How disable the TFT 1.54" display on the BrainCraft HAT
by leolee8774 on Wed Apr 14, 2021 9:38 pm
I have setup my BrainCraft HAT by following the instruction and the TFT 1.54" display works well.
Now I want to know how can I turn off the TFT diaplay and re-use the HDMI display? And is there a way that the TFT display can be disabled automatically when I connect to a HDMI display? Thanks.
Regards,
Leo
leolee8774
Re: How disable the TFT 1.54" display on the BrainCraft HAT
by mikeysklar on Fri Apr 16, 2021 11:32 am
Leo,
Good question. I've not seen a way to detect the HDMI monitor presence so that you can automate this process. However, here are some things you can try.
This python script shoudl disable the display backlight on the BrainCraft TFT.
# Turn on the Backlight
backlight = DigitalInOut(board.D26)
backlight.switch_to_output()
backlight.value = True
Does anything show up from dmesg or or other system log files as you insert the HDMi cable into your Pi? If so, you could setup a script that monitors the log file and calls the above python code. Hacky, I know,
mikeysklar
by marc_woohoo on Wed Apr 28, 2021 12:39 pm
mikeysklar
I'm also trying to figure out how to use my external monitor instead of the tiny TFT 1.54 display. I've tried running your python script, but nothing happened. Is there any other workaround I could try?
marc_woohoo
by mikeysklar on Wed Apr 28, 2021 2:57 pm
The BrainCraft HAT has pretty much the same LCD setup as the 1.3" TFT Bonnet for a Pi. You should be able to follow those instructions to set the BrainCraft HAT to boot to console and as long as your HDMI cable is plugged in at boot your monitor should be your main display.
cd ~
sudo pip3 install --upgrade adafruit-python-shell click==7.0
sudo apt-get install -y git
git clone https://github.com/adafruit/Raspberry-Pi-Installer-Scripts.git
cd Raspberry-Pi-Installer-Scripts
sudo python3 adafruit-pitft.py --display=st7789_240x240 --rotation=0 --install-type=console
https://learn.adafruit.com/adafruit-1-3 ... le-install
mikeysklar
by geekguy on Mon May 17, 2021 2:26 am
Your script does not get the desired results. Nothing goes to HDMI. Did you test this script?
8-Dale
geekguy
by mikeysklar on Mon May 17, 2021 8:24 pm
8-dale,
I've never run this with the Braincraft, but we use this script on all our PiTFTs.
Go ahead and post your /boot/config.txt and we will take a look at override options.
mikeysklar
by geekguy on Fri May 21, 2021 12:52 pm
mikeysklar wrote:Go ahead and post your /boot/config.txt and we will take a look at override options.
OK, here it is.
8-Dale
brainy.config.txt
This is config.txt from the rPi 4 I have the Braincraft HAT on.
(2.11 KiB) Downloaded 3 times
geekguy
by mikeysklar on Sun May 23, 2021 3:26 pm
8-Dale,
Can you comment out the Adafruit section that our script adds-in at the end of /boot/config.txt?
# --- added by adafruit-pitft-helper Sun May 16 23:18:59 2021 ---
hdmi_force_hotplug=1
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
dtoverlay=drm-minipitft13,rotate=0,fps=60
# --- end adafruit-pitft-helper Sun Ma
Then boot from HDMI to confirm that all works correctly. I think in this scenario you are going to have to use two seperate /boot/config.txt files one without the piTFT code and another with it that you switch between to use the display or HDMI.
mikeysklar
by geekguy on Sun May 23, 2021 5:35 pm
mikeysklar wrote:Can you comment out the Adafruit section that our script adds-in at the end of /boot/config.txt?
I did that and I do not get a display on HDMI or the TFT. So, I uncommented that section, rebooted, and am back to the TFT being my only display. I have to SSh in to brainy in order to do anything on it.
8-Dale
geekguy
by mikeysklar on Mon May 24, 2021 11:56 am
Okay, we should be able to get HDMI going by keeping the Adafruit TFT lines at the bottom commented out. Then proceed to uncomment these lines forcing a safe strong HDMI signal.
hdmi_safe=1
hdmi_drive=2
config_hdmi_boost=4
mikeysklar
by geekguy on Mon May 24, 2021 2:01 pm
mikeysklar wrote:Okay, we should be able to get HDMI going by keeping the Adafruit TFT lines at the bottom commented out. Then proceed to uncomment these lines forcing a safe strong HDMI signal.
hdmi_safe=1
hdmi_drive=2
config_hdmi_boost=4
OK, this is working, but not completely. I do have everything going to HDMI now. That is good, however, I am not getting the entire screen and the first few characters are cut off. I do not have use of the whole HDMI screen - just part right in the middle that has a grey background.
Progress!
8-Dale
geekguy
by mikeysklar on Mon May 24, 2021 4:26 pm
Glad to hear it.
You might be able to move the safe line. I suspect that is reducing resolution and causing the cutoff.
hdmi_safe=1
You can run adjust the resolution from a terminal:
sudo raspi-config
Display Options
Resolution
I think the above might save a resolution to your /boot/config.txt (not positive), but the idea here is too have an config-hdmi.txt and config-braincraft.txt that you can switch between with a manual reboot. Hardly ideal, but a start.
mikeysklar
