PiTFT 3.2" (resistive) Touchscreen not respond
by rolandnagy on Mon May 03, 2021 9:28 am
I've bought an Adafruit PiTFT 3.2" TFT Resistive touch screen for a Raspbery PI 4 B. I went through the "Easy Install" steps and the display part of the device is works fine, but it's not responds to any of touch. I can't see any of error message.
So, what can I do with the touchscreen?
Thanks,
Roland
rolandnagy
Re: PiTFT 3.2" (resistive) Touchscreen not respond
by illydone on Fri May 07, 2021 7:50 am
We have perhaps the same problem as 2.4, 2.8 and 3.2 resistive seem to use the same driver.
And did you check this page?
https://learn.adafruit.com/adafruit-pit ... -calibrate
What's the output of this command:
dmesg | grep stmpe-spi
illydone
by rolandnagy on Mon May 10, 2021 2:53 am
thanks for the answer. Yes, I've already tried the manual install steps but it didn't help, the touchscreen is not good yet.
I get the following lines for the "dmesg | grep stmpe-spi" command:
[ 4.601069] stmpe-spi spi0.1: failed to request IRQ GPIO: -16
[ 4.601101] stmpe-spi: probe of spi0.1 failed with error -16
Regards,
Roland
rolandnagy
by illydone on Mon May 10, 2021 4:05 am
You have an IRQ problem (not the same problem as me).
Can you please post the whole output of dmesg?
Seems there's a problem with the driver. Perhaps another driver is already loaded as in a previous case here.
illydone
by adafruit_support_mike on Tue May 11, 2021 12:55 am
Also post a photo showing the back of the PiTFT where the flex cable comes through the PCB please. There are a couple of phyical reasons for that kind of signal problem.
800x600 images usually work best.
