Play Wav/Mp3 through Voice Bonnet Speaker
Re: Play Wav/Mp3 through Voice Bonnet Speaker
by mikeysklar on Tue Apr 13, 2021 1:34 pm
Well this all looks correct so far.
If you run into alsamixer and make the VoiceBonnet the default output device then you should be able to hear audio when running
sudo aplay <wavfile>
If alsamixer does not resolve it then you will need to modify the /etc/asound.conf to use card 1 instead of 0.
pcm.!default {
type hw
card 0
ctl.!default {
type hw
card 0
mikeysklar
by piornet on Sat Apr 24, 2021 12:55 pm
So...should I do anything else, or...?
piornet
by mikeysklar on Mon Apr 26, 2021 10:52 am
@piornet,
This all looks good so far. You are correctly seeing your sound card when running `aplay -l`.
You should be able to play and record sounds using these commands. You will need to a WAV file and adjust the name from my example of test.wav to your filename for the last two:
speaker-test -c 2 -F S16_LE -r 48000 -D hw:1,0
arecord --device=hw:1,0 --format S16_LE --rate 44100 -c1 test.wav
aplay -D plughw:1,0 test.wav
mikeysklar
