Order 1622717-5731789260
Hello, the Raspberry Pi 3 - Model B (part 3055) that was part of
my order failed on day 2 of use. I would like to see if this can be
replaced.
I verified that the the SD card boots another RPi3 that we have running PiHole.
Raspberry Pi
- adafruit_support_mike
Re: Raspberry Pi
As a hardware check, what voltages do you see on the 3.3v and 5v GPIO pins when the RasPi is powered?
- aik
Re: Raspberry Pi
They measured 3.33 volts and 5.20 volts respectively.
Re: Raspberry Pi
Thank you.. that rules out most of the worst kinds of hardware failure.
Do you see any activity at all when the RasPi tries to boot, especially a blink pattern from the green LED?
Re: Raspberry Pi
Is there any flicker on the green LED, or a 'faint green glow'?
The last thing the board's firmware does before looking for an OS image to boot is set the green LED on a low PWM duty cycle, do it lights just barely enough to be visible. A boot that stops there usually means there's some kind of issue with the connection to the SD card.
- aik
Re: Raspberry Pi
The SDK card was put in this Pi and it didn't work. The SDK was put in a second Pi and it did work. I would like a replacement.
Re: Raspberry Pi
Send a note containing a link to this thread and your order number to [email protected]. The folks there will get you a replacement.
- aik
Re: Raspberry Pi
Thank you. I have emailed support again.
