PiTFT with Pi-hole not working
by jasonaylward on Thu Oct 24, 2019 10:52 am
Hi. I recently bought the Pi-hole setup and I seem to be having trouble getting the PiTFT working. It's obviously getting a text from the pi but it's all broken up and unreadable.
I saw one tech page about some little black tags being pushed in all the way. It underside of the PiTFT appears to look just like it's supposed to.
Any ideas?
Photo of the screen
jasonaylward
Re: PiTFT with Pi-hole not working
by franklin97355 on Thu Oct 24, 2019 1:36 pm
Which Pi are you using and what version of the operating system? Can we see a picture of the back of the display?
franklin97355
by jasonaylward on Thu Oct 24, 2019 2:21 pm
It's the Raspberry Pi 3, Model B using the most recent version of Raspbian Lite.
jasonaylward
by jasonaylward on Thu Oct 24, 2019 2:22 pm
Sorry. Didn't realize it was upside-down until it was too late :)
jasonaylward
by franklin97355 on Thu Oct 24, 2019 2:42 pm
That's OK. Check the clip on the left side of the cable in the picture to make sure it is tight. If that does not fix the problem send a note to support@adafruit.com with a link to this thread and they will get you a replacement display.
franklin97355
by jasonaylward on Thu Oct 24, 2019 2:49 pm
Thanks for your help!
jasonaylward
by jasonaylward on Sat Nov 02, 2019 9:11 am
Hi Franklin. I got a new PiTLT in the mail this week and I'm seeing exactly the same noisiness on the screen.
Is this a problem with these units?
I've attached photos of the new unit plugged into the raspberry pi running pi-hole.
jasonaylward
by adafruit2 on Sat Nov 02, 2019 1:13 pm
hiya could be something changed in our setup code - can you re-run the pitft setup script and post a screenshot/paste text of the output?
adafruit2
Site Admin
by adafruit_support_carter on Mon Nov 04, 2019 12:43 pm
FWIW - Installer script seems to be OK. I just burned fresh copy of 2019-09-26 Raspbian Lite, booted on a 3B+, and ran through script:
https://learn.adafruit.com/adafruit-pit ... -install-2
Select 1 for screen, 3 for rotation, YES for show console, reboot. Worked fine.
@jasonaylward Were you following this?
https://learn.adafruit.com/pi-hole-ad-p ... ation-4-10
which shows setup for a different screen.
by jasonaylward on Wed Nov 06, 2019 9:11 am
Sorry for the delay. I was away from the computer over the weekend.
@carter, yeah, Those were the directions I was following but I didn't realize it was for a different screen. I wasn't paying attention to screen dimensions.
I'll try to re-run the config and see if that helps. I'm guessing that was the problem all along.
jasonaylward
by jasonaylward on Thu Nov 07, 2019 12:11 am
Update: that was totally it. I had the wrong display.
Thanks. And I'm really sorry you all had to send out a new PiTLT. It was totally not my intention.
Thanks again.
jasonaylward
by adafruit_support_carter on Thu Nov 07, 2019 12:38 pm
Oh well. At least now we know. Glad it's all working.
by gregn on Mon Nov 11, 2019 10:33 am
I just set up a pi-hole with the same kit and had the same problem for the same reason--I didn't pay attention to which display I had when making the selection during PiTFT software installation and just blindly followed the wrong guide, selecting option 4 instead of 1. Thank you very much for documenting the problem and solution in this thread. I just re-installed the software and selected display option 1 and now everything works perfectly.
gregn
by adafruit_support_carter on Mon Nov 11, 2019 12:55 pm
We updated the guide (a few days ago?) to clarify the specific display being used. Hopefully that'll help make it more clear what options to pick for the TFT that comes with the kit.
