I'm having a problem trying to get the SPI bus to work with a BME280 module. The Raspberry pi 2 is connected to a 40 pin
breakout adapter to solder less breadboard.
BME280 SCK-> SCLK Raspberry pi
BME280 SDO -> MISO
BME280 SDI -> MOSI
BME280 CD -> GPIO 8 (CE0)
I'm using Python. I have activated the Raspberry pi 2 SPI using the raspi-config setup menu.
I run Adafruit_BME280_Example.py and get the following errors. Any idea what my problem is?
The BME280 works when connected to the I2C bus.
File "/home/pi/Downloads/Adafruit_Python_BME280_master/Adafruit_BME280_Example.py", line 3, in <module>
sensor = BME280(mode=BME280_OSAMPLE_8)
File "/home/pi/Downloads/Adafruit_Python_BME280_master/Adafruit_BME280.py", line 90, in __init__
self._load_calibration()
File "/home/pi/Downloads/Adafruit_Python_BME280_master/Adafruit_BME280.py", line 96, in _load_calibration
self.dig_T1 = self._device.readU16LE(BME280_REGISTER_DIG_T1)
File "/usr/local/lib/python2.7/dist-packages/Adafruit_GPIO-1.0.1-py2.7.egg/Adafruit_GPIO/I2C.py", line 185, in readU16LE
return self.readU16(register, little_endian=True)
File "/usr/local/lib/python2.7/dist-packages/Adafruit_GPIO-1.0.1-py2.7.egg/Adafruit_GPIO/I2C.py", line 164, in readU16
result = self._bus.read_word_data(self._address,register) & 0xFFFF
File "/usr/local/lib/python2.7/dist-packages/Adafruit_PureIO-0.2.1-py2.7.egg/Adafruit_PureIO/smbus.py", line 173, in read_word_data
ioctl(self._device.fileno(), I2C_RDWR, request)
IOError: [Errno 5] Input/output error
Thanks,
Owl2623
BME280 SPI interface to Raspberry pi 2
Re: BME280 SPI interface to Raspberry pi 2
The errors say the code is still trying to find the BME280 on the I2C bus.
I'm afraid the Adafruit_Python_BME280 module is only written for I2C.
- Owl2623
Mike,
I was hoping to use the I2C bus for a Adafruit HMC5883 module which only has I2C interface and the BME280 on the SPI bus not knowing how to address each module separately on a I2C bus.
Can you advise on how to structure the code to address the individual modules? Samples would be appreciated.
I'm open to any other suggestion you can offer.
Thanks,
Alan
PS. I did some more searching and I believe that I have found code implementing SPI communication for the BME280.
https://github.com/spooky360/BME280_Pyt ... /BME280.py
Comments?
Alan
Thanks,
Alan
Comments?
Alan
All I2C devices have built-in addresses, usually built right into the chip circuit. Some have pins that let you change the address so you can use more than one of the chip on the same I2C bus, but some only give you one choice.
The HMC5883's address is 0x17, and the BME280 uses address 0x77. The code libraries already have those values written in, and the two devices can share the same I2C bus. All you have to do is connect the SDA and SCL lines.
- Owl2623
That was simpler than expected. I will give it a try.
