Adafruit CYBERDECK HAT for Raspberry Pi 400
PRODUCT ID: 4863
I was trying to use this with the suggested hyperpixel4. The screen kept losing the image and just had the backlit light. I thought the issue was the lcd screen, but after removing the cyberdeck from the equation, my lcd screen works fine.
Defective item
Re: Defective item
We've just found that the Cyberdeck Hat has a diode that seems to cause a conflict with the HyperPixel's CS pin. It seeems to be an edge case.
You can fix it by cutting this trace on the Cyberdeck between the component and the via:
You can't use that pin while the two devices are connected to the RasPi anyway.
- adafruit_support_carter
Re: Defective item
Please see here for information about this issue along with suggestions for fixing it:
viewtopic.php?f=50&t=179733&start=15#p875641
