PI 3B+ doesn't boot!!
ralphxyz
Post by ralphxyz »
Raspberry Pi 3 - Model B+ - 1.4GHz Cortex-A53 with 1GB RAM PID: 3775
No Input Signal
NOOBS_v2_8_1 as far as I know the latest!!
bcm2710-rpi-3-b-plus.dtb
Thanks for the help!!
Ralph
Franklin97355
Re: PI 3B+ doesn't boot!!
Post by Franklin97355 »
Try the latest Raspbian as a test. The B+ is really finicky on what OS it likes.
ralphxyz
Post by ralphxyz »
This is the latest I downloaded it yesterday!!
ralphxyz wrote:Raspberry Pi 3 - Model B+ - 1.4GHz Cortex-A53 with 1GB RAM PID: 3775
No Input Signal
Ralph
Franklin97355
The 3B+ Pi's have had a problem with NOOBS, please try Raspbian.
ralphxyz
Post by ralphxyz »
oops sorry, Raspbian is being downloaded!!
Thanks for your help!!
Ralph
ralphxyz
Post by ralphxyz »
Same result with Raspbian!!
Only the red PWR led lights should the ACT led also light?
Ralph
ralphxyz
Post by ralphxyz »
Both the NOOBS and Raspbian work fine on my PI Zero W but nothing on my Pi 3B+.
Ralph
adafruit_support_mike
What voltages do you see on the 5V and 3.3V GPIO pins?
ralphxyz
Post by ralphxyz »
Pin 1 5.2v
Pin 2 5.37v
That's not good.. it sounds like the 3.3V regulator has failed.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement Pi3B+, and may arrange return shipping for the one you have now. We've been seeing an unusually high rate of similar problems, and the RasPi Foundation might want us to pull some units back for inspection.
(#3775)
ralphxyz
Post by ralphxyz »
Thanks, done.
INVOICE NO. 1776433
DATE ORDERED: Friday 01 June, 2018
PAYMENT METHOD: PayPal
Now how the heck do you get the Raspberry Pi 3B+ out of the nice case I bought with it?
Also how to remove and reuse the heatsink?
Ralph
Flip the case over and you'll see slots along the edges near the clips that hold the PCB down. Use a thin-bladed screwdriver to press the tabs on the GPIO header side off the PCB, and the RasPi will swing out of the case along the same path it went in.
For the heatsink, you can probably use something like an Xacto blade or other thin-bladed knife.
Return to “Adafruit Raspberry Pi® accessories”
