[Help] TCA9548A Read and Parse data from Omron D6T-1A-01 Sen
by g0dswar3k on Sun Apr 25, 2021 4:58 am
Hi everyone,
I'm working on reading the temp from the Omron D6T-1A-01 Sensor. I'm using the TCA9548A to read from the 2 same sensors.
I've use the code for MLX with TCA as reference.
import adafruit_tca9548a
import adafruit_mlx90614
tca = adafruit_tca9548a.TCA9548A(i2c)
# Initialized MLX90614 Sensors on TCA at Ch2
mlx = adafruit_mlx90614.MLX90614(tca[2])
Unfortunately using the code below for D6T connected to Channel 0 and 1, I cant read/parse the data from S1 and S2 since the output is object.
S1 =  tca[0]
S2 = tca[1]
Is there way so that I can read and parse the i2c block data from S1 and S2?
Thank you.
g0dswar3k
Re: [Help] TCA9548A Read and Parse data from Omron D6T-1A-01
by adafruit_support_carter on Mon Apr 26, 2021 12:56 pm
Sounds like maybe you are after manual muxing?
https://github.com/adafruit/Adafruit_Ci ... /issues/28
The current library was designed for use with the CircuitPython busio library, which is what all CircuitPython drivers are written to. For something without a CircuitPython library, you'd need something like what issue thread is discussing.
