PI4 usb power port
PI4 usb power port
by saltpoint3289 on Sat May 08, 2021 12:05 pm
Purchased PI4 in February 2021, attached the PI Foundation 7” touchscreen (2718). Yesterday the power port was lose and in a very short time fell off. I am weak in soldering little teeny tiny areas so I am looking for an alternative. I have tried to use the power supply port of the display - the pi led shows red and nothing else happens. No green led, no display. The gpio connections between pi and display are simply ground to ground ; 5v to 5v.
1) how can I make this work?
2) is there another solution that does involve soldering?
Thank you, Cynthia LaPier
saltpoint3289
Re: PI4 usb power port
by mikeysklar on Sun May 09, 2021 8:00 pm
Hi Cynthia,
You could add a POE Hat (Power over Ethernet). It is an elligant solution to have your data and power come into the unit over one line. It does require a POE enabled switch.
https://www.adafruit.com/product/3953
Another option would be to use the Pi header pins #2 and #6 to feed in the appropriately sized power supply 5v / ~3A would be ideal for a Pi 4.
https://www.raspberrypi.org/forums/view ... 3#p1515411
mikeysklar
by saltpoint3289 on Mon May 10, 2021 10:16 pm
Thank you for the suggestions.
I will be suing this setup in the field with my telescope so POE won’t work.
I am going to work on the GPIO idea.
I really wanted to use this display as it has a separate us power port if it can share with the RPi - why wouldn’t it work in reverse?
Thank you
saltpoint3289
by mikeysklar on Tue May 11, 2021 9:32 am
The power pins exposed on the 7" display should work. I think those are worth trying. The only concern would be that the traces are not large enough to carry the required current to run the Pi and the display.
I was only able to locate two mechanical design files and installation instructions for it so I was unable to confirm how much current the 7" display board can handle over those external connectors.
https://www.raspberrypi.org/documentati ... e/display/
mikeysklar
