TCA9548a + SHT31D connect
by Mainzelman on Sun May 02, 2021 12:20 pm
Hello, Beginner help needed.
Raspberry PI 4, 1x TCA9548 + 2x SHT31D, Python3. How can I connect the SHT31 to the TCA9548 ?
i2cdetect -l
i2c-15 i2c i2c-1-mux (chan_id 4) I2C adapter
i2c-13 i2c i2c-1-mux (chan_id 2) I2C adapter
i2c-1 i2c bcm2835 (i2c@7e804000) I2C adapter
i2c-11 i2c i2c-1-mux (chan_id 0) I2C adapter
i2c-18 i2c i2c-1-mux (chan_id 7) I2C adapter
i2c-16 i2c i2c-1-mux (chan_id 5) I2C adapter
i2c-14 i2c i2c-1-mux (chan_id 3) I2C adapter
i2c-12 i2c i2c-1-mux (chan_id 1) I2C adapter
i2c-17 i2c i2c-1-mux (chan_id 6) I2C adapter
# Example code
#!/usr/bin/python3
import time
import board
import busio
import adafruit_sht31d
import adafruit_tca9548a
i2c=busio.I2C(board.SCL, board.SDA)
tca = adafruit_tca9548a.TCA9548A(i2c)
sht1 = adafruit_sht31d.SHT31D(tca[0])
sht2 = adafruit_sht31d.SHT31D(tca[1])
while 1:
print("Sensor #1: Temp: {}, RH: {}".format(sht1.temperature,sht1.relative_humidity))
print("Sensor #2: Temp: {}, RH: {}".format(sht2.temperature,sht2.relative_humidity))
print("-------------------------")
# Error
File "./Test-1.py", line 13, in <module>
File "/usr/local/lib/python3.7/dist-packages/adafruit_sht31d.py", line 182, in __init__
self.i2c_device = I2CDevice(i2c_bus, address)
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 50, in __init__
self.__probe_for_device()
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 151, in __probe_for_device
while not self.i2c.try_lock():
# Print only TCA state
# Example code
#!/usr/bin/python3
import time
import board
import busio
#sht1 = adafruit_sht31d.SHT31D(tca[0])
#sht2 = adafruit_sht31d.SHT31D(tca[1])
while 1:
# print("Sensor #1: Temp: {}, RH: {}".format(sht1.temperature,sht1.relative_humidity))
# print("Sensor #2: Temp: {}, RH: {}".format(sht2.temperature,sht2.relative_humidity))
print(tca)
print(tca[0])
print(tca[1])
print(tca[2])
print(tca[3])
print(tca[4])
print(tca[5])
print(tca[6])
print(tca[7])
time.sleep(2)
# Output
<adafruit_tca9548a.TCA9548A object at 0xb66fdc90>
<adafruit_tca9548a.TCA9548A_Channel object at 0xb662e890>
<adafruit_tca9548a.TCA9548A_Channel object at 0xb6648230>
<adafruit_tca9548a.TCA9548A_Channel object at 0xb66482d0>
<adafruit_tca9548a.TCA9548A_Channel object at 0xb6648310>
<adafruit_tca9548a.TCA9548A_Channel object at 0xb6648350>
<adafruit_tca9548a.TCA9548A_Channel object at 0xb6648390>
<adafruit_tca9548a.TCA9548A_Channel object at 0xb66483d0>
<adafruit_tca9548a.TCA9548A_Channel object at 0xb6648410>
many thanks for help or tips
Mainzelman
Re: TCA9548a + SHT31D connect
by mikeysklar on Mon May 03, 2021 4:48 pm
This is not an answer to your question, but if you only hve two SHT-31D devices you can set the address on them using either 0x44 and 0x45. This would allow you to bypass the TCA9548A.
ADR - This is the I2C address selection pin. This pin has a 10K pull down resistor to make the default I2C address 0x44. You can tie this pin to Vin to make the address 0x45
https://learn.adafruit.com/adafruit-sht ... ut/pinouts
mikeysklar
by Mainzelman on Tue May 04, 2021 2:12 am
Thank you for the hint - but i would like to use more then 2 sensors. I only use 2 Sensors in the example.
Mainzelman
by mikeysklar on Tue May 04, 2021 11:41 am
Your code example looks fine that is failing out on the i2c try_lock. I'm wondering if a small addition of multiple tries would make a difference?
>>> while not <chrome_find class="find_in_page">i2c.try</chrome_find>_lock():
...     pass
https://learn.adafruit.com/circuitpytho ... -2837704-1
Can you also post your wiring. Maybe there is something there out of place?
mikeysklar
by Mainzelman on Tue May 04, 2021 12:33 pm
many thanks for the answer. Please find attached one Picture with Cable settings.
To me it looks like SHT31 lib is not communicating with TCA9548a lib.
Please note - i use Kernel drivers:
/boot/config.txt
# ap - Kernel driver
dtoverlay=i2c-mux,pca9548
when i test with i2cdetect -y <N> everyone has address UU.
pi@raspberrypi:~ $ i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: UU -- -- -- -- -- -- --
pi@raspberrypi:~ $ i2cdetect -y 11
Is that correct ?
Mainzelman
by mikeysklar on Thu May 06, 2021 11:39 am
I think the UU is a function of I2S being enabled (the sound interface - do not confuse with I2C). That should go away if you disable i2s (/boot/config.txt).
Is the kernel driver required pca9865? That does not seem necessary.
I've seen one forum user successfully report getting things going on their Pi with the TCA9865A + SHT31D combo.
viewtopic.php?f=24&t=172376
I think you are running identical code so I suspect the issue is more with the a driver conflict (i2s or PCA) and possibly wiring. Although your wiring looks reasonable from the parts I can see.
import time
from busio import I2C
from board import SCL,SDA
i2c=I2C(SCL,SDA)
while 1:
time.sleep(1)
mikeysklar
by Mainzelman on Mon May 10, 2021 6:01 am
First of all, I would like to say thank you very much for your support. I reset and rebuilt my project. It works now ! (without the kernel modules)
-> to my shame i have to say - i had connected the power supply to the sensors on the wrong side of the breadboard ;-(( (beginners mistake)
Thanks again.
Mainzelman
by mikeysklar on Mon May 10, 2021 4:14 pm
Cool. Glad that worked out. Thank you for getting back to us with your findings.
mikeysklar
