EDIT 1: I tried redoing this with a new "pi zero w" and a new "adafruit i2s audio decoder" and the outcome is the same. Everything looks right but there is no sound. Please help.
I've recently purchased 3 of these little breakout boards for use with a raspberry pi zero w. I can't get any sound out f it at all.
I initially installed stretch lite and went through the setup procedure. All went well but no sound during any of the speaker tests. I noticed that the adafruit tutorial used jessie lite so installed that and went through the setup procedure again but still no sound.
I used the i2samp.sh script and then went through the manual install method just to make certain that the script did everything correctly ... it did.
No errors or weird messages in the log files during reboots or from the speaker tests ... they seem to be running and sending data to the left/right channels alternately.
I used a 'scope to check the 3 i/o lines between the pi zero and the DAC but see nothing during the speaker tests so the pi zero doesn't seem to be sending data/clock to the DAC.
lsmod seems to show a reasonable set of modules: snd_soc_bcm2835_i2s, snd_soc_hifiberry_dac, and snd_soc_pcm5102a are all loaded along with the lower level snd modules.
I can't see anything out of place here. Am I missing something obvious?
Thank you...
I2S Stereo DAC (UDA1334A)
- jimv206
Re: I2S Stereo DAC (UDA1334A)
- jimv206
Thanks for the reply. I've uploaded the image you've requested. I'm sure I've overlooked something silly ;-)
- jimv206
OK, I looked at some more things. I installed mpg123 and executed:
and let it run for a few seconds. Naturally, it created a rather large file. In that file, I saw these lines:
Followed by some checks like:
... etc, and then interestingly:
The "Audio device: <none>" doesn't seem right.
Hope this helps.
mpg123 -vvv http://ice1.somafm.com/u80s-128-mp3 > mpg123-output.txt 2>&1
Trying output module alsa.
Using default module dir: /usr/lib/arm-linux-gnueabihf/mpg123
Module dir: /usr/lib/arm-linux-gnueabihf/mpg123
Module path: ./output_alsa.so
Output module 'alsa' chosen.
High Performance MPEG 1.0/2.0/2.5 Audio Player for Layers 1, 2 and 3
version 1.20.1; written and copyright by Michael Hipp and others
free software (LGPL) without any warranty but with best wishes
Decoder: generic
Note: Disabling all formats.
Note: checking support for 8000Hz/1ch.
Note: result 0x77ff
Note: Want to enable format 8000/1 for encodings 0x77ff.
Note: checking support for 11025Hz/1ch.
Note: result 0x77ff
Audio driver: alsa
Audio capabilities:
Hope this helps.
Your wired connections don't match the ones shown in the tutorial:
viewtopic.php?f=24&t=54246&start=15#p630193
The RasPi's I2S interface only exists on GPIO 18, 19, and 21.
- jimv206
OK silly me. I thought the tutorial meant "pins" 18, 19, 21. Maybe the tutorial could indicate "GPIO18", etc rather than just "#18", etc? I really thought it was pin numbers.
Will try this tomorrow.
Thank you so much.
Jim
Thank you so much.
Jim
- jimv206
Just to let you know, all is working well now. Thank you.
Glad to hear that did it. Happy hacking!
- waiyung
Dear all, what is the mount hole size for UDA1334A? I tried 4-40, it did not fit. Thank u
The holes are drilled 0.1", but lose a few thousandths when the through-holes are plated.
4-40 threads have a major diameter of 0.1120", so they are a bit too big. You'd need #2 screws (2-56 or 2-64) if you want to stick to imperial sizes. 3-48 or 3-56 might work, but the major diameter is 0.99", which is pretty close to the diameter of the plated hole.
In metric sizes, M2 screws will definitely work. M2.5 threads are slightly narrower than #3 imperial, so those might work if you're lucky.
