cyberdeck not quite right
by william_mccolgan on Thu Apr 29, 2021 3:17 pm
fit to cyberdeck
Fit to pi400
Fit to pi400
backlight
backlight
I was delighted when the cyberdeck hat came back on the store. I ordered one with a 4" hyper pixel right away, but can't get it to work.
(invoice 2548526)
The hyperpixel works. I tried it on a pi zero. No problem. works directly plugged into the GPIO on the Pi400 (with desktop upside down).
But when I introduce the cyberdeck something isn't right. The connections to the display and the pi400 are good. I have also tried with extenders on the pi400 just in case. The display backlights when I power up. But the desktop appears for only a blink on an eye then the screen goes black, Its still powered, it is backlit, but nothing on screen. I can SSH onto the device, so it is running, just not outputting through the cyberdeck.
Any tips or suggestions appreciated. I think I might have a defective unit.
https://www.icloud.com/sharedalbum/#B0cGY8gBYGviBI7
william_mccolgan
Re: cyberdeck not quite right
by adafruit_support_carter on Tue May 04, 2021 1:24 pm
What are the extenders you mention here? Are those something entirely different from the Cyberdeck? And you're getting the same behavior?
by william_mccolgan on Tue May 04, 2021 2:55 pm
I just mean the 40 pin female header that comes in the box with the hyperPixel. Whether I use these or not, the result is the same.
william_mccolgan
by adafruit_support_carter on Tue May 04, 2021 3:18 pm
Oh, OK, this riser?
So just to be clear, it seems like the behavior is specific to the Cyberdeck? The display works fine on both Pi's when direct connected. But not when through the Cyberdeck. No other changes?
by william_mccolgan on Wed May 05, 2021 2:20 am
That's correct. The cyberdeck makes the difference. If we leave the headers out entirely , the display works on the pi400 and on pi zero.
Introduce the cyberdeck and I have the issue described.
william_mccolgan
by adafruit2 on Wed May 05, 2021 10:01 am
take a look, are there any traces/pads that are not soldered through on the cyberdeck? someone also mentioned needing to mechanically adjust the 'deck - we test each deck with a TFT Kippah which is just-about-the-same thing
adafruit2
Site Admin
by william_mccolgan on Wed May 05, 2021 2:38 pm
No, none of them look bad. some of the soldering is not pretty, but it all looks sufficient.
william_mccolgan
by adafruit2 on Wed May 05, 2021 6:22 pm
only thing we can recommend is maybe reseating/tilting the cyberdeck. there's no active electronic parts - the pins pass through! hwat if you plug it into the other Pi (Zero or 3 or whatever)?
adafruit2
Site Admin
by william_mccolgan on Thu May 06, 2021 2:33 am
Here is the hyper pixel working fine directly plugged into a Pi4
william_mccolgan
by william_mccolgan on Thu May 06, 2021 2:38 am
Here is the same set up with the cyberdeck inserted.
You can see that VNC believes the device is outputting to the correct form factor, and it does come up on the display for a second or two, so the connections are made, but something about introducing the cyberdeck is causing the image to fail very quickly. This doesn't happen with the display connected directly.
No amount of angling / reseating seems to make a difference.
I think there is a manufacturing defect in the cyberdeck.
william_mccolgan
by adafruit2 on Sat May 08, 2021 1:44 pm
hmm, well we could either replace it or refund - there's no guarantee another cyberdeck would work (if its something about the hyperpixel combined!)
adafruit2
Site Admin
by william_mccolgan on Mon May 10, 2021 7:55 am
Replace would be great. I don't think there is any issue with the hyperpixel.
william_mccolgan
by adafruit2 on Mon May 10, 2021 10:08 am
ok email support@adafruit with a link to this thread to request a replacment. let us know either way! it is good data.
adafruit2
Site Admin
by Cdogger715 on Mon May 17, 2021 1:24 pm
Hello, I am having this exact problem. I have a Cyberdeck hat connecting a Hyperpixel 4 to the GPIO on a Raspberry Pi 400. Just like the other poster in this thread, when I plug the Hyperpixel directly into GPIO it works perfectly, but when I introduce the Cyberdeck hat the backlight turns on as does the screen for a brief moment before turning off.
Cdogger715
by adafruit2 on Tue May 18, 2021 11:44 am
@william did it get resolved?
adafruit2
Site Admin
