Hello after installing an adafruit 2.2" screen using the following tutorial
https://learn.adafruit.com/adafruit-2-2 ... spberry-pi
the raspberry 3b gets stuck booting, With rc-local.service Stuck on the hdmi screen. And the 2.2" just glowing white.
Need help as soon as possible, and thanks for stoping by to read!
Raspbery pi 3b stuck on boot after installing a 2.2" adafrui
- somerandomguy412
Last edited by somerandomguy412 on Sun Oct 14, 2018 6:44 pm, edited 1 time in total.
- Franklin97355
Re: Raspbery pi 3b wont boot after installing a 2.2" adafrui
Does it boot without the screen and will it boot if you use a fresh copy of the OS downloaded from the Raspberry Pi site?
- somerandomguy412
if i try without the HDMI screen, then the 2.2" adafruit screen is just white,
It did boot fine with the raspbian OS before. I dont wanna Reflash it, Since i do have important stuff on the SD card, :/
*edit, i have an other SD card that i flashed with a fresh OS, and it works fine, But i still want my important files from the other SD card, :x
- somerandomguy412
Re: Raspbery pi 3b stuck on boot after installing a 2.2" ada
Alright update, after i put "init=/bin/s" in the cmdline.txt of the sd card, i manged to edit the rc.local file using this command
"mount -o remount,rw /dev/sda1"
and now i could edit the file! yays
but now when i try to boot the Raspbery pi, it gets stuck on
systemd-user-session.service
lol
lol
- adafruit_support_carter
Just to verify - everything works with the display if you start fresh and follow the guide?*edit, i have an other SD card that i flashed with a fresh OS, and it works fine, But i still want my important files from the other SD card, :x
What is the version of Raspbian you are working with on the problematic SD card?
- somerandomguy412
The HDMI display works fine with a new reflashed SD card, The small 2.2" screen does not,adafruit_support_carter wrote:Just to verify - everything works with the display if you start fresh and follow the guide?*edit, i have an other SD card that i flashed with a fresh OS, and it works fine, But i still want my important files from the other SD card, :x
RASPBIAN STRETCH WITH DESKTOP
Image with desktop based on Debian Stretch
Version:October 2018
Release date:2018-10-09
Kernel version:4.14
Let's continue troubleshooting with the second SD card. You've already linked to this, but make sure you're following these instructions:
https://learn.adafruit.com/adafruit-2-2 ... sy-install
and also note the specific version of Raspbian from March 13, 2018.
Can you start over and capture your running of the script and post the contents here. Similar to this:
viewtopic.php?f=47&t=139845#p700117
