Hello, I want to use the servo hat to control multiple servo motors. Therefore I setup my Raspberry Pi according to the tutorial of the servo hat, but in the end the test did not move my motor at all.
These are the things i did:
I2C configuration:
sudo apt-get install python-smbus
sudo apt-get install i2c-tools
installed kernel support with raspi-config
sudo i2cdetect -y 1 (gives the same output as in the tutorial)
install python library:
sudo apt-get install -y git build-essential python-dev
git clone https://github.com/adafruit/Adafruit_Python_PCA9685.git
cd Adafruit_Python_PCA9685
sudo python setup.py install
sudo python examples/simpletest.py --> This command does nothing to the connected motor.
Is there something else needed for this to work?
PWM / SERVO HAT doesn't move FS5103R motor
- adafruit_support_bill
Re: PWM / SERVO HAT doesn't move FS5103R motor
Can we get a closer shot of the board? From this angle it looks like there is no solder on the header pins.
- DSStore
There is indeed no solder on it because i currently don't have access to a soldering iron, but it should work even without soldering even if it's not ideal right?
If it works at all, it will be intermittent at best. And you also risk damage to the chips on the board.
- DSStore
ok thank you for your help
