Cyberdeck Hat Issue
Cyberdeck Hat Issue
by Cdogger715 on Mon May 17, 2021 5:10 pm
Plugged directly into GPIO
Plugged into Cyberdeck 2
Plugged into Cyberdeck 1
I am having an issue with the Cyberdeck hat. I have it hooked into a Raspberry Pi 400 and a Hyperpixel 4 through GPIO. Whenever I boot up the Pi, the Hyperpixel backlight comes on, then the screen will show the desktop for a few seconds, then only the backlight will be on and the screen will be blank. When I hook the Hyperpixel directly into the GPIO I don't have any issues.
Cdogger715
Re: Cyberdeck Hat Issue
by dastels on Mon May 17, 2021 6:26 pm
Have a close look at the soldering on the male header (where the screen is plugged onto. You're looking for any of those surface-mount tabes having broken away from the circuit board.
dastels
by Cdogger715 on Mon May 17, 2021 6:55 pm
Tabs 2
Tabs 1
None of the tabs appear to have broken away.
Cdogger715
by dastels on Mon May 17, 2021 7:00 pm
Do you have any other hats you could try the deck with? Does jiggling the display change anything? How does the soldering on the female connector look?
Since the display works when plugged in directly and there's very little other than connectoprs on the cyberdeck, my thought is that there's a soldering issue somewhere. Another possibility is a problem with a trace. is there any scuff/scrape damage?
dastels
by Cdogger715 on Mon May 17, 2021 7:32 pm
I do not have any other hats to plug it into. Jiggling the display does not change anything and there doesn't appear to be any scrapes or improperly soldered areas.
Cdogger715
by adafruit2 on Tue May 18, 2021 11:55 am
@cdogger can ya post in the pim forums, maybe they have some ideas why it doesnt work? a few folks have said it doesnt work but there's no reason we can see why it wouldnt!
adafruit2
Site Admin
by Cdogger715 on Tue May 18, 2021 12:06 pm
What are the pin forums? I'm not finding them.
Cdogger715
by adafruit2 on Tue May 18, 2021 12:10 pm
pimoroni, the folks who make the display :)
adafruit2
Site Admin
