I decided to throw my hand into the ring with trying to do the PiGrrl Zero. Got everything together, continuity seems clear on all the points, but when I connect power and flip the switch, I just get the white screen. I'm including a copy of the code from dmesg.txt as well as a photo of the soldering (hopefully it is clear enough, I've had some issues with lighting of late).
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.35+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 Fri Jun 30 14:34:49 BST 2017
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x1c800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 119808
[ 0.000000] free_area_init_node: node 0, pgdat c0914874, node_mem_map dc3e3000
[ 0.000000] Normal zone: 1053 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 119808 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 118755
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=320 bcm2708_fb.fbheight=240 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:1D:BC:E3 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=3d24ca30-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait loglevel=3 consoleblank=0 plymouth.enable=0
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 456240K/479232K available (5946K kernel code, 489K rwdata, 1948K rodata, 400K init, 734K bss, 14800K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xdd800000 - 0xff800000 ( 544 MB)
lowmem : 0xc0000000 - 0xdd400000 ( 468 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc05d6bbc (5947 kB)
.init : 0xc0840000 - 0xc08a4000 ( 400 kB)
.data : 0xc08a4000 - 0xc091e728 ( 490 kB)
.bss : 0xc091e728 - 0xc09d5f28 ( 734 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000030] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000061] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000154] bcm2835: system timer (irq = 27)
[ 0.000612] Console: colour dummy device 80x30
[ 0.000635] console [tty1] enabled
[ 0.000660] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060299] pid_max: default: 32768 minimum: 301
[ 0.060727] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060742] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.061810] Disabling cpuset control group subsystem
[ 0.062015] CPU: Testing write buffer coherency: ok
[ 0.062073] ftrace: allocating 21712 entries in 64 pages
[ 0.176822] Setting up static identity map for 0x8200 - 0x8238
[ 0.178803] devtmpfs: initialized
[ 0.188186] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.188604] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.188630] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.189910] pinctrl core: initialized pinctrl subsystem
[ 0.191349] NET: Registered protocol family 16
[ 0.193857] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.203614] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.203629] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.203733] Serial: AMBA PL011 UART driver
[ 0.206591] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.207296] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.255717] bcm2835-dma 20007000.dma: DMA legacy API manager at dd80d000, dmachans=0x1
[ 0.258471] SCSI subsystem initialized
[ 0.258748] usbcore: registered new interface driver usbfs
[ 0.258868] usbcore: registered new interface driver hub
[ 0.259064] usbcore: registered new device driver usb
[ 0.266901] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-03 14:16
[ 0.268868] clocksource: Switched to clocksource timer
[ 0.325085] VFS: Disk quotas dquot_6.6.0
[ 0.325200] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.325497] FS-Cache: Loaded
[ 0.325852] CacheFiles: Loaded
[ 0.345141] NET: Registered protocol family 2
[ 0.346483] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.346572] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.346667] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.346760] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.346786] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.347110] NET: Registered protocol family 1
[ 0.347853] RPC: Registered named UNIX socket transport module.
[ 0.347864] RPC: Registered udp transport module.
[ 0.347869] RPC: Registered tcp transport module.
[ 0.347873] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.349179] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.351556] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.371459] FS-Cache: Netfs 'nfs' registered for caching
[ 0.373192] NFS: Registering the id_resolver key type
[ 0.373238] Key type id_resolver registered
[ 0.373244] Key type id_legacy registered
[ 0.377659] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.378020] io scheduler noop registered
[ 0.378032] io scheduler deadline registered (default)
[ 0.378494] io scheduler cfq registered
[ 0.384395] BCM2708FB: allocated DMA memory 5c900000
[ 0.384453] BCM2708FB: allocated DMA channel 0 @ dd80d000
[ 0.388509] Console: switching to colour frame buffer device 40x30
[ 0.393250] bcm2835-rng 20104000.rng: hwrng registered
[ 0.393402] vc-cma: Videocore CMA driver
[ 0.393413] vc-cma: vc_cma_base = 0x00000000
[ 0.393421] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.393426] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.393830] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 0.418672] brd: module loaded
[ 0.430910] loop: module loaded
[ 0.430931] Loading iSCSI transport class v2.0-870.
[ 0.431794] usbcore: registered new interface driver smsc95xx
[ 0.431822] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.660136] Core Release: 2.80a
[ 0.660163] Setting default values for core params
[ 0.660201] Finished setting default values for core params
[ 0.860552] Using Buffer DMA mode
[ 0.860564] Periodic Transfer Interrupt Enhancement - disabled
[ 0.860569] Multiprocessor Interrupt Enhancement - disabled
[ 0.860580] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.860669] Dedicated Tx FIFOs mode
[ 0.861259] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdc914000 dma = 0x5c914000 len=9024
[ 0.861285] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.861295] dwc_otg: Microframe scheduler enabled
[ 0.861378] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04512ec
[ 0.861390] WARN::hcd_init_fiq:460: FIQ ASM at 0xc04515c8 length 36
[ 0.861415] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdd878000
[ 0.861484] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.861548] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.861667] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 0.861720] Init: Port Power? op_state=1
[ 0.861725] Init: Power Port (0)
[ 0.862082] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.862097] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.862108] usb usb1: Product: DWC OTG Controller
[ 0.862117] usb usb1: Manufacturer: Linux 4.9.35+ dwc_otg_hcd
[ 0.862127] usb usb1: SerialNumber: 20980000.usb
[ 0.863302] hub 1-0:1.0: USB hub found
[ 0.863388] hub 1-0:1.0: 1 port detected
[ 0.864264] dwc_otg: FIQ enabled
[ 0.864274] dwc_otg: NAK holdoff enabled
[ 0.864279] dwc_otg: FIQ split-transaction FSM enabled
[ 0.864299] Module dwc_common_port init
[ 0.864800] usbcore: registered new interface driver usb-storage
[ 0.865252] mousedev: PS/2 mouse device common for all mice
[ 0.866846] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.867349] bcm2835-cpufreq: min=700000 max=1000000
[ 0.867979] sdhci: Secure Digital Host Controller Interface driver
[ 0.867986] sdhci: Copyright(c) Pierre Ossman
[ 0.868463] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
[ 0.870989] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
[ 0.871156] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.871682] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.871827] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.872096] usbcore: registered new interface driver usbhid
[ 0.872103] usbhid: USB HID core driver
[ 0.873324] vchiq: vchiq_init_state: slot_zero = 0xdc980000, is_master = 0
[ 0.875707] Initializing XFRM netlink socket
[ 0.875762] NET: Registered protocol family 17
[ 0.875941] Key type dns_resolver registered
[ 0.878273] registered taskstats version 1
[ 0.878807] vc-sm: Videocore shared memory driver
[ 0.878830] [vc_sm_connected_init]: start
[ 0.884880] [vc_sm_connected_init]: end - returning 0
[ 0.893530] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 0.895928] sdhost: log_buf @ dc913000 (5c913000)
[ 0.968949] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.971452] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.971468] mmc-bcm2835 20300000.mmc: DMA channel allocated
[ 1.002004] random: fast init done
[ 1.049095] of_cfs_init
[ 1.049272] of_cfs_init: OK
[ 1.055758] Waiting for root device PARTUUID=3d24ca30-02...
[ 1.067053] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.068696] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.070487] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.073526] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.107913] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.111096] mmc0: new high speed SDHC card at address e624
[ 1.112321] mmcblk0: mmc0:e624 SU16G 14.8 GiB
[ 1.114831] mmcblk0: p1 p2
[ 1.179196] mmc1: new high speed SDIO card at address 0001
[ 1.186725] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.186817] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.188205] devtmpfs: mounted
[ 1.189502] Freeing unused kernel memory: 400K (c0840000 - c08a4000)
[ 1.189510] This architecture does not have kernel memory protection.
[ 1.508082] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -BANNED)
[ 1.508694] systemd[1]: Detected architecture 'arm'.
[ 1.644715] NET: Registered protocol family 10
[ 1.646629] systemd[1]: Inserted module 'ipv6'
[ 1.649687] systemd[1]: Set hostname to <retropie>.
[ 1.650211] systemd[1]: Initializing machine ID from random generator.
[ 1.650777] systemd[1]: Installed transient /etc/machine-id file.
[ 2.388627] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[ 2.395411] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 2.396253] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.396480] systemd[1]: Starting Remote File Systems (Pre).
[ 2.877405] fuse init (API version 7.26)
[ 4.696226] systemd-udevd[132]: starting version 215
[ 6.779123] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 6.978155] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.968566] usbcore: registered new interface driver brcmfmac
[ 8.146350] brcmfmac: Firmware version = wl0: Aug 7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
[ 8.984589] systemd-journald[128]: Received request to flush runtime journal from PID 1
[ 9.591599] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.622184] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.623287] fbtft_of_value: buswidth = 8
[ 9.623298] fbtft_of_value: debug = 0
[ 9.623304] fbtft_of_value: rotate = 270
[ 9.623309] fbtft_of_value: fps = 40
[ 10.231853] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=50, spi0.0 at 60 MHz
[ 11.001770] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.001802] brcmfmac: power management disabled
[ 11.695264] uart-pl011 20201000.serial: no DMA platform data
[ 12.760197] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:266236k SSFS
[ 13.227953] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 16.162190] Bluetooth: Core ver 2.22
[ 16.162349] NET: Registered protocol family 31
[ 16.162358] Bluetooth: HCI device and connection manager initialized
[ 16.162387] Bluetooth: HCI socket layer initialized
[ 16.162413] Bluetooth: L2CAP socket layer initialized
[ 16.162468] Bluetooth: SCO socket layer initialized
[ 16.175357] Bluetooth: HCI UART driver ver 2.3
[ 16.175376] Bluetooth: HCI UART protocol H4 registered
[ 16.175383] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.175587] Bluetooth: HCI UART protocol Broadcom registered
[ 16.474522] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.474533] Bluetooth: BNEP filters: protocol multicast
[ 16.474558] Bluetooth: BNEP socket layer initialized
[ 19.730575] input: retrogame as /devices/virtual/input/input0
[ 36.911098] random: crng init done
