2.13" Monochrome E-Ink Bonnet Faded
- csotzing
I've built a temperature & humidity monitor out of a Pi Zero and a 2.13" Monochrome E-Ink Bonnet. After a few months of running 24/7 the display is not nearly as "dark" as it was; that is, the blacks are faded considerably. The application refreshes the screen every 5 minutes so I'm definitely not *over-refreshing. Can the contrast be configured or is this bonnet just wearing out?
- DSC_0223.JPG (398.61 KiB) Viewed 352 times
- Franklin97355
Re: 2.13" Monochrome E-Ink Bonnet Faded
Do you see any "ghost image"?
- csotzing
Do you mean when the display inverts when it refreshes? In that case yes and actually having just watched the refresh a few times the black in the inverted image is *way darker, probably as dark as it ever was. It goes faded gray immediately after the refresh.
- adafruit2
yeah it could be wearing out, how many refreshes have you done (total count?) - we can ask if theres a refresh limit from the manufacturer
- csotzing
The display updates every 5 minutes and runs 24h. So for the time I've had it (plus the development cycles) I guess it's around 20,000 refreshes?
- adafruit2
yah that sounds... high. eink displays like these are designed for store labels, updating once a day
it could be that there's a max number of refreshes before it dims - oled's are the same!
we'll ask
we'll ask
- csotzing
Thanks, I'd be interested to know if there a max number of refreshes. FWIW the example code includes a weather application which surely wouldn't be super useful if it only updated once a day!
Are there other display bonnets for a Pi Zero that include a Qwiic/STEMMA QT connector that you could recommend for a (somewhat) frequent refresh?
- adafruit2
once a day weather is pretty useful! the magtag does that and we have it on our fridge :)
https://learn.adafruit.com/magtag-weather
- csotzing
Any update on max refreshes? Perhaps there is a way to adjust the contrast as the board ages? Thanks for your help.
- adafruit2
hiya they replied asking if the display was exposed to sunlight?
- csotzing
The device is mounted to a wall that never gets direct sunlight. It's actually quite dark in that room.
The fact that at refresh the fully blacked out screen is very dark is still odd to me. The bonnet is still capable of that kind of contrast so perhaps the fade is a configuration issue?
- adafruit2
what if you display all black
- csotzing
Wow I'm actually kind of surprised the result of that test. Drawing a black rectangle that fills the screen *is the correct contrast, very black. But when I go back to my text display it fades out as it was previously. I'm not setting anything except the fill (no contrast, etc.). And to reiterate the text printed in really crisp black letters originally and no code has changed since I wrote it a few months ago.
Exampe code excerpt for text:
Example code for the box:
Thanks for all the help, much appreicated.
# Draw the humidity text
draw.text(
(x_offset, (calib_display_height/4)-(humidity_text_height/2)+y_offset),
self._humidity_text,
font=self.large_font,
fill=BLACK,
#black box
shape = [(0,0), (calib_display_width, calib_display_height)]
draw.rectangle(shape, fill=BLACK)
- adafruit2
could be you wore out the ink in those spots, could try flashing the whole thing black or white often to help reset it. we dont have any lower level insight - its just speculation
- csotzing
I set the screen to all black and had it reset every 5 minutes for 24 hours. The black full screen was fully black (no fading). I then reverted it to the temp/humidity display and the text is faded again.
This tells me that it's not the pixels that are worn out because they displayed correctly as part of a fully blacked out screen.
Any word from the manufacturer?
