PiTFT 2.4 problem with touchscreen on Pi4
by illydone on Sun Apr 18, 2021 1:18 pm
Hi
The screen was perfectly working on Raspberry 3B+. The OS has been updated till the original install but not the configuration.
It is now essentially used as a console screen on a 4B /Raspbian lite, used as a nano laptop for shell, so I don't really need the touch fonctionnality for daily use.
First problem:
I switched to GUI on he Pi4, and the touch isn't working. I tried to reinstall pitft with the latest script, I also tried to manually load stmpe-ts, but touch isn't working. In dmesg, I get:
stmpe-spi spi 0.1: unknown chip id: 0x0
stmpe-spi: probe of spi 0.1 failed with error -22
The same SD card and the same screen on another Pi4B gives the same error.
The same SD card and the same screen back on a Pi3B+ is perfectly working.
The problem seems to be linked to the Pi4. Is it a know issue?
Second problem (not the most important):
I don't exactly remember how it was installed first, but I had the console very quickly during boot/shutdown and when I changed to desktop using raspi-config, I didn't have to change/reinstall anything about pitft and the UI was displayed in 320x240. It worked perfectly except touch.
After reinstalling yesterday with your latest python scripts, I have to choose between console or fbcp. If it starts in console, I never have access to the UI and keep stucked in console. If it starts in fbcp, the console appears but very lately and I don't have the boot/shutdown sequence. However, UI is starting.
What is the configuration to have both the console and the UI as it was the case before reinstalling pitft?
illydone
Re: PiTFT 2.4 problem with touchscreen on Pi4
by adafruit2 on Mon Apr 19, 2021 1:06 pm
ok what if you turn off everything. wait a few minutes, then turn it back on?
adafruit2
Site Admin
by illydone on Tue Apr 20, 2021 5:12 am
I just started the pi after 2 days off: no change. Still unknown chip id and error -22 and no touch link in /dev.
BTW, I tested several official Raspberry Pi power supplies with no change.
illydone
by illydone on Mon Apr 26, 2021 11:40 am
Anybody has an idea? Seems the touch screen is not compatible with pi4.
illydone
by adafruit2 on Mon Apr 26, 2021 10:48 pm
its so weird, it works fine on the Pi3 but not Pi4?
adafruit2
Site Admin
by illydone on Tue Apr 27, 2021 6:32 am
You're right, same SD card/system/parameters.
Except the board, the only difference is the power supply (although I also tested with the Pi3 power supply and a USB C adapter).
illydone
by illydone on Wed Apr 28, 2021 2:27 am
Does anybody have tests I can make or parameters I can set?
illydone
