I was successfully able to configure the Animated Eyes Bonnet by following the guide here:
https://learn.adafruit.com/animated-sna ... pberry-pi/
In the guide the way its suggested to switch the graphics is to edit /boot/Pi_Eyes/eyes.py and reboot.
I would like to be able to stop the existing eye configuration and start a new one via SSH automatically.
I have 2 simple helper scripts that attempt to kill everything by hand and start a new process (By reusing the last section currently in /etc/rc.local.
cat start_eyes.sh
#!/bin/bash
sudo pkill -f eyes.py
sudo pkill -f dragon_eyes.py
sudo killall fbx2
sudo /boot/Pi_Eyes/fbx2 -i &
cd /boot/Pi_Eyes
sudo python3 eyes.py --radius 240 &
exit 0
When I launch this script, I get the following error.
File "eyes.py", line 223, in <module>
mykeys = pi3d.Keyboard() # For capturing key presses
File "/usr/local/lib/python3.7/dist-packages/pi3d/Keyboard.py", line 257, in Keyboard
return CursesKeyboard() if use_curses else SysKeyboard()
File "/usr/local/lib/python3.7/dist-packages/pi3d/Keyboard.py", line 19, in __init__
curses.cbreak()
_curses.error: cbreak() returned ERR
Is there a recommended way to start a new instance of eyes.py and fbx2 over SSH, without having to do a full restart?
Thanks in advance!
Animated Eyes Bonnet for Raspberry Pi - Restart over SSH
- guacharo
- mikeysklar
Re: Animated Eyes Bonnet for Raspberry Pi - Restart over SSH
I would try to comment out the mykeys lines (there are three) in eyes.py which might be enough to stop the keyboard requirement.
https://github.com/adafruit/Pi_Eyes/blob/master/eyes.py
It looks like you have the right idea of killing off and restarting processes. I don't see a more elegant solution.
- guacharo
I commented out the following lines first:
#mykeys = pi3d.Keyboard() # For capturing key presses
#k = mykeys.read()
#mykeys.close()
But the code complained about the
NameError: name 'k' is not defined
So I commented the rest of the if statement as well:
#if k==27:
#mykeys.close()
#DISPLAY.stop()
#exit(0)
I am now able to switch eye configs via my scripts.
Each time after I run the helper script the only error that pops up is:
glGetError 0x500
But the graphics switch as expected.
Thank you for the assistance, and have a great day!
#k = mykeys.read()
#mykeys.close()
#if k==27:
#mykeys.close()
#DISPLAY.stop()
#exit(0)
glGetError 0x500
- mikeysklar
Cool I'm glad that worked so now you can run the eyes headless (ha ha).
You might be able to get rid of that last error message "glGetError 0x500".
Look for something like this in the scripts that are running and comment it out,
glEnable(GL_TEXTURE_2D)
- guacharo
Thanks for the assistance! The eyes are indeed headless. Regarding that last error, I don't see anything referencing glEnable
$ grep "glEnable(GL_TEXTURE_2D)" *.py
$ grep "glEnable" *.py
Not a huge issue. Ive gotten around it by redirecting output to /dev/null.
$ sudo ./start_dragon_eyes.sh > /dev/null 2>&1
$ sudo ./start_eyes.sh > /dev/null 2>&1
Ill make sure to post a followup with a video once this project is complete.
- guacharo
As promised, here is a video showing the eyes switching every 10 seonds in a loop.
https://drive.google.com/file/d/1yhBOgO ... p=drivesdk
- mikeysklar
Nicely done. Thanks for sharing the video. The eyes look great in the skull.
