Please see the contents of my /
boot/config.txt,
dmesg,
/dev/spi*,
/dev/fb*,
lsmod below.
I also tried some commands I found in the forum after searching for "SPI, ILI9341" and found an interesting post. The output of the command:
>sudo modprobe fbtft_device name=list; dmesg | tail -30
gives me this, which does not show ILI93421 anywhere. (I tried doing, ">subo modprobe fbtft_device name=pitftt", which cause the TFT screen to flicker, but doesn't show the desktop).
pi@raspberrypi:~ $ sudo modprobe fbtft_device name=list; dmesg | tail -30
modprobe: ERROR: could not insert 'fbtft_device': Operation canceled
[ 1041.511898] fbtft_device: ili9481
[ 1041.511902] fbtft_device: itdb24
[ 1041.511906] fbtft_device: itdb28
[ 1041.511909] fbtft_device: itdb28_spi
[ 1041.511913] fbtft_device: mi0283qt-2
[ 1041.511917] fbtft_device: mi0283qt-9a
[ 1041.511921] fbtft_device: mi0283qt-v2
[ 1041.511924] fbtft_device: nokia3310
[ 1041.511928] fbtft_device: nokia3310a
[ 1041.511932] fbtft_device: nokia5110
[ 1041.511935] fbtft_device: piscreen
[ 1041.511939] fbtft_device: pitft
[ 1041.511942] fbtft_device: pioled
[ 1041.511947] fbtft_device: rpi-display
[ 1041.511950] fbtft_device: s6d02a1
[ 1041.511954] fbtft_device: sainsmart18
[ 1041.511958] fbtft_device: sainsmart32
[ 1041.511962] fbtft_device: sainsmart32_fast
[ 1041.511965] fbtft_device: sainsmart32_latched
[ 1041.511969] fbtft_device: sainsmart32_spi
[ 1041.511973] fbtft_device: spidev
[ 1041.511976] fbtft_device: ssd1331
[ 1041.511980] fbtft_device: tinylcd35
[ 1041.511984] fbtft_device: tm022hdh26
[ 1041.511987] fbtft_device: tontec35_9481
[ 1041.511992] fbtft_device: tontec35_9486
[ 1041.511996] fbtft_device: upd161704
[ 1041.511999] fbtft_device: waveshare32b
[ 1041.512003] fbtft_device: waveshare22
[ 1041.512006] fbtft_device:
/boot/config.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=off
#dtparam=i2s=on
dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Turn on i2c (bus #1) for Raspberry Pi 2 and Pi 1 Model A, B (rev 2) and B+.
# If you have a Raspberry Pi Model B rev 1 with the i2c bus 0 instead,
# change this line to dtparam=i2c0=on
dtparam=i2c1=on
# --- added by adafruit-pitft-helper Thu 16 Nov 02:25:35 UTC 2017 ---
[pi1]
device_tree=bcm2708-rpi-b-plus.dtb
[pi2]
device_tree=bcm2709-rpi-2-b.dtb
[all]
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=off
dtoverlay=pitft28c,rotate=90,speed=32000000,fps=20
# --- end adafruit-pitft-helper Thu 16 Nov 02:25:35 UTC 2017 ---
dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.59-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1047 SMP Sun Oct 29 12:19:23 GMT 2017
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] free_area_init_node: node 0, pgdat 80c6f380, node_mem_map ba3a1000
[ 0.000000] Normal zone: 2133 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 242688 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 14 pages/cpu @ba35b000 s25600 r8192 d23552 u57344
[ 0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a074c7b3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait fbcon=map:10 fbcon=font:VGA8x8 quiet splash plymouth.ignore-serial-consoles
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 940364K/970752K available (7168K kernel code, 486K rwdata, 2012K rodata, 1024K init, 770K bss, 22196K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80b00000 - 0x80c00000 (1024 kB)
.data : 0x80c00000 - 0x80c79834 ( 487 kB)
.bss : 0x80c7b000 - 0x80d3b964 ( 771 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000018] Switching to timer-based delay loop, resolution 52ns
[ 0.000294] Console: colour dummy device 80x30
[ 0.000310] console [tty1] enabled
[ 0.000329] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000345] pid_max: default: 32768 minimum: 301
[ 0.000649] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000658] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001659] Disabling memory control group subsystem
[ 0.001731] CPU: Testing write buffer coherency: ok
[ 0.001764] ftrace: allocating 22392 entries in 66 pages
[ 0.048808] CPU0: update cpu_capacity 1024
[ 0.048822] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.048857] Setting up static identity map for 0x100000 - 0x100034
[ 0.050719] CPU1: update cpu_capacity 1024
[ 0.050727] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.051412] CPU2: update cpu_capacity 1024
[ 0.051419] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.052090] CPU3: update cpu_capacity 1024
[ 0.052096] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.052184] Brought up 4 CPUs
[ 0.052194] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.052198] CPU: All CPU(s) started in HYP mode.
[ 0.052202] CPU: Virtualization extensions available.
[ 0.052992] devtmpfs: initialized
[ 0.064522] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.064791] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.064807] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.065340] pinctrl core: initialized pinctrl subsystem
[ 0.066244] NET: Registered protocol family 16
[ 0.068643] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.077617] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.077623] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.077760] Serial: AMBA PL011 UART driver
[ 0.079659] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.080185] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.149649] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[ 0.151471] SCSI subsystem initialized
[ 0.151629] usbcore: registered new interface driver usbfs
[ 0.151705] usbcore: registered new interface driver hub
[ 0.151800] usbcore: registered new device driver usb
[ 0.158613] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:09
[ 0.160145] clocksource: Switched to clocksource arch_sys_counter
[ 0.207163] VFS: Disk quotas dquot_6.6.0
[ 0.207238] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.207439] FS-Cache: Loaded
[ 0.207680] CacheFiles: Loaded
[ 0.219795] NET: Registered protocol family 2
[ 0.220689] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.220797] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.220982] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.221069] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.221110] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.221315] NET: Registered protocol family 1
[ 0.221722] RPC: Registered named UNIX socket transport module.
[ 0.221727] RPC: Registered udp transport module.
[ 0.221731] RPC: Registered tcp transport module.
[ 0.221736] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.222845] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.225145] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.241197] FS-Cache: Netfs 'nfs' registered for caching
[ 0.242174] NFS: Registering the id_resolver key type
[ 0.242198] Key type id_resolver registered
[ 0.242203] Key type id_legacy registered
[ 0.244605] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.244708] io scheduler noop registered
[ 0.244714] io scheduler deadline registered (default)
[ 0.244961] io scheduler cfq registered
[ 0.250598] BCM2708FB: allocated DMA memory fad10000
[ 0.250621] BCM2708FB: allocated DMA channel 0 @ bb80f000
[ 0.309167] Console: switching to colour frame buffer device 240x135
[ 0.344969] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.345094] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.345644] vc-sm: Videocore shared memory driver
[ 0.360877] brd: module loaded
[ 0.369791] loop: module loaded
[ 0.369805] Loading iSCSI transport class v2.0-870.
[ 0.370412] usbcore: registered new interface driver smsc95xx
[ 0.370427] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.598493] Core Release: 2.80a
[ 0.598501] Setting default values for core params
[ 0.598532] Finished setting default values for core params
[ 0.798925] Using Buffer DMA mode
[ 0.798930] Periodic Transfer Interrupt Enhancement - disabled
[ 0.798935] Multiprocessor Interrupt Enhancement - disabled
[ 0.798941] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.798953] Dedicated Tx FIFOs mode
[ 0.799321] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[ 0.799347] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.799353] dwc_otg: Microframe scheduler enabled
[ 0.799397] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058f5b0
[ 0.799406] WARN::hcd_init_fiq:460: FIQ ASM at 0x8058f920 length 36
[ 0.799419] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87a000
[ 0.799476] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.799513] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.799543] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 0.799591] Init: Port Power? op_state=1
[ 0.799595] Init: Power Port (0)
[ 0.799806] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.799816] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.799825] usb usb1: Product: DWC OTG Controller
[ 0.799832] usb usb1: Manufacturer: Linux 4.9.59-v7+ dwc_otg_hcd
[ 0.799841] usb usb1: SerialNumber: 3f980000.usb
[ 0.800680] hub 1-0:1.0: USB hub found
[ 0.800725] hub 1-0:1.0: 1 port detected
[ 0.801466] dwc_otg: FIQ enabled
[ 0.801470] dwc_otg: NAK holdoff enabled
[ 0.801474] dwc_otg: FIQ split-transaction FSM enabled
[ 0.801488] Module dwc_common_port init
[ 0.801716] usbcore: registered new interface driver usb-storage
[ 0.801963] mousedev: PS/2 mouse device common for all mice
[ 0.802940] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.803216] bcm2835-cpufreq: min=600000 max=1200000
[ 0.803606] sdhci: Secure Digital Host Controller Interface driver
[ 0.803610] sdhci: Copyright(c) Pierre Ossman
[ 0.803889] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[ 0.806062] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.806163] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.808804] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.809000] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.809178] usbcore: registered new interface driver usbhid
[ 0.809182] usbhid: USB HID core driver
[ 0.809982] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[ 0.811707] [vc_sm_connected_init]: start
[ 0.822043] [vc_sm_connected_init]: end - returning 0
[ 0.822423] Initializing XFRM netlink socket
[ 0.822446] NET: Registered protocol family 17
[ 0.822557] Key type dns_resolver registered
[ 0.823116] Registering SWP/SWPB emulation handler
[ 0.823809] registered taskstats version 1
[ 0.830199] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.830270] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.831866] sdhost: log_buf @ bad07000 (fad07000)
[ 0.910178] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.912414] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.912422] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 0.970292] of_cfs_init
[ 0.970404] of_cfs_init: OK
[ 0.970878] Waiting for root device PARTUUID=a074c7b3-02...
[ 0.988276] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.989843] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.991399] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.994179] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.020280] Indeed it is in host mode hprt0 = 00021501
[ 1.087436] random: fast init done
[ 1.091820] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.094685] mmc0: new high speed SDHC card at address aaaa
[ 1.095354] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 1.098279] mmcblk0: p1 p2
[ 1.148861] mmc1: new high speed SDIO card at address 0001
[ 1.220191] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.220327] Indeed it is in host mode hprt0 = 00001101
[ 1.224428] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.224477] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.225214] devtmpfs: mounted
[ 1.282197] Freeing unused kernel memory: 1024K
[ 1.450488] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.450504] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.451361] hub 1-1:1.0: USB hub found
[ 1.451452] hub 1-1:1.0: 5 ports detected
[ 1.686405] systemd[1]: System time before build time, advancing clock.
[ 1.770199] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.819796] NET: Registered protocol family 10
[ 1.833491] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.863111] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +BANNED +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 1.863705] systemd[1]: Detected architecture arm.
[ 1.864744] systemd[1]: Set hostname to <raspberrypi>.
[ 1.900809] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.900827] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.903993] smsc95xx v1.0.5
[ 1.994197] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:f6:f9:91
[ 2.090226] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 2.221707] usb 1-1.2: New USB device found, idVendor=7392, idProduct=7811
[ 2.221723] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.221731] usb 1-1.2: Product: 802.11n WLAN Adapter
[ 2.221738] usb 1-1.2: Manufacturer: Realtek
[ 2.221746] usb 1-1.2: SerialNumber: 00e04c000001
[ 2.320202] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[ 2.342531] systemd[1]: Created slice User and Session Slice.
[ 2.343016] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.343261] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.343496] systemd[1]: Listening on Syslog Socket.
[ 2.344108] systemd[1]: Created slice System Slice.
[ 2.344778] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.347757] systemd[1]: Mounting Debug File System...
[ 2.462530] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b
[ 2.462548] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.462556] usb 1-1.4: Product: USB Receiver
[ 2.462568] usb 1-1.4: Manufacturer: Logitech
[ 2.472592] i2c /dev entries driver
[ 2.847965] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 2.924688] systemd-journald[124]: Received request to flush runtime journal from PID 1
[ 3.256217] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.4/input2
[ 3.461791] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 3.790770] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 3.802564] usbcore: registered new interface driver brcmfmac
[ 3.831000] input: Logitech K400 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input0
[ 3.832426] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-3f980000.usb-1.4:1
[ 3.946302] usbcore: registered new interface driver rtl8192cu
[ 4.025204] brcmfmac: Firmware version = wl0: Aug 7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
[ 4.026103] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.41 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-08-07 00:37:47
[ 4.047717] random: crng init done
[ 4.978793] uart-pl011 3f201000.serial: no DMA platform data
[ 6.444033] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.891163] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 6.891244] brcmfmac: power management disabled
[ 7.374084] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 7.374545] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.611857] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 8.013733] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 8.027562] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 9.496306] Bluetooth: Core ver 2.22
[ 9.496385] NET: Registered protocol family 31
[ 9.496390] Bluetooth: HCI device and connection manager initialized
[ 9.496408] Bluetooth: HCI socket layer initialized
[ 9.496422] Bluetooth: L2CAP socket layer initialized
[ 9.496453] Bluetooth: SCO socket layer initialized
[ 9.517072] Bluetooth: HCI UART driver ver 2.3
[ 9.517085] Bluetooth: HCI UART protocol H4 registered
[ 9.517090] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 9.517248] Bluetooth: HCI UART protocol Broadcom registered
[ 9.837971] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.837984] Bluetooth: BNEP filters: protocol multicast
[ 9.838006] Bluetooth: BNEP socket layer initialized
[ 9.915257] Bluetooth: RFCOMM TTY layer initialized
[ 9.915297] Bluetooth: RFCOMM socket layer initialized
[ 9.915326] Bluetooth: RFCOMM ver 1.11
[ 12.973598] fuse init (API version 7.26)
[ 55.856799] logitech-hidpp-device 0003:046D:4024.0004: HID++ 2.0 device connected.
>ll /dev/spi*
pi@raspberrypi:~ $ ll /dev/spi*
crw-rw---- 1 root spi 153, 0 Nov 22 02:24 /dev/spidev0.0
crw-rw---- 1 root spi 153, 1 Nov 22 02:24 /dev/spidev0.1
>ll /dev/fb*
i@raspberrypi:~ $ ll /dev/fb*
crw-rw---- 1 root video 29, 0 Nov 22 02:24 /dev/fb0
lsmod
pi@raspberrypi:~ $ lsmod
Module Size Used by
fuse 99603 3
rfcomm 37723 6
bnep 12051 2
hci_uart 20020 1
btbcm 7916 1 hci_uart
bluetooth 365780 29 hci_uart,bnep,btbcm,rfcomm
evdev 12423 2
joydev 9988 0
hid_logitech_hidpp 20558 0
spidev 7373 0
brcmfmac 292632 0
brcmutil 9863 1 brcmfmac
snd_bcm2835 24427 1
snd_pcm 98501 1 snd_bcm2835
snd_timer 23968 1 snd_pcm
snd 70032 5 snd_timer,snd_bcm2835,snd_pcm
spi_bcm2835 7596 0
bcm2835_gpiomem 3940 0
8192cu 582281 0
uio_pdrv_genirq 3923 0
uio 10204 1 uio_pdrv_genirq
fixed 3285 0
cfg80211 544545 2 8192cu,brcmfmac
hid_logitech_dj 12173 0
rfkill 20851 7 bluetooth,cfg80211
i2c_dev 6913 0
ip_tables 13161 0
x_tables 20578 1 ip_tables
ipv6 408900 30
thanks for your help. when this is working, i'll rename the thread and list the steps to get this working for others to reference.
