Raspberry Pi Camera Board v2
some_josh
Post by some_josh »
I recently puchased Raspberry Pi Zero W Camera Pack - Includes Pi Zero W[ID:3414] in Order 1805893
I imaged a new 32GB SanDisk microSDHC with 2018-06-27-raspbian-stretch-lite and put it in the Raspberry Pi Zero W.
Then I connected the camera board to the Raspberry Pi Zero W with the mini camera cable included in the kit.
I also connected a monitor via a miniHDMI adapter, a threee port USB hub with ethernet to the microUSB socket labeled "USB", and a 5V 2.5A power supply to the microUSB socket labeled "PWR". After boot up I used raspi-config to set localization and I enabeled the Raspberry Pi Camera.
I tried using raspistill to capture an image, but it didn't work. So I shutdown the Raspberry Pi and removed the power cable.
Then I removed the ribon cable from both ends and reattached the ribon cable again.
Then I checked the voltage at ic labeled U3 on the backside of the board and got 3.308 Volts.
I tried using the raspistill command
pi@node:~ $ raspistill -v -o test.jpg
mmal: Cannot read camera info, keeping the defaults for OV5647
raspistill Camera App v1.3.11
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled  no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Flicker Avoid Mode 'off'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
I shutdown the Raspberry Pi Zero W and then disconnected the power.
On an ESD safe mat I detached the camera board from the ribon cable and removed the camera module from the board.
Then I reattached the camera module to the board and felt a good snap as it connected.
I reattached the ribon cable to the camera board and then reattached power to the Raspberry Pi Zero W.
It rebooted normally and then I checked the power at the U3 chip on the back of the camera board and again got 3.308 V
I tried raspistill again
Opacity 255
then I tried the vcgencmd get_camera
pi@node:~ $ vcgencmd get_camera
supported=1 detected=0
adafruit_support_mike
Re: Raspberry Pi Camera Board v2
Post the output from `dmesg` after the RasPi boots with the camera attached please.
some_josh
Post by some_josh »
pi@node:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.52+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1123 Wed Jun 27 17:05:32 BST 2018
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 8 MiB at 0x17400000
[    0.000000] On node 0 totalpages: 98304
[    0.000000] free_area_init_node: node 0, pgdat c09c04f8, node_mem_map d7c8a400
[    0.000000]   Normal zone: 864 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 98304 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 97440
[    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:DE:29:BB vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=0315ca9b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 370300K/393216K available (6422K kernel code, 587K rwdata, 1988K rodata, 440K init, 677K bss, 14724K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xd8800000 - 0xff800000   ( 624 MB)
                   lowmem  : 0xc0000000 - 0xd8000000   ( 384 MB)
                   modules : 0xbf000000 - 0xc0000000   (  16 MB)
                     .text : 0xc0008000 - 0xc064ddac   (6424 kB)
                     .init : 0xc08ca000 - 0xc0938000   ( 440 kB)
                     .data : 0xc0938000 - 0xc09cae90   ( 588 kB)
                      .bss : 0xc09d07d0 - 0xc0a79d1c   ( 678 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] ftrace: allocating 24096 entries in 71 pages
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000031] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000074] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000167] bcm2835: system timer (irq = 27)
[    0.000728] Console: colour dummy device 80x30
[    0.001316] console [tty1] enabled
[    0.001368] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060343] pid_max: default: 32768 minimum: 301
[    0.060859] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060913] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.062236] Disabling memory control group subsystem
[    0.062458] CPU: Testing write buffer coherency: ok
[    0.063585] Setting up static identity map for 0x8200 - 0x8238
[    0.064858] devtmpfs: initialized
[    0.073761] random: get_random_u32 called from bucket_table_alloc+0x88/0x1c4 with crng_init=0
[    0.074661] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.075085] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.075158] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.076509] pinctrl core: initialized pinctrl subsystem
[    0.077895] NET: Registered protocol family 16
[    0.080883] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.087328] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.087397] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.087547] Serial: AMBA PL011 UART driver
[    0.090341] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.091207] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.130572] bcm2835-dma 20007000.dma: DMA legacy API manager at d880d000, dmachans=0x1
[    0.132951] SCSI subsystem initialized
[    0.133227] usbcore: registered new interface driver usbfs
[    0.133361] usbcore: registered new interface driver hub
[    0.133592] usbcore: registered new device driver usb
[    0.140837] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-07-03 14:21
[    0.142862] clocksource: Switched to clocksource timer
[    0.231407] VFS: Disk quotas dquot_6.6.0
[    0.231588] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.231907] FS-Cache: Loaded
[    0.232278] CacheFiles: Loaded
[    0.249432] NET: Registered protocol family 2
[    0.250669] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.250803] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.250921] TCP: Hash tables configured (established 4096 bind 4096)
[    0.251098] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.251158] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.251547] NET: Registered protocol family 1
[    0.252283] RPC: Registered named UNIX socket transport module.
[    0.252341] RPC: Registered udp transport module.
[    0.252368] RPC: Registered tcp transport module.
[    0.252391] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.254383] hw perfevents: no irqs for PMU, sampling events not supported
[    0.254509] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.258197] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.270227] FS-Cache: Netfs 'nfs' registered for caching
[    0.271587] NFS: Registering the id_resolver key type
[    0.271685] Key type id_resolver registered
[    0.271717] Key type id_legacy registered
[    0.271766] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.276535] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.277017] io scheduler noop registered
[    0.277069] io scheduler deadline registered (default)
[    0.277626] io scheduler cfq registered
[    0.277673] io scheduler mq-deadline registered
[    0.277702] io scheduler kyber registered
[    0.280028] BCM2708FB: allocated DMA memory 57500000
[    0.280141] BCM2708FB: allocated DMA channel 0 @ d880d000
[    0.312157] Console: switching to colour frame buffer device 160x64
[    0.339517] bcm2835-rng 20104000.rng: hwrng registered
[    0.339986] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    0.341374] vc-sm: Videocore shared memory driver
[    0.342212] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[    0.362535] brd: module loaded
[    0.375866] loop: module loaded
[    0.376053] Loading iSCSI transport class v2.0-870.
[    0.377148] usbcore: registered new interface driver smsc95xx
[    0.377408] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.606160] Core Release: 2.80a
[    0.606333] Setting default values for core params
[    0.606551] Finished setting default values for core params
[    0.807134] Using Buffer DMA mode
[    0.807305] Periodic Transfer Interrupt Enhancement - disabled
[    0.807518] Multiprocessor Interrupt Enhancement - disabled
[    0.807722] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.807975] Dedicated Tx FIFOs mode
[    0.809005] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xd7514000 dma = 0x57514000 len=9024
[    0.809379] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    0.810099] dwc_otg: Microframe scheduler enabled
[    0.810318] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc049a438
[    0.810557] WARN::hcd_init_fiq:460: FIQ ASM at 0xc049a714 length 36
[    0.810798] WARN::hcd_init_fiq:486: MPHI regs_base at 0xd88a5000
[    0.811106] dwc_otg 20980000.usb: DWC OTG Controller
[    0.811365] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    0.811700] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    0.820240] Init: Port Power? op_state=1
[    0.828502] Init: Power Port (0)
[    0.837159] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.845486] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.853793] usb usb1: Product: DWC OTG Controller
[    0.861907] usb usb1: Manufacturer: Linux 4.14.52+ dwc_otg_hcd
[    0.870137] usb usb1: SerialNumber: 20980000.usb
[    0.879464] hub 1-0:1.0: USB hub found
[    0.887908] hub 1-0:1.0: 1 port detected
[    0.897247] dwc_otg: FIQ enabled
[    0.897261] dwc_otg: NAK holdoff enabled
[    0.897267] dwc_otg: FIQ split-transaction FSM enabled
[    0.897288] Module dwc_common_port init
[    0.897819] usbcore: registered new interface driver usb-storage
[    0.906887] mousedev: PS/2 mouse device common for all mice
[    0.915388] IR NEC protocol handler initialized
[    0.923681] IR RC5(x/sz) protocol handler initialized
[    0.931770] IR RC6 protocol handler initialized
[    0.939899] IR JVC protocol handler initialized
[    0.947838] IR Sony protocol handler initialized
[    0.955806] IR SANYO protocol handler initialized
[    0.963706] IR Sharp protocol handler initialized
[    0.971577] IR MCE Keyboard/mouse protocol handler initialized
[    0.979430] IR XMP protocol handler initialized
[    0.988721] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.997302] bcm2835-cpufreq: min=700000 max=1000000
[    1.006242] sdhci: Secure Digital Host Controller Interface driver
[    1.014314] sdhci: Copyright(c) Pierre Ossman
[    1.023046] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
[    1.031932] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
[    1.040551] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.049494] ledtrig-cpu: registered to indicate activity on CPUs
[    1.058143] hidraw: raw HID events driver (C) Jiri Kosina
[    1.066755] usbcore: registered new interface driver usbhid
[    1.075120] usbhid: USB HID core driver
[    1.084299] vchiq: vchiq_init_state: slot_zero = d7580000, is_master = 0
[    1.094691] [vc_sm_connected_init]: start
[    1.107343] [vc_sm_connected_init]: end - returning 0
[    1.115820] Indeed it is in host mode hprt0 = 00021501
[    1.185531] Initializing XFRM netlink socket
[    1.193958] NET: Registered protocol family 17
[    1.202317] Key type dns_resolver registered
[    1.212770] registered taskstats version 1
[    1.229733] random: fast init done
[    1.241023] uart-pl011 20201000.serial: cts_event_workaround enabled
[    1.249461] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    1.261664] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[    1.270187] mmc-bcm2835 20300000.mmc: DMA channel allocated
[    1.334938] sdhost: log_buf @ d7513000 (57513000)
[    1.369867] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.378626] Indeed it is in host mode hprt0 = 00001101
[    1.457536] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.467499] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.477382] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.488635] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.502978] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.512757] of_cfs_init
[    1.541812] of_cfs_init: OK
[    1.551621] Waiting for root device PARTUUID=0315ca9b-02...
[    1.634102] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[    1.642112] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.650115] usb 1-1: Product: USB 2.0 Hub
[    1.659985] hub 1-1:1.0: USB hub found
[    1.669167] hub 1-1:1.0: 4 ports detected
[    1.686896] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.700997] mmc0: new high speed SDHC card at address aaaa
[    1.710625] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[    1.725658]  mmcblk0: p1 p2
[    1.735287] mmc1: new high speed SDIO card at address 0001
[    1.790835] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.799294] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.819538] devtmpfs: mounted
[    1.830620] Freeing unused kernel memory: 440K
[    1.838849] This architecture does not have kernel memory protection.
[    1.992995] usb 1-1.1: new low-speed USB device number 3 using dwc_otg
[    2.170682] usb 1-1.1: New USB device found, idVendor=046e, idProduct=5542
[    2.179264] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.187712] usb 1-1.1: Product: USB M ultimedia Keyboard
[    2.196046] usb 1-1.1: Manufacturer: BANNED
[    2.241641] input: BANNED USB Multimedi Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:046E:5542.0001/input/input0
[    2.314061] hid-generic 0003:046E:5542.0001: input,hidraw0: USB HID v1.10 Keyboard [BANNED USB Multimedi Keyboard] on usb-20980000.usb-1.1/input0
[    2.377015] input: BANNED USB Multimedi Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:046E:5542.0002/input/input1
[    2.453909] hid-generic 0003:046E:5542.0002: input,hiddev96,hidraw1: USB HID v1.10 Device [BANNED USB Multimedi Keyboard] on usb-20980000.usb-1.1/input1
[    2.469772] systemd[1]: System time before build time, advancing clock.
[    2.562995] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    2.654275] NET: Registered protocol family 10
[    2.666393] Segment Routing with IPv6
[    2.692596] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.705218] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8152
[    2.714823] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.724377] usb 1-1.2: Product: USB 10/100 LAN
[    2.733777] usb 1-1.2: Manufacturer: Realtek
[    2.743080] usb 1-1.2: SerialNumber: 00E04A379BCB
[    2.779969] random: systemd: uninitialized urandom read (16 bytes read)
[    2.801498] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +BANNED +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    2.822744] systemd[1]: Detected architecture arm.
[    2.871222] systemd[1]: Set hostname to <node>.
[    2.953370] random: systemd: uninitialized urandom read (16 bytes read)
[    3.189541] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[    4.032485] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.055763] systemd[1]: Listening on udev Kernel Socket.
[    4.078223] systemd[1]: Listening on Syslog Socket.
[    4.101746] systemd[1]: Created slice User and Session Slice.
[    4.124300] systemd[1]: Listening on udev Control Socket.
[    4.148243] systemd[1]: Created slice System Slice.
[    4.172624] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[   22.440539] random: crng init done
[   22.440568] random: 7 urandom warning(s) missed due to ratelimiting
[   58.507579] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   58.947928] systemd-journald[73]: Received request to flush runtime journal from PID 1
[   62.183402] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[   62.206082] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[   62.206580] usbcore: registered new interface driver brcmfmac
[   62.286667] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[   62.482260] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[   62.615231] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[   62.616824] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[   64.632111] usbcore: registered new interface driver r8152
[   64.723028] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[   64.850248] usbcore: registered new interface driver cdc_ether
[   64.898512] r8152 1-1.2:1.0 eth0: v1.09.9
[   67.765180] uart-pl011 20201000.serial: no DMA platform data
[   69.752670] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   70.671460] r8152 1-1.2:1.0 enx00e04a379bcb: renamed from eth0
[   71.457522] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   71.457565] brcmfmac: power management disabled
[   72.018032] IPv6: ADDRCONF(NETDEV_UP): enx00e04a379bcb: link is not ready
[   72.037140] r8152 1-1.2:1.0 enx00e04a379bcb: carrier on
[   72.037361] IPv6: ADDRCONF(NETDEV_CHANGE): enx00e04a379bcb: link becomes ready
[   72.249939] Bluetooth: Core ver 2.22
[   72.250105] NET: Registered protocol family 31
[   72.250113] Bluetooth: HCI device and connection manager initialized
[   72.250140] Bluetooth: HCI socket layer initialized
[   72.250155] Bluetooth: L2CAP socket layer initialized
[   72.250203] Bluetooth: SCO socket layer initialized
[   72.287309] Bluetooth: HCI UART driver ver 2.3
[   72.287326] Bluetooth: HCI UART protocol H4 registered
[   72.287334] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   72.294026] Bluetooth: HCI UART protocol Broadcom registered
[   72.463361] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   72.856305] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   72.856320] Bluetooth: BNEP filters: protocol multicast
[   72.856352] Bluetooth: BNEP socket layer initialized
pi@node:~ $
Thank you. That doesn't show any sign of a connection between the CPU and the camera.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement Pi Camera.
