Mini USB Microphone lots of clicking noise
by qLrtGgRU4LdAzR4e on Thu Nov 16, 2017 2:49 pm
I recently purchased a mini USB microphone from adafruit to use with my Pi Zero. I'm following the instructions https://learn.adafruit.com/usb-audio-cards-with-a-raspberry-pi/recording-audio and running
arecord --device=hw:1,0 -f S16_LE -r 44100 -c1 test.wav
The resulting wav file has this constant clicking noise in the background. Is there anyway to get rid of that? I tried following these trouble shooting instructions https://learn.adafruit.com/usb-audio-cards-with-a-raspberry-pi/troubleshooting but I don' t know how to set the usb mode to 1.1?
qLrtGgRU4LdAzR4e
Re: Mini USB Microphone lots of clicking noise
by adafruit_support_mike on Thu Nov 23, 2017 3:28 am
Try adding:
dwc_otg.speed=1
to the end of your /boot/cmdline.txt file and see if that helps.
by qLrtGgRU4LdAzR4e on Fri Dec 01, 2017 4:00 pm
Yeah I already tried that - it's listed as one of the hints in the troubleshooting post I linked above:
"You can work around the problem by adding dwc_otg.speed=1 to /boot/cmdline.txt and setting the USB ports to USB-1.1 mode."
Do you know how I set the USB port to USB-1.1 mode?
qLrtGgRU4LdAzR4e
by adafruit_support_mike on Sat Dec 02, 2017 3:43 am
That is the option that sets the OTG port to USB-1.1
by qLrtGgRU4LdAzR4e on Mon Dec 04, 2017 3:22 pm
Gotcha thanks. If there is nothing else to try I would suggest you stop recommending this microphone for the raspberry pi. The clicking artifact is pretty annoying.
qLrtGgRU4LdAzR4e
