Play Wav/Mp3 through Voice Bonnet Speaker
by piornet on Sun Feb 14, 2021 12:41 am
Hi! I'm trying to play an audio file through the voice bonnet, but having problems. I'm using it on an Rpi4 - not sure how to configure playback through the speakers connected to the bonnet. Any help would be appreciated. I'm using Pygame, but not married to it - just need to figure out a way to get it play through the attached speakers.
Thanks so much!
piornet
Re: Play Wav/Mp3 through Voice Bonnet Speaker
by mikeysklar on Mon Feb 15, 2021 6:05 pm
piornet,
Did you follow our guide for the Voice Bonnet setup on your Pi4?
https://learn.adafruit.com/adafruit-voi ... y-pi-setup
mikeysklar
by piornet on Fri Feb 19, 2021 12:48 pm
Yes, and I was able to hear the sounds. But when I try playing a WAV file through pygame, I don't hear anything. (I've double-checked to make sure the audio switch is set to ON).
I'm using an RPi4 so the bonnet is card 2.
piornet
by mikeysklar on Mon Feb 22, 2021 6:40 pm
I noticed on our pygame examples we are providing MP3 files. Are you able to play those?
https://learn.adafruit.com/adafruit-spe ... ith-pygame
Are you using pygameMP3.py we provide?
''' pg_midi_sound101.py
play midi music files (also mp3 files) using pygame
tested with Python273/331 and pygame192 by vegaseat
#code modified by James DeVito from here: https://www.daniweb.com/programming/software-development/code/454835/let-pygame-play-your-midi-or-mp3-files
#!/usr/bin/python
import sys
import pygame as pg
import os
import time
def play_music(music_file):
    stream music with mixer.music module in blocking manner
    this will stream the sound from disk while playing
    clock = pg.time.Clock()
    try:
        pg.mixer.music.load(music_file)
        print("Music file {} loaded!".format(music_file))
    except pygame.error:
        print("File {} not found! {}".format(music_file, pg.get_error()))
        return
    pg.mixer.music.play()
    # If you want to fade in the audio...
    # for x in range(0,100):
    #     pg.mixer.music.set_volume(float(x)/100.0)
    #     time.sleep(.0075)
    # # check if playback has finished
    while pg.mixer.music.get_busy():
        clock.tick(30)
freq = 44100    # audio CD quality
bitsize = -16   # unsigned 16 bit
channels = 2    # 1 is mono, 2 is stereo
buffer = 2048   # number of samples (experiment to get right sound)
pg.mixer.init(freq, bitsize, channels, buffer)
if len(sys.argv) > 1:
    try:
        user_volume = float(sys.argv[1])
    except ValueError:
        print "Volume argument invalid. Please use a float (0.0 - 1.0)"
        pg.mixer.music.fadeout(1000)
        pg.mixer.music.stop()
        raise SystemExit
    print("Playing at volume: " + str(user_volume)+ "\n")
    pg.mixer.music.set_volume(user_volume)
    mp3s = []
    for file in os.listdir("."):
        if file.endswith(".mp3"):
            mp3s.append(file)
    print mp3s
    for x in mp3s:
        try:
            play_music(x)
            time.sleep(.25)
        except KeyboardInterrupt:
            # if user hits Ctrl/C then exit
            # (works only in console mode)
            raise SystemExit
else:
    print("Please specify volume as a float! (0.0 - 1.0)")
mikeysklar
by piornet on Tue Feb 23, 2021 6:57 pm
Unfortunately pygameMP3.py produces a syntax error:
piornet
by mikeysklar on Wed Feb 24, 2021 3:34 pm
I see your point about pygameMP3 having some issues. I downloaded on my OS/X and a Pi4 machine with similar results that you saw.
How about using the classic mpg123 for MP3s or aplay for WAVs
I'm assuming you are running the current Pi OS release with updates is that correct?
alsamixer should still control volume levels
mikeysklar
by piornet on Fri Mar 19, 2021 9:19 pm
Unfortunately that didn't work either. I ordered another Voice Bonnet hat just in case it's a hardware issue, as I saw another post about that. Will give that a try.
piornet
by piornet on Tue Mar 23, 2021 1:54 pm
I got the new board but unfortunately it's the same problem. I'm not sure what to do - my project is stuck without the speakers working. Do you have any suggestions?
piornet
by mikeysklar on Wed Mar 24, 2021 1:36 pm
Just to summarize where we are.
Every aspect of the Audio Setup page is working correctly?
https://learn.adafruit.com/adafruit-voi ... udio-setup
aplay / alsamixer / speaker-test -c2 / arecord are all working properly through the speakers connected to the voice bonnet 3.5" jack?
The only part that is not working is pygame?
mikeysklar
by piornet on Mon Mar 29, 2021 11:17 am
No, I'm not able to get any sound from it at all, including speaker test and the microphone test.
What I've done:
* Formatted card and tried a fresh install and followed all the instructions again
* Purchased another Voice Bonnet in case my board was bad
piornet
by mikeysklar on Tue Mar 30, 2021 5:00 pm
Okay, since nothing works let's back up a step from audio configuration and get you running the blinka installation script that will setup i2c. Then we can confirm you can see the device.
cd ~
sudo pip3 install --upgrade adafruit-python-shell
wget https://raw.githubusercontent.com/adafruit/Raspberry-Pi-Installer-Scripts/master/raspi-blinka.py
sudo python3 raspi-blinka.py
https://learn.adafruit.com/adafruit-voi ... inka-setup
sudo i2cdetect -y 1
mikeysklar
by mikeysklar on Tue Mar 30, 2021 5:01 pm
cd ~
sudo i2cdetect -y 1
mikeysklar
by piornet on Sun Apr 11, 2021 2:16 pm
Thanks for the reply! I've redone the Blinka installation and confirmed that the device is showing up. It shows up as UU, I've attached a screenshot. Still no sound from either the attached speaker or from headphones on both the Voice Bonnet and on the Pi4 itself. :(
mikeysklar wrote:Okay, since nothing works let's back up a step from audio configuration and get you running the blinka installation script that will setup i2c. Then we can confirm you can see the device.
cd ~
sudo i2cdetect -y 1
piornet
by mikeysklar on Mon Apr 12, 2021 3:47 pm
The UU part is great. You see the Bonnet.
What happens when you run the following steps. I'm assuming you are on the latest Pi OS release kernel of 5.10. If you are not please update your installation.
 cd ~
sudo apt-get install -y git
git clone https://github.com/HinTak/seeed-voicecard
cd seeed-voicecard
git checkout v5.9
sudo ./install.sh
sudo reboot
and on reboot run
sudo aplay -l
speaker-test -c2
mikeysklar
by piornet on Mon Apr 12, 2021 7:41 pm
I repeated the steps, and it still shows up.
piornet
