Good Afternoon,
I recently purchased the Raspberry Pi NoIR Camera Board v2 (Order # 1764096-4365750125, purchased last week) and have not been able to get it to work. I am using a new bare bones Pi 3 B+ with nothing else attached to it. I am running Raspbian and have updated and upgraded the OS. I have enabled the camera via the configuration and cannot get any video or pictures to be taken. I have verified all connections are secure and the cables are in the correct direction. I have also tested a 2nd Pi and a longer camera cable with no luck. Attached is a picture of the error I get when I try and take a picture/video. Any help would be appreciated.
Raspberry Pi NoIR Camera Board v2 - 8 Megapixels (PID: 3100)
- pilot56
- Attachments
- Capture.JPG (30.55 KiB) Viewed 216 times
Re: Raspberry Pi NoIR Camera Board v2 - 8 Megapixels (PID: 3
To confirm, have you disconnected and reseated the Kapton tab between the CCD module and the PCB?
- pilot56
Yes, I have tried twice. I am assuming that this is the black locking feature on the connector.
That sounds more like the flex cable connector.
The CCD module is the device that actually captures the image, and has the lens assembly on its front. It connects to the PCB through a short flex cable, and the connection between that cable and the PCB is what I'm referring to:
- pilot56
I had not tried to re-seat that connector. I was unaware it was even possible.
Update ... I have unplugged, inspected, and reinserted this connection and I am still getting the same error on the Pi
- ngong0
I have a new raspi zero W and noIR camera module as well and having the exact same issue. Constantly reseated all 3 connectors. Rebooted. Reflashed. installed all updates as well
pi@raspberrypi:~ $ raspistill -t 3000 -o test.jpg
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
pi@raspberrypi:~ $ vcgencmd get_camera
supported=1 detected=0
Thank you.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement NoIR camera.
(#3100)
(#3100)
