Unable to connect to Raspberry Pi Zero wh
Re: Unable to connect to Raspberry Pi Zero wh
by adafruit_support_carter on Fri Apr 30, 2021 2:30 pm
Setting the county part is also important, and sometimes gets overlooked.
by gerbreown on Sat May 01, 2021 6:39 am
Just went through the steps manually. Changed the SSID and password.
I set the country to PH for the Philippines which is where I am.
I also placed the Pi next to the router and still am getting "Destination Host Unreachable" error messages. Even though it is showing up in the router admin page.
I just did a "arp -a" command and received a message (192.168.1.4) The Pi IP address at <incomplete> on enp3s0. The enp3s0 is an ethernet port not wifi so that command is useless in this case.
When I ssh pi@192.168.1.4 or ssh pi@raspberrypi.local I get "No route to host"
If I ping 192.168.1.4 or ping raspberrypi.local I get "Destination Host Unreachable"
I am beginning to think that my Pi is defective because all of my 5 other Pis have worked out of the box and I can ping and ssh to all of them. How can I get a replacement for this Pi? It has been almost 3 weeks now and with your help and my searching and trying other things I am still not able to connect to this computer.
Thanks.
gerbreown
by adafruit_support_carter on Mon May 03, 2021 1:02 pm
Really weird issue. This doesn't seem like a hardware issue, but let's just replace the Pi and see what happens.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement Pi Zero WH.
