Sep 07 16:25:01 raspberrypi kernel: [vc_sm_connected_init]: start
Sep 07 16:25:01 raspberrypi kernel: [vc_sm_connected_init]: end - returning 0
Sep 07 16:25:01 raspberrypi kernel: 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Sep 07 16:25:01 raspberrypi kernel: sdhost: log_buf @ d7513000 (57513000)
Sep 07 16:25:01 raspberrypi kernel: random: fast init done
Sep 07 16:25:01 raspberrypi kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Sep 07 16:25:01 raspberrypi kernel: mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Sep 07 16:25:01 raspberrypi kernel: mmc-bcm2835 20300000.mmc: DMA channel allocated
Sep 07 16:25:01 raspberrypi kernel: usb 1-1: new low-speed USB device number 2 using dwc_otg
Sep 07 16:25:01 raspberrypi kernel: of_cfs_init
Sep 07 16:25:01 raspberrypi kernel: of_cfs_init: OK
Sep 07 16:25:01 raspberrypi kernel: Waiting for root device PARTUUID=c855574e-02...
Sep 07 16:25:01 raspberrypi kernel: mmc0: host does not support reading read-only switch, assuming write-enable
Sep 07 16:25:01 raspberrypi kernel: mmc0: new high speed SDHC card at address e624
Sep 07 16:25:01 raspberrypi kernel: mmcblk0: mmc0:e624 SS16G 14.8 GiB
Sep 07 16:25:02 raspberrypi kernel: usb 1-1: New USB device found, idVendor=046d, idProduct=c31d
Sep 07 16:25:02 raspberrypi kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 07 16:25:02 raspberrypi kernel: usb 1-1: Product: USB Keyboard
Sep 07 16:25:02 raspberrypi kernel: usb 1-1: Manufacturer: Logitech
Sep 07 16:25:02 raspberrypi kernel: mmcblk0: p1 p2
Sep 07 16:25:02 raspberrypi kernel: input: Logitech USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:046D:C31D.0001/input/input0
Sep 07 16:25:02 raspberrypi kernel: hid-generic 0003:046D:C31D.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-20980000.usb-1/input0
Sep 07 16:25:02 raspberrypi kernel: input: Logitech USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.1/0003:046D:C31D.0002/input/input1
Sep 07 16:25:02 raspberrypi kernel: hid-generic 0003:046D:C31D.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-20980000.usb-1/input1
Sep 07 16:25:02 raspberrypi kernel: EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Sep 07 16:25:02 raspberrypi kernel: EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Sep 07 16:25:02 raspberrypi kernel: EXT4-fs (mmcblk0p2): recovery complete
Sep 07 16:25:02 raspberrypi kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Sep 07 16:25:02 raspberrypi kernel: VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Sep 07 16:25:02 raspberrypi kernel: devtmpfs: mounted
Sep 07 16:25:02 raspberrypi kernel: Freeing unused kernel memory: 400K (c0842000 - c08a6000)
Sep 07 16:25:02 raspberrypi kernel: This architecture does not have kernel memory protection.
Sep 07 16:25:02 raspberrypi systemd[1]: System time before build time, advancing clock.
Sep 07 16:25:02 raspberrypi kernel: NET: Registered protocol family 10
Sep 07 16:25:02 raspberrypi kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Sep 07 16:25:02 raspberrypi systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +BANNED +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
Sep 07 16:25:02 raspberrypi systemd[1]: Detected architecture arm.
Sep 07 16:25:02 raspberrypi systemd[1]: Set hostname to <raspberrypi>.
Sep 07 16:25:02 raspberrypi systemd[1]: Listening on Syslog Socket.
Sep 07 16:25:02 raspberrypi systemd[1]: Listening on udev Control Socket.
Sep 07 16:25:02 raspberrypi systemd[1]: Created slice System Slice.
Sep 07 16:25:02 raspberrypi systemd[1]: Mounting RPC Pipe File System...
Sep 07 16:25:02 raspberrypi systemd[1]: Reached target Swap.
Sep 07 16:25:02 raspberrypi systemd[1]: Created slice system-systemd\x2dfsck.slice.
Sep 07 16:25:02 raspberrypi systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Sep 07 16:25:02 raspberrypi systemd-journald[107]: Journal started
Sep 07 16:25:02 raspberrypi systemd-journald[107]: Runtime journal (/run/log/journal/c968b7b125ee405ebd6b42a6ebd1643c) is 2.3M, max 18.5M, 16.2M free.
Sep 07 16:25:02 raspberrypi fake-hwclock[93]: Thu 7 Sep 16:25:01 UTC 2017
Sep 07 16:25:02 raspberrypi systemd-fsck[102]: e2fsck 1.43.4 (31-Jan-2017)
Sep 07 16:25:02 raspberrypi systemd-fsck[102]: Superblock last mount time is in the future.
Sep 07 16:25:02 raspberrypi systemd-fsck[102]: (by less than a day, probably due to the hardware clock being incorrectly set)
Sep 07 16:25:02 raspberrypi systemd-fsck[102]: /dev/mmcblk0p2: clean, 39360/938672 files, 347306/3877760 blocks
Sep 07 16:25:03 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Sep 07 16:25:03 raspberrypi kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Sep 07 16:25:03 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Sep 07 16:25:03 raspberrypi systemd[1]: Started Apply Kernel Variables.
Sep 07 16:25:03 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
Sep 07 16:25:03 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Sep 07 16:25:03 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Sep 07 16:25:03 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Sep 07 16:25:03 raspberrypi systemd[1]: Started Load/Save Random Seed.
Sep 07 16:25:04 raspberrypi systemd-journald[107]: Runtime journal (/run/log/journal/c968b7b125ee405ebd6b42a6ebd1643c) is 2.3M, max 18.5M, 16.2M free.
Sep 07 16:25:04 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Sep 07 16:25:04 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Sep 07 16:25:04 raspberrypi systemd[1]: Started Set the console keyboard layout.
Sep 07 16:25:04 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Sep 07 16:25:05 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Sep 07 16:25:05 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Sep 07 16:25:05 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 146 (plymouthd).
Sep 07 16:25:05 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Sep 07 16:25:05 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Sep 07 16:25:05 raspberrypi systemd[1]: Reached target Encrypted Volumes.
Sep 07 16:25:05 raspberrypi systemd[1]: Reached target Paths.
Sep 07 16:25:06 raspberrypi kernel: gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Sep 07 16:25:06 raspberrypi systemd[1]: Found device /dev/serial1.
Sep 07 16:25:07 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/c855574e-01.
Sep 07 16:25:07 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/c855574e-01...
Sep 07 16:25:07 raspberrypi mtp-probe[168]: checking bus 1, device 2: "/sys/devices/platform/soc/20980000.usb/usb1/1-1"
Sep 07 16:25:07 raspberrypi mtp-probe[168]: bus: 1, device: 2 was not an MTP device
Sep 07 16:25:08 raspberrypi systemd-fsck[170]: fsck.fat 4.1 (2017-01-24)
Sep 07 16:25:08 raspberrypi systemd-fsck[170]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Sep 07 16:25:08 raspberrypi systemd-fsck[170]: Automatically removing dirty bit.
Sep 07 16:25:08 raspberrypi systemd-fsck[170]: Performing changes.
Sep 07 16:25:08 raspberrypi systemd-fsck[170]: /dev/mmcblk0p1: 144 files, 42944/84272 clusters
Sep 07 16:25:08 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/c855574e-01.
Sep 07 16:25:08 raspberrypi systemd[1]: Mounting /boot...
Sep 07 16:25:08 raspberrypi systemd[1]: Mounted /boot.
Sep 07 16:25:08 raspberrypi systemd[1]: Reached target Local File Systems.
Sep 07 16:25:08 raspberrypi systemd[1]: Starting Raise network interfaces...
Sep 07 16:25:08 raspberrypi systemd[1]: Starting Set console font and keymap...
Sep 07 16:25:08 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Sep 07 16:25:08 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Sep 07 16:25:08 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Sep 07 16:25:08 raspberrypi systemd[1]: Started Set console font and keymap.
Sep 07 16:25:09 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Sep 07 16:25:09 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Sep 07 16:25:09 raspberrypi systemd[1]: Reached target NFS client services.
Sep 07 16:25:09 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Sep 07 16:25:09 raspberrypi systemd[1]: Reached target Remote File Systems.
Sep 07 16:25:09 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Sep 07 16:25:09 raspberrypi systemd[1]: Starting Network Time Synchronization...
Sep 07 16:25:09 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Sep 07 16:25:10 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Sep 07 16:25:10 raspberrypi systemd[1]: Started Network Time Synchronization.
Sep 07 16:25:10 raspberrypi systemd[1]: Reached target System Initialization.
Sep 07 16:25:10 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Sep 07 16:25:10 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Sep 07 16:25:10 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Sep 07 16:25:10 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Sep 07 16:25:10 raspberrypi systemd[1]: Reached target Sockets.
Sep 07 16:25:10 raspberrypi systemd[1]: Reached target Basic System.
Sep 07 16:25:10 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Sep 07 16:25:10 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Sep 07 16:25:10 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Sep 07 16:25:10 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
Sep 07 16:25:10 raspberrypi thd[200]: Found socket passed from systemd
Sep 07 16:25:10 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Sep 07 16:25:10 raspberrypi avahi-daemon[199]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Sep 07 16:25:10 raspberrypi avahi-daemon[199]: Successfully dropped root privileges.
Sep 07 16:25:10 raspberrypi avahi-daemon[199]: avahi-daemon 0.6.32 starting up.
Sep 07 16:25:11 raspberrypi systemd[1]: Started Regular background program processing daemon.
Sep 07 16:25:11 raspberrypi systemd[1]: Starting System Logging Service...
Sep 07 16:25:11 raspberrypi cron[206]: (CRON) INFO (pidfile fd = 3)
Sep 07 16:25:11 raspberrypi systemd[1]: Starting Login Service...
Sep 07 16:25:11 raspberrypi cron[206]: (CRON) INFO (Running @reboot jobs)
Sep 07 16:25:11 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Sep 07 16:25:11 raspberrypi dhcpcd[201]: no valid interfaces found
Sep 07 16:25:11 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Sep 07 16:25:11 raspberrypi liblogging-stdlog[209]: [origin software="rsyslogd" swVersion="8.24.0" x-pid="209" x-info="http://www.rsyslog.com"] start
Sep 07 16:25:11 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Sep 07 16:25:12 raspberrypi avahi-daemon[199]: Successfully called chroot().
Sep 07 16:25:12 raspberrypi avahi-daemon[199]: Successfully dropped remaining capabilities.
Sep 07 16:25:12 raspberrypi avahi-daemon[199]: No service file found in /etc/avahi/services.
Sep 07 16:25:12 raspberrypi avahi-daemon[199]: Network interface enumeration completed.
Sep 07 16:25:12 raspberrypi avahi-daemon[199]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 1811149699.
Sep 07 16:25:12 raspberrypi dbus[220]: [system] Successfully activated service 'org.freedesktop.systemd1'
Sep 07 16:25:12 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Sep 07 16:25:12 raspberrypi systemd[1]: Starting WPA supplicant...
Sep 07 16:25:12 raspberrypi kernel: uart-pl011 20201000.serial: no DMA platform data
Sep 07 16:25:12 raspberrypi systemd[1]: Reached target System Time Synchronized.
Sep 07 16:25:12 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Sep 07 16:25:12 raspberrypi systemd[1]: Started System Logging Service.
Sep 07 16:25:12 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
Sep 07 16:25:13 raspberrypi wpa_supplicant[243]: Successfully initialized wpa_supplicant
Sep 07 16:25:13 raspberrypi systemd-logind[213]: New seat seat0.
Sep 07 16:25:13 raspberrypi dphys-swapfile[205]: Starting dphys-swapfile swapfile setup ...
Sep 07 16:25:13 raspberrypi systemd[1]: Started WPA supplicant.
Sep 07 16:25:13 raspberrypi systemd[1]: Started Login Service.
Sep 07 16:25:13 raspberrypi dphys-swapfile[205]: want /var/swap=100MByte, checking existing: keeping it
Sep 07 16:25:14 raspberrypi kernel: Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
Sep 07 16:25:14 raspberrypi dphys-swapfile[205]: done.
Sep 07 16:25:14 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Sep 07 16:25:14 raspberrypi raspi-config[214]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
Sep 07 16:25:14 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Sep 07 16:25:14 raspberrypi systemd[1]: Reached target Sound Card.
Sep 07 16:25:14 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Sep 07 16:25:15 raspberrypi systemd-udevd[139]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Sep 07 16:25:15 raspberrypi systemd-udevd[143]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Sep 07 16:25:15 raspberrypi systemd-udevd[139]: Process '/sbin/crda' failed with exit code 249.
Sep 07 16:25:15 raspberrypi wpa_supplicant[325]: Successfully initialized wpa_supplicant
Sep 07 16:25:16 raspberrypi wpa_supplicant[325]: Could not read interface wlan0 flags: No such device
Sep 07 16:25:16 raspberrypi wpa_supplicant[325]: nl80211: Driver does not support authentication/association or connect commands
Sep 07 16:25:16 raspberrypi wpa_supplicant[325]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Sep 07 16:25:16 raspberrypi wpa_supplicant[325]: WEXT: Could not set interface 'wlan0' UP
Sep 07 16:25:16 raspberrypi wpa_supplicant[325]: wlan0: Failed to initialize driver interface
Sep 07 16:25:16 raspberrypi ifup[280]: /etc/network/if-pre-up.d/wpasupplicant: 120: /etc/network/if-pre-up.d/wpasupplicant: cannot create /dev/stderr: No such device or address
Sep 07 16:25:16 raspberrypi ifup[280]: run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Sep 07 16:25:16 raspberrypi ifup[280]: ifup: failed to bring up wlan0
Sep 07 16:25:16 raspberrypi systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
Sep 07 16:25:16 raspberrypi systemd[1]: Failed to start Raise network interfaces.
Sep 07 16:25:16 raspberrypi systemd[1]: networking.service: Unit entered failed state.
Sep 07 16:25:16 raspberrypi systemd[1]: networking.service: Failed with result 'exit-code'.
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: Core ver 2.22
Sep 07 16:25:17 raspberrypi kernel: NET: Registered protocol family 31
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: HCI device and connection manager initialized
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: HCI socket layer initialized
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: L2CAP socket layer initialized
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: SCO socket layer initialized
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: HCI UART driver ver 2.3
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: HCI UART protocol H4 registered
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: HCI UART protocol Broadcom registered
Sep 07 16:25:17 raspberrypi btuart[216]: bcm43xx_init
Sep 07 16:25:17 raspberrypi btuart[216]: Flash firmware /lib/firmware/BCM43430A1.hcd
Sep 07 16:25:17 raspberrypi btuart[216]: Set BDADDR UART: b8:27:eb:a2:65:ee
Sep 07 16:25:17 raspberrypi btuart[216]: Set Controller UART speed to 3000000 bit/s
Sep 07 16:25:17 raspberrypi btuart[216]: Device setup complete
Sep 07 16:25:17 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Sep 07 16:25:17 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Sep 07 16:25:17 raspberrypi systemd[1]: Starting Bluetooth service...
Sep 07 16:25:17 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Sep 07 16:25:17 raspberrypi bluetoothd[360]: Bluetooth daemon 5.43
Sep 07 16:25:17 raspberrypi systemd[1]: Started Bluetooth service.
Sep 07 16:25:17 raspberrypi systemd[1]: Reached target Bluetooth.
Sep 07 16:25:17 raspberrypi bluetoothd[360]: Starting SDP server
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: BNEP filters: protocol multicast
Sep 07 16:25:17 raspberrypi kernel: Bluetooth: BNEP socket layer initialized
Sep 07 16:25:17 raspberrypi bluetoothd[360]: Bluetooth management interface 1.14 initialized
Sep 07 16:25:17 raspberrypi bluetoothd[360]: Failed to obtain handles for "Service Changed" characteristic
Sep 07 16:25:17 raspberrypi dbus[220]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Sep 07 16:25:17 raspberrypi bluetoothd[360]: Sap driver initialization failed.
Sep 07 16:25:17 raspberrypi bluetoothd[360]: sap-server: Operation not permitted (1)
Sep 07 16:25:17 raspberrypi systemd[1]: Starting Hostname Service...
Sep 07 16:25:17 raspberrypi dbus[220]: [system] Successfully activated service 'org.freedesktop.hostname1'
Sep 07 16:25:17 raspberrypi systemd[1]: Started Hostname Service.
Sep 07 16:25:41 raspberrypi dhcpcd[201]: timed out
Sep 07 16:25:41 raspberrypi dhcpcd[201]: forked to background, child pid 372
Sep 07 16:25:41 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Sep 07 16:25:41 raspberrypi systemd[1]: Reached target Network.
Sep 07 16:25:41 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Sep 07 16:25:41 raspberrypi systemd[1]: Starting Permit User Sessions...
Sep 07 16:25:41 raspberrypi systemd[1]: Reached target Network is Online.
Sep 07 16:25:41 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Sep 07 16:25:41 raspberrypi systemd[1]: apt-daily.timer: Adding 9h 48min 36.455279s random time.
Sep 07 16:25:41 raspberrypi systemd[1]: Started Daily apt download activities.
Sep 07 16:25:41 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 25min 18.504097s random time.
Sep 07 16:25:41 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Sep 07 16:25:41 raspberrypi systemd[1]: Reached target Timers.
Sep 07 16:25:42 raspberrypi systemd[1]: Started Permit User Sessions.
Sep 07 16:25:42 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Sep 07 16:25:42 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Sep 07 16:25:42 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Sep 07 16:25:42 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 146 (plymouthd).
Sep 07 16:25:42 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Sep 07 16:25:42 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Sep 07 16:25:42 raspberrypi sshd[373]: Server listening on 0.0.0.0 port 22.
Sep 07 16:25:42 raspberrypi systemd[1]: Started Getty on tty1.
Sep 07 16:25:42 raspberrypi sshd[373]: Server listening on :: port 22.
Sep 07 16:25:42 raspberrypi systemd[1]: Reached target Login Prompts.
Sep 07 16:25:42 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Sep 07 16:25:42 raspberrypi systemd[1]: Reached target Multi-User System.
Sep 07 16:25:42 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Sep 07 16:25:42 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Sep 07 16:25:42 raspberrypi systemd[1]: Startup finished in 2.757s (kernel) + 44.274s (userspace) = 47.031s.
Sep 07 16:25:42 raspberrypi login[384]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Sep 07 16:25:43 raspberrypi systemd[1]: Created slice User Slice of pi.
Sep 07 16:25:43 raspberrypi systemd-logind[213]: New session c1 of user pi.
Sep 07 16:25:43 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Sep 07 16:25:43 raspberrypi systemd[1]: Started Session c1 of user pi.
Sep 07 16:25:43 raspberrypi systemd[393]: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Sep 07 16:25:43 raspberrypi systemd[393]: Listening on GnuPG BANNED agent and passphrase cache.
Sep 07 16:25:43 raspberrypi systemd[393]: Reached target Timers.
Sep 07 16:25:43 raspberrypi systemd[393]: Listening on GnuPG BANNED agent (access for web browsers).
Sep 07 16:25:43 raspberrypi systemd[393]: Listening on GnuPG BANNED agent (ssh-agent emulation).
Sep 07 16:25:43 raspberrypi systemd[393]: Reached target Paths.
Sep 07 16:25:43 raspberrypi systemd[393]: Listening on GnuPG BANNED agent and passphrase cache (restricted).
Sep 07 16:25:43 raspberrypi systemd[393]: Reached target Sockets.
Sep 07 16:25:43 raspberrypi systemd[393]: Reached target Basic System.
Sep 07 16:25:43 raspberrypi systemd[393]: Reached target Default.
Sep 07 16:25:43 raspberrypi systemd[393]: Startup finished in 158ms.
Sep 07 16:25:43 raspberrypi systemd[1]: Started User Manager for UID 1000.
Sep 07 16:26:02 raspberrypi kernel: random: crng init done
Sep 07 16:26:26 raspberrypi sudo[431]: pi : TTY=tty1 ; PWD=/home/pi ; USER=root ; COMMAND=/sbin/ifconfig -a
Sep 07 16:26:26 raspberrypi sudo[431]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Sep 07 16:26:26 raspberrypi sudo[431]: pam_unix(sudo:session): session closed for user root
Sep 07 16:26:35 raspberrypi sudo[441]: pi : TTY=tty1 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/dmesg
Sep 07 16:26:35 raspberrypi sudo[441]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Sep 07 16:26:35 raspberrypi sudo[441]: pam_unix(sudo:session): session closed for user root
Sep 07 16:26:43 raspberrypi sudo[450]: pi : TTY=tty1 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Sep 07 16:26:43 raspberrypi sudo[450]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Sep 07 16:26:43 raspberrypi sudo[450]: pam_unix(sudo:session): session closed for user root
Sep 07 16:26:46 raspberrypi sudo[458]: pi : TTY=tty1 ; PWD=/home/pi ; USER=root ; COMMAND=/sbin/ifconfig -a
Sep 07 16:26:46 raspberrypi sudo[458]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Sep 07 16:26:46 raspberrypi sudo[458]: pam_unix(sudo:session): session closed for user root
Sep 07 16:26:51 raspberrypi sudo[466]: pi : TTY=tty1 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/dmesg
Sep 07 16:26:51 raspberrypi sudo[466]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Sep 07 16:26:51 raspberrypi sudo[466]: pam_unix(sudo:session): session closed for user root
Sep 07 16:26:57 raspberrypi sudo[474]: pi : TTY=tty1 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Sep 07 16:26:57 raspberrypi sudo[474]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
viewtopic.php?f=50&t=124525&p=621675&hi ... ig#p621675
Any help is appreciated,
