Adafruit PiTFT 2.8" Touchscreen Display
- fluxxion
I have the 2.8" PiTFT Touchscreen Display (https://www.adafruit.com/product/1601) and I followed the easy install instructions (https://learn.adafruit.com/adafruit-pit ... -install-2) and everything is fine (I can see the desktop and everything), except that I can't use the display as a touchscreen. Shouldn't I be able to move the mouse or whatever with my finger? Why is it only the resistive touchscreen that needs touch calibrated? Did I maybe not get a touchscreen display?
Re: Adafruit PiTFT 2.8" Touchscreen Display
Post a photo showing the back of the PiTFT where the flex cable comes through the slot please, plus the output from `dmesg`.
800x600 images usually work best, and it's much easier to scan the message dump when it's between CODE tags.
- fluxxion
Here is the output of 'dmesg'. I'll post a pic in a couple min.
pi@raspberrypi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.14.71-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1145 SMP Fri Sep 21 15:38:35 BST 2018
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] free_area_init_node: node 0, pgdat 80c85280, node_mem_map ba39f000
[ 0.000000] Normal zone: 2133 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 242688 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 17 pages/cpu @ba348000 s38720 r8192 d22720 u69632
[ 0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: bcm2708_fb.fbwidth=480 bcm2708_fb.fbheight=640 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=3804e8ef-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 940232K/970752K available (7168K kernel code, 576K rwdata, 2076K rodata, 1024K init, 698K bss, 22328K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80b00000 - 0x80c00000 (1024 kB)
.data : 0x80c00000 - 0x80c9017c ( 577 kB)
.bss : 0x80c97f10 - 0x80d468b0 ( 699 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 25273 entries in 75 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000025] Switching to timer-based delay loop, resolution 52ns
[ 0.000338] Console: colour dummy device 80x30
[ 0.000360] console [tty1] enabled
[ 0.000391] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000411] pid_max: default: 32768 minimum: 301
[ 0.000813] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000834] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002057] Disabling memory control group subsystem
[ 0.002182] CPU: Testing write buffer coherency: ok
[ 0.002797] CPU0: update cpu_capacity 1024
[ 0.002809] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.003440] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003629] Hierarchical SRCU implementation.
[ 0.004678] smp: Bringing up secondary CPUs ...
[ 0.005865] CPU1: update cpu_capacity 1024
[ 0.005877] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.007150] CPU2: update cpu_capacity 1024
[ 0.007161] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.008398] CPU3: update cpu_capacity 1024
[ 0.008409] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.008562] smp: Brought up 1 node, 4 CPUs
[ 0.008577] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.008584] CPU: All CPU(s) started in HYP mode.
[ 0.008590] CPU: Virtualization extensions available.
[ 0.009804] devtmpfs: initialized
[ 0.022960] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
[ 0.023885] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.024230] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.024257] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.025072] pinctrl core: initialized pinctrl subsystem
[ 0.026186] NET: Registered protocol family 16
[ 0.029531] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.036046] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.036060] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.036327] Serial: AMBA PL011 UART driver
[ 0.038614] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.081635] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
[ 0.083593] SCSI subsystem initialized
[ 0.083921] usbcore: registered new interface driver usbfs
[ 0.083997] usbcore: registered new interface driver hub
[ 0.084144] usbcore: registered new device driver usb
[ 0.090372] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-09-21 15:43
[ 0.092235] clocksource: Switched to clocksource arch_sys_counter
[ 0.180214] VFS: Disk quotas dquot_6.6.0
[ 0.180339] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.180596] FS-Cache: Loaded
[ 0.180910] CacheFiles: Loaded
[ 0.194236] NET: Registered protocol family 2
[ 0.195244] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.195375] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.195564] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.195739] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.195801] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.196120] NET: Registered protocol family 1
[ 0.196829] RPC: Registered named UNIX socket transport module.
[ 0.196840] RPC: Registered udp transport module.
[ 0.196845] RPC: Registered tcp transport module.
[ 0.196852] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.198909] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.202896] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.213927] FS-Cache: Netfs 'nfs' registered for caching
[ 0.214845] NFS: Registering the id_resolver key type
[ 0.214887] Key type id_resolver registered
[ 0.214894] Key type id_legacy registered
[ 0.214915] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.217812] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.218036] io scheduler noop registered
[ 0.218046] io scheduler deadline registered (default)
[ 0.218448] io scheduler cfq registered
[ 0.218458] io scheduler mq-deadline registered
[ 0.218466] io scheduler kyber registered
[ 0.220767] BCM2708FB: allocated DMA memory fad00000
[ 0.220812] BCM2708FB: allocated DMA channel 0 @ bb813000
[ 0.237435] Console: switching to colour frame buffer device 60x40
[ 0.247459] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.247625] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.248300] vc-sm: Videocore shared memory driver
[ 0.248719] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.263486] brd: module loaded
[ 0.275793] loop: module loaded
[ 0.275811] Loading iSCSI transport class v2.0-870.
[ 0.276720] libphy: Fixed MDIO Bus: probed
[ 0.276853] usbcore: registered new interface driver lan78xx
[ 0.276937] usbcore: registered new interface driver smsc95xx
[ 0.276958] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.304938] dwc_otg 3f980000.usb: base=0xf0980000
[ 0.452226] NOHZ: local_softirq_pending 80
[ 0.472226] NOHZ: local_softirq_pending 80
[ 0.492225] NOHZ: local_softirq_pending 80
[ 0.505257] Core Release: 2.80a
[ 0.505271] Setting default values for core params
[ 0.505313] Finished setting default values for core params
[ 0.705661] Using Buffer DMA mode
[ 0.705670] Periodic Transfer Interrupt Enhancement - disabled
[ 0.705676] Multiprocessor Interrupt Enhancement - disabled
[ 0.705685] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.705699] Dedicated Tx FIFOs mode
[ 0.706214] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad14000 dma = 0xfad14000 len=9024
[ 0.706245] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.706254] dwc_otg: Microframe scheduler enabled
[ 0.706327] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805e9c5c
[ 0.706342] WARN::hcd_init_fiq:460: FIQ ASM at 0x805e9fc4 length 36
[ 0.706357] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[ 0.706430] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.706473] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.706520] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 0.706571] Init: Port Power? op_state=1
[ 0.706578] Init: Power Port (0)
[ 0.706882] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.706898] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.706909] usb usb1: Product: DWC OTG Controller
[ 0.706920] usb usb1: Manufacturer: Linux 4.14.71-v7+ dwc_otg_hcd
[ 0.706930] usb usb1: SerialNumber: 3f980000.usb
[ 0.707795] hub 1-0:1.0: USB hub found
[ 0.707858] hub 1-0:1.0: 1 port detected
[ 0.708613] dwc_otg: FIQ enabled
[ 0.708621] dwc_otg: NAK holdoff enabled
[ 0.708627] dwc_otg: FIQ split-transaction FSM enabled
[ 0.708641] Module dwc_common_port init
[ 0.709040] usbcore: registered new interface driver usb-storage
[ 0.709316] mousedev: PS/2 mouse device common for all mice
[ 0.709403] IR NEC protocol handler initialized
[ 0.709410] IR RC5(x/sz) protocol handler initialized
[ 0.709416] IR RC6 protocol handler initialized
[ 0.709422] IR JVC protocol handler initialized
[ 0.709428] IR Sony protocol handler initialized
[ 0.709433] IR SANYO protocol handler initialized
[ 0.709439] IR Sharp protocol handler initialized
[ 0.709445] IR MCE Keyboard/mouse protocol handler initialized
[ 0.709450] IR XMP protocol handler initialized
[ 0.710377] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.710702] bcm2835-cpufreq: min=600000 max=900000
[ 0.711142] sdhci: Secure Digital Host Controller Interface driver
[ 0.711149] sdhci: Copyright(c) Pierre Ossman
[ 0.711618] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.711778] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.712620] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.712806] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.712996] usbcore: registered new interface driver usbhid
[ 0.713002] usbhid: USB HID core driver
[ 0.713783] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
[ 0.715541] [vc_sm_connected_init]: start
[ 0.724427] [vc_sm_connected_init]: end - returning 0
[ 0.725185] Initializing XFRM netlink socket
[ 0.725219] NET: Registered protocol family 17
[ 0.725353] Key type dns_resolver registered
[ 0.725870] Registering SWP/SWPB emulation handler
[ 0.726765] registered taskstats version 1
[ 0.734402] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.734505] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.734574] console [ttyAMA0] enabled
[ 0.737129] sdhost: log_buf @ bad13000 (fad13000)
[ 0.812277] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.813751] of_cfs_init
[ 0.813921] of_cfs_init: OK
[ 0.814748] Waiting for root device PARTUUID=3804e8ef-02...
[ 0.922385] Indeed it is in host mode hprt0 = 00021501
[ 0.992734] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.996161] mmc0: new high speed SDXC card at address aaaa
[ 0.996943] mmcblk0: mmc0:aaaa SL128 119 GiB
[ 1.000325] mmcblk0: p1 p2
[ 1.013926] random: fast init done
[ 1.037321] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.037400] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.040523] devtmpfs: mounted
[ 1.044473] Freeing unused kernel memory: 1024K
[ 1.114316] NOHZ: local_softirq_pending 40
[ 1.123556] NOHZ: local_softirq_pending 40
[ 1.132291] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.132501] Indeed it is in host mode hprt0 = 00001101
[ 1.199215] NOHZ: local_softirq_pending 40
[ 1.204096] NOHZ: local_softirq_pending 40
[ 1.209592] NOHZ: local_softirq_pending 40
[ 1.220582] NOHZ: local_softirq_pending 40
[ 1.304213] NOHZ: local_softirq_pending 40
[ 1.372660] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.372681] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.373765] hub 1-1:1.0: USB hub found
[ 1.373876] hub 1-1:1.0: 5 ports detected
[ 1.515248] systemd[1]: System time before build time, advancing clock.
[ 1.639444] NET: Registered protocol family 10
[ 1.640924] Segment Routing with IPv6
[ 1.653556] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.673639] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.680830] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +BANNED +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 1.681628] systemd[1]: Detected architecture arm.
[ 1.684883] systemd[1]: Set hostname to <raspberrypi>.
[ 1.692314] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.734677] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.756808] uart-pl011 3f201000.serial: no DMA platform data
[ 1.782390] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
[ 1.822709] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.822731] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.825755] smsc95xx v1.0.6
[ 1.926755] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:56:f0:2f
[ 2.022300] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
[ 2.169437] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b
[ 2.169458] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.169469] usb 1-1.4: Product: USB Receiver
[ 2.169479] usb 1-1.4: Manufacturer: Logitech
[ 2.256620] systemd[1]: Listening on udev Kernel Socket.
[ 2.257552] systemd[1]: Listening on udev Control Socket.
[ 2.257924] systemd[1]: Listening on Syslog Socket.
[ 2.258255] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.259324] systemd[1]: Created slice User and Session Slice.
[ 2.259831] systemd[1]: Listening on Journal Socket.
[ 2.261096] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.292369] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
[ 2.425374] usb 1-1.5: New USB device found, idVendor=7392, idProduct=7811
[ 2.425408] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.425424] usb 1-1.5: Product: 802.11n WLAN Adapter
[ 2.425435] usb 1-1.5: Manufacturer: Realtek
[ 2.425450] usb 1-1.5: SerialNumber: 00e04c000001
[ 2.435397] i2c /dev entries driver
[ 3.305820] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.328321] usbcore: registered new interface driver rtl8192cu
[ 3.425202] systemd-journald[83]: Received request to flush runtime journal from PID 1
[ 4.027219] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.031184] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[ 4.299516] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.4/input2
[ 4.836681] input: Logitech M185 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:4008.0004/input/input0
[ 4.847247] logitech-hidpp-device 0003:046D:4008.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech M185] on usb-3f980000.usb-1.4:1
[ 4.864003] input: Logitech K270 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:4003.0005/input/input1
[ 4.865780] logitech-hidpp-device 0003:046D:4003.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K270] on usb-3f980000.usb-1.4:2
[ 4.897549] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.905870] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.907415] fbtft_of_value: buswidth = 8
[ 4.907435] fbtft_of_value: debug = 0
[ 4.907444] fbtft_of_value: rotate = 90
[ 4.907454] fbtft_of_value: fps = 30
[ 4.946191] edt_ft5x06 1-0038: touchscreen probe failed
[ 4.946251] edt_ft5x06: probe of 1-0038 failed with error -121
[ 5.105729] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB buffer memory, fps=33, spi0.0 at 64 MHz
[ 6.267565] random: crng init done
[ 6.267587] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.838362] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.157250] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 7.157837] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.645671] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 12.550307] fuse init (API version 7.26)
[ 28.460194] logitech-hidpp-device 0003:046D:4008.0004: HID++ 2.0 device connected.
[ 59.278136] logitech-hidpp-device 0003:046D:4003.0005: HID++ 2.0 device connected.
[ 104.330478] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
pi@raspberrypi:~ $
- fluxxion
And here is the picture...
- pitft_600x800.jpg (236.46 KiB) Viewed 100 times
Thank you.
The dmesg trace says you installed support for the FT6206 capacitive touchscreen controller, but that PiTFT uses the STMPE610 resistive touchscreen sensor. Try re-running the setup script and using the resistive option.
- fluxxion
Oh...yeah I thought I had a capacitive touchscreen. I'll try setting up as the resistive touch. Thanks a bunch!
