SBC: Rpi 3B+
OS: Latest Buster Desktop
I have both a Slamtec A1M8-R5 and a A1M8-R6 which is the latest hardware and firmware (v 1.29)
When I run "display_lidar_pi" using my A1M8-R5, I get the expected Lidar display on my LCD display.
When I run "display_lidar_pi.py" using my A1M8-R6, I get the following error message: "adafruit_rplidar .rplidar exception: wrong body size"
I have searched the IoT for a possible solution to the "adafruit_rplidar .rplidar exception: wrong body size" error, but have experienced no joy.
The A1M8-R5 is two years old and is running an early version of the A1M8 firmware. The A1M8-R6 is running the latest firmware.
Obviously the Adafruit RPLidar module is taking an exception to the latest A1M8-R6 firmware, but has no issue with the A1M8-R5 firmware.
I am using the Adafruit RPLidar module with both the A1M8-R5 and R6 on my Donkey Car platform and have no issues connecting with either A1M8 and collecting data.
Is there a line of code in the "display_lidar_pi.py" program that can be adjusted to overcome the dreaded "adafruit_rplidar .rplidar exception: wrong body size" error?
Here is the complete error message"
pygame 1.9.4.post1
Hello from the pygame community. https://www.pygame.org/contribute.html
{'model': 24, 'firmware': (1, 29), 'hardware': 7, 'serialnumber': '14342370f79ce5c5d49ae5c9f699f18c'}
File "display_lidar_pi.py", line 55, in <module>
for scan in lidar.iter_scans():
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_rplidar.py", line 508, in iter_scans
for new_scan, quality, angle, distance in iterator:
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_rplidar.py", line 433, in iter_measurements
raw = self._read_response(dsize)
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_rplidar.py", line 261, in _read_response
raise RPLidarException("Wrong body size")
adafruit_rplidar.RPLidarException: Wrong body size
Rplidar does not support A1M8-R6 firmware version
- tciii
- tciii
Re: Rplidar does not support A1M8-R6 firmware version
Update:
I have found that if I run the "Usage Example" Python programhttps://github.com/adafruit/Adafruit_Ci ... on_RPLIDAR I can get the RPLidar range data displayed as sequential millimeter readings on my LCD display for both the A1M8-R5 and the A1M8-R6, but still cannot display the A1M8-R6 range data as dots scaled to fit my LCD display as I can with the A1M8-R5 when running "display_lidar_pi.py".
There is obviously an issue with "display_lidar_pi.py"https://learn.adafruit.com/slamtec-rpli ... spberry-pi that is occurring with the A1M8-R6 that is not occurring with the A1M8-R5 which will display the range data as dots scaled to fit my LCD display.
- adafruit2
hiya where did you buy the A1M8-R6?
- tciii
I bought it from the same place that I bought my A1M8-R5 from.adafruit2 wrote:hiya where did you buy the A1M8-R6?
It doesn't matter where I bought the A1M8-R6 from as there is a missing "timeout" value in the Adafruit "display_lidar_pi.py" Python program.
Once I added the missing "timeout" value the A1M8-R6 correctly displayed the expected dot pattern on my LCD display.
No further assistance is required.
- adafruit2
ok it sounds like you did not get the sensor from adafruit? in which case we cannot replicate your issue
please submit a PR with the changes to the example program so others can benefit
