Invalid Syntax strip.setPixelColor
by wx4tcc on Wed Oct 10, 2018 1:21 pm
Using this code below I have ran into an error at the bottom of the code. I am given an invalid syntax error for strip.setPixelColor(i, color))
Any suggestions?
import urllib2
import xml.etree.ElementTree as ET
import time
from neopixel import *
import sys
import os
# LED strip configuration:
LED_COUNT      = 50      # Number of LED pixels.
LED_PIN        = 18      # GPIO pin connected to the pixels (18 uses PWM!).
#LED_PIN        = 10      # GPIO pin connected to the pixels (10 uses SPI /dev/spidev0.0).
LED_FREQ_HZ    = 800000  # LED signal frequency in hertz (usually 800khz)
LED_DMA        = 5       # DMA channel to use for generating signal (try 5)
LED_BRIGHTNESS = 128     # Set to 0 for darkest and 255 for brightest
LED_INVERT     = False   # True to invert the signal (when using NPN transistor level shift)
LED_CHANNEL    = 0       # set to '1' for GPIOs 13, 19, 41, 45 or 53
LED_STRIP      = ws.WS2811_STRIP_GRB   # Strip type and colour ordering
def wheel(pos):
        """Generate rainbow colors across 0-255 positions."""
        if pos < 85:
                return Color(pos * 3, 255 - pos * 3, 0)
        elif pos < 170:
                pos -= 85
                return Color(255 - pos * 3, 0, pos * 3)
        else:
                pos -= 170
                return Color(0, pos * 3, 255 - pos * 3)
def rainbowCycle(strip, wait_ms=2, iterations=1):
        """Draw rainbow that uniformly distributes itself across all pixels."""
        for j in range(256*iterations):
                for i in range(strip.numPixels()):
                        strip.setPixelColor(i, wheel((int(i * 256 / strip.numPixels()) + j) & 255))
                strip.show()
                #time.sleep(wait_ms/1000.0)
strip = Adafruit_NeoPixel(LED_COUNT, LED_PIN, LED_FREQ_HZ, LED_DMA, LED_INVERT, LED_BRIGHTNESS, LED_CHANNEL, LED_STRIP)
strip.begin()
with open("/NeoSectional/airports") as f:
    airports = f.readlines()
airports = [x.strip() for x in airports]
print airports
mydict = {
url = "https://www.aviationweather.gov/adds/dataserver_current/httpparam?dataSource=metars&requestType=retrieve&format=xml&hoursBeforeNow=1.5&stationString="
for airportcode in airports:
   if airportcode == "NULL":
      continue
   print airportcode
   url = url + airportcode + ","
print url
content = urllib2.urlopen(url).read()
print content
root = ET.fromstring(content)
for metar in root.iter('METAR'):
      continue
   stationId = metar.find('station_id').text
   print stationId
   if metar.find('flight_category') is None:
      print "Skipping"
      continue
   flightCateory = metar.find('flight_category').text
   print stationId + " " + flightCateory
   if stationId in mydict:
      print "duplicate, only save first metar"
   else:
      mydict[stationId] = flightCateory
print mydict
rainbowCycle(strip)
i = 0
      i = i +1
      continue
   print
   color = Color(0,0,0)
   flightCateory = mydict.get(airportcode,"No")
   print airportcode + " " + flightCateory
   if  flightCateory != "No":
      if flightCateory == "VFR":
         print "VFR"
         color = Color(255,0,0)
      elif flightCateory == "MVFR":
         color = Color(0,0,255)
         print "MVFR"
      elif flightCateory == "IFR":
         color = Color(0,255,0)
         print "IFR"
      elif flightCateory == "LIFR":
         color = Color(0,128,128)
         print "LIFR"
   else:
      color = Color(255,255,255)
      print "N/A"
   print "Setting light " + str(i) + " for " + airportcode + " " + flightCateory + " " + str(color)
   strip.show()
   i = i+1
print
print "fin"
wx4tcc
