Raspberry Pi failure
by jojemar on Sat May 08, 2021 12:40 pm
Hello!
I bought a RP 8GB from you a few short weeks ago. After receiving my case, heatsinks, and fan for it, I got it all installed and everything was fine... for a few days.
Two days ago when I booted it up, instead of the normal initialization, a sunbursty white and gray pattern was displayed, then the screen turned off. I checked my connections and everything looked fine, so I did a reboot. Same thing. I poked and prodded around a bit, and eventually the screen displayed nothing.
Heatsinks are a copper layer under a typical inert aluminum heatsink. Fan cycles the air. Never ran close to hot.
I plugged it into my monitor and reboot. Same. Lights turn on, fan turns on, no monitor output.
Is it possible that this is a problem board? The little gray tab on the camera port looks damaged. I haven't connected a camera and don't own a camera to connect.
Any ideas?
jojemar
Re: Raspberry Pi failure
by adafruit_support_carter on Mon May 10, 2021 11:03 am
Please post a photo of this.
Have you tried starting over with a fresh OS image?
by jojemar on Wed May 12, 2021 2:23 pm
I actually figured this out... the screen was bad and for some reason my monitor just wasn't working with the Pi. RMA'd the screen, all good to go. That little cover/clamp for the camera port still looks dodgy but everything works.
jojemar
by adafruit_support_carter on Wed May 12, 2021 3:01 pm
OK, cool. If it all seems to be working, then maybe all good. If the camera connector thing ends up being an issue, please just respond back here and we'll pick things back up.
