apt.adafruit.com down
by jackw01 on Sat Aug 18, 2018 12:49 pm
I am not able to run
sudo apt-get update
on my Raspberry Pi because the apt repository at apt.adafruit.com seems to be down.
jackw01
Re: apt.adafruit.com down
by adafruit_support_mike on Sat Aug 18, 2018 3:51 pm
We shut down that server a couple of weeks ago, and should have updated all the tutorials that use it.
If you found a page we missed, please post the URL and we’ll correct it.
by jackw01 on Sat Aug 18, 2018 4:00 pm
How do I find out which packages my Pi were downloaded from the Adafruit repository and configure apt not to use apt.adafruit.com in the future?
jackw01
by adafruit_support_mike on Mon Aug 20, 2018 3:56 am
All of the packages should be in the main servers by now. Just remove 'apt.adafruit.com' from the file /etc/apt/sources.list
by johne3819 on Tue Aug 21, 2018 5:53 pm
I have looked everywhere and there is no right answer i can find, how do I do the command
sudo apt-get install raspberrypi-bootloader adafruit-pitft-helper raspberrypi-kernel
and not get an error. The apt.adafruit.com repository is gone, everywhere says the main repositories should have it. I can't find it Please help!
Oh and your documentation on the pitftplus really sucks for the buttons,
johne3819
by johne3819 on Tue Aug 21, 2018 6:00 pm
adafruit_support_mike wrote:We shut down that server a couple of weeks ago, and should have updated all the tutorials that use it.
Every tutorial i see has the old repository information in it.
johne3819
by adafruit_support_mike on Thu Aug 23, 2018 12:08 am
Could you post some links please?
by matts_11432 on Tue Oct 02, 2018 12:12 pm
The GitHub for Adafruit Occidentalis still references it in the readme. https://github.com/adafruit/Adafruit-Occidentalis
Also, this tutorial probably shouldn't exist: https://learn.adafruit.com/apt-adafruit-com/overiew
I see that the Occidentalis project hasn't been updated at all in a while, I'm guessing there are newer methods to do the same things now.
matts_11432
by adafruit_support_mike on Wed Oct 03, 2018 1:16 am
We keep all of our older tutorials for historical reasons, but try to add notes to the ones that are outdated and no longer supported.
I'll let the web team know about those so we can add warnings if necessary. Thanks!
by phoggberg on Wed Oct 03, 2018 11:04 am
I love using Occidentalis, it was a great program, because I often take my raspberry pi on the road, and changing between my onboard vehicle's WiFi and the Hotel's WiFi, or a client's WiFi couldn't be easier. I even developed a script keeping various sites SSID & Password in encrypted compressed backup files. Then just run the script and it decompresses, decrypts, and copies to /boot/Occidentalis.txt, then just reboot. Easy Peasy switching. Why did you drop it? I find it one of the most useful utilities. Also your install Occidentalis make setup of a new pi easier. You should bring them back into support. Find My Pi is also useful when you have 5 or 10 pi's on your network.
phoggberg
by adafruit2 on Wed Oct 03, 2018 12:03 pm
we'll let the author know and figure out another way of supporting it!
adafruit2
Site Admin
by phoggberg on Thu Oct 04, 2018 4:34 pm
Thanks. And thank you for the quick response
phoggberg
by bpb on Mon Oct 08, 2018 1:28 pm
Hi phoggberg - I've ported occi over to our Raspberry-Pi-Installer-Scripts repo and added support for installing system-wide with a systemd unit file instead of the old init script. You can install this version with:
git clone https://github.com/adafruit/Raspberry-Pi-Installer-Scripts.git
cd Raspberry-Pi-Installer-Scripts
sudo ./occi --install
In general, it should work the same as the previous version of the utility.
bpb
cron
