Hello
my dad got me a raspberry pi zero w for christmas and when I hook it up to my tv it works but there are a lot of green pixel on my tv so then me and him went out to best buy and purchased a second hdmi mini to regular hdmi adapter and it still didn't work. I even tried it in on the tv in the living room but the same problem was occurring. so what I want to do is not return it but get a replacement.
Order Confirmation No: 1591210-0178361635
Regards,
Samir Hamada
[email protected]
raspberry pi zero w bad hdmi port
- sehamada
- 20180102_232520-600x800.jpg (171.93 KiB) Viewed 416 times
- 20180102_232501-600x800.jpg (141.08 KiB) Viewed 416 times
Re: raspberry pi zero w bad hdmi port
That's a known issue:
https://elinux.org/R-Pi_Troubleshooting#Display
It means the HDMI signal isn't quite strong enough. You can usually make it work by adding the line:
to the file /boot/config.txt
config_hdmi_boost=7
- sehamada
The txt won't save changes
You have to edit /boot/config.txt using `sudo`, or move the SD card to a desktop computer and edit the file there.
- sehamada
i did it and it still did not work
- freddyja
I have the same issue with my two raspberry zero that I've bought I plug them in but it doesn't seem to have a signal in the HDMI I troubleshooted by connecting my raspberry 3 and it works fine to the HDMI so it's not my HDMI connection thanks
@freddyja: Please start a new thread for your issue. Trying to handle more than one set of hardware in a thread is just asking for confusion.
@sehamada: Send a note containing a link to this thread and your order number to [email protected]. The folks there will get you a replacement display, and will arrange return shipping for the one you have now.
