Have a "little" issue with this raspberry PI. Shortly after the start, it freezes. Pings show over 90% packet loss, can't ssh or do anything else with it. Tried a different SD card, added a cooling fan, no luck.
Attaching a ping screenshot
Order No: 2574663-6020993956
Regards,
Bob
Raspberry PI 4 freezes shortly after the start
- neeyo
- Attachments
- Screen Shot 2021-06-10 at 6.43.46 PM.png (785.31 KiB) Viewed 284 times
Re: Raspberry PI 4 freezes shortly after the start
Can you log in with a keyboard and display?
- neeyo
Nope, freezes too :(
What voltage do you see on the 5V and 3.3V GPIO pins?
- neeyo
5.3 and 3.28 volts
Okay, that probably rules out a short circuit in the microprocessor or power management system.
What are you using as a power supply?
- neeyo
The official PI PSU, this one - https://www.raspberrypi.org/products/ty ... er-supply/
Good.. that’s about as close as it gets to the known-working configuration.
Combining that with the fact that the supply pin voltages are in spec strongly suggests the power supply is good. That puts all the suspicion on the RasPi, which isn’t doing what it should.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement Pi4.
- neeyo
Thanks a lot, will do!
- creatoroflight
My raspberry Pi 4 freezes while trying to run recalbox added it to sd using Raspberry PI Imager
tried using a different sd still freezes then it stopped booting.
Tried to use bootloader on Raspberry PI Imager to fix it.
I get a red screen not a green one and it still not booting
so dont know where to go from here?
