Raspberry Pi 4 B not booting
- tmoore747
I have a Raspberry Pi 4 model B that I received a couple of days ago. I have only been able to get it to boot once. I imaged two different SD cards using the official Raspberry Pi Imaging tool and Balena etcher. I checked the SD card and HDMI cable on another Pi and they work fine. I am also using the official power adapter. When trying to boot, the red light stays lit and the green light flashes in no obvious pattern and then goes dark.
- adafruit_support_carter
Re: Raspberry Pi 4 B not booting
What did you do with the Pi the one time it did boot?
- tmoore747
I worked through the setup steps for wireless, password, etc and then I shut it down so I could come back to it later. It had failed to boot prior to this and now each attempt since.
Which RAM size variant Pi do you have?
If you remove the SD card and then apply power, what does the ACT LED do?
- tmoore747
Without an SD card, the ACT light is solid green. It is the 8 gb version.
Just to make sure what this is. It's one of these?I am also using the official power adapter.
https://www.adafruit.com/product/4298
Did anything ever get attached to the Pi's GPIO headers?
- tmoore747
Yes, that is the power adapter. No, nothing has ever been connected to the headers.
OK, let's replace it. Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement Pi 4.
- tmoore747
Thanks for the help.
