I2S recording combined with I2S Playback
by besi on Tue Nov 06, 2018 7:32 pm
I am cross-posting my thread here because after hours of searching and debugging I haven't found a solution to my problem https://raspberrypi.stackexchange.com/questions/90647/i2s-recording-combined-with-i2s-playback
I have a Raspberry Pi Zero and I am using the Adafruit I2S MEMS Microphone together with the ADAFRUIT I2S 3W CLASS D AMPLIFIER BREAKOUT - MAX98357A
https://www.adafruit.com/product/3421
https://www.adafruit.com/product/3006
I did follow the two respective tutorials and I got both the mic and the speaker working. However, I do need to disable the microphone or the amp + speaker won't work.
There seems to be a conflict regarding the I2S bus.
According to this forum post https://www.raspberrypi.org/forums/viewtopic.php?t=183617#p1385657 it can be done.
This is my setup:
I have the following `/etc/modules`:
i2c-dev
snd-bcm2835
my_loader
The `/boot/config.txt` looks like so:
dtparam=i2s=on
dtparam=audio=on
dtoverlay=hifiberry-dac
dtoverlay=i2s-mmap
This is what I see in `dmesg` when I have both the mic and the amplifier enabled:
[   13.039895] asoc-simple-card asoc-simple-card.0: snd-soc-dummy-dai <-> 20203000.i2s mapping ok
[   13.660674] bcm2835-i2s 20203000.i2s: **Trying to bind component to card "snd_rpi_hifiberry_dac" but is already bound to card "snd_rpi_simple_card"**
[   13.660700]  snd-hifiberry-dac soc:sound: ASoC: failed to instantiate card -19
[    13.661278] snd-hifiberry-dac soc:sound: snd_soc_register_card() failed: -19
Contradictings instructions
The two adafruit tutorials for the mic and the amp are conflicting. The mic tutorial tells me to enable the snd-bcm2835 module:
https://learn.adafruit.com/adafruit-i2s-mems-microphone-breakout
Add `snd-bcm2835` on its own line, to the modules file as shown below
While the amp tutorial tells me to disable the module:
https://learn.adafruit.com/adafruit-max98357-i2s-class-d-mono-amp
However, if you see the following line:
snd_bcm2835
Put a `#` in front of it
Please note the different typing using both a dash and an underscore `snd_bcm2835` vs. `snd-bcm2835`.
So my question, is it possible to combine the mic and the mono amp alongside each other. And if so how can this be configured.
besi
Re: I2S recording combined with I2S Playback
by adafruit_support_mike on Wed Nov 07, 2018 1:25 am
It is possible for the mic and speaker amp to work together, but they have to be on different channels.. one left, one right.
Post a photo showing your actual hardware and connections and we'll take a look. Schematics only show how things are supposed to work, not how things really are. 800x600 images usually work best.
by besi on Wed Nov 07, 2018 5:28 am
Hello Mike, thanks for your quick response.
There was in fact an error in the schematics. I did also update the colours of the wires. And you can see that the white and purple are shared between both boards (See updated schematics above, which should now be accurate).
Pi Zero
Mic
Amp
Can you also comment regarding the snd_bcm2835 module. Does this have to be enabled or disabled?
Could it be a problem that the two boards have different voltage levels but the same clock and data signals?
besi
